So yeah I know the RPi Model B requires 5V/700mA to run and this accounts for 200mA of power going to the USB ports (for Keyboard/Mouse).
I also noticed that in the wiki people are using 5V/2A adapters. I was wondering if you use a more powerful power supply to give power to the Pi if it's possible to put higher powered USB devices into the USB port directly without needing a powered hub to give them juice.
Anyways the idea I wanted to get across was that I've been doing some looking around and see that USB Wifi Dongles draw anywhere from 100mA to 500mA depending on models at least according to TrendNET's site. I havent seen power usage numbers from other vendors. Also the Mini/Nano adapter seemed to come in around 100mA-210mA and I have a few of the Edimax ones laying around and was considering using one of those.
Anyways if people more experienced with this sort of stuff are able to test how much current a given usb peripheral draws like the Wifi dongles that would be helpful since my goal is to build a PirateBox on a RPi and having to power the RPi and a powered hub sort of kills the portability of it.
USB Wifi Dongles and Power Usage
Page 1 of 2 1, 2
I have a similar project in mind (providing an open Wifi-Access Point with a bridged VPN).
I have power problems too.
I use:
- some cheap power supply (it says "Output: DC 5.4V / 1000mA")
- the cheapest, AP enabled Wifi-USB-Dongle i could find: TP-Link TL-WN821N
- and a Raspberry PI, obviously
So, I toyed around with my setup and had a lot of trouble of getting everything to work. With the fresh Raspbian Image all works better now, almost out of the box - except the power problem.
Scenario 1:
Using an USB-Powered Hub (for the wifi dongle) everything works ok, my Wifi AP starts just fine
Scenario 2:
Using one of the RPIs built-in USB-Ports, it seems it can't get enough power. It just won't work.
#2 is the preferred one - can anybody help me please and tell me what my options are to get the wifi dongle work without a powered usb hub?
- Ben
I use:
Scenario 1:
Scenario 2:
- Ben
What you could probably try is this: use a USB-Y-cable and see whether the power you get through both USB ports is enough for your wlan dongle. Don't know whether this makes a difference on the PI.
In any case, I'd personally think this is cutting a bit close to the bone. I guess you'll be much better off getting yourself a little powered 4-port hub and use that one to power the PI (using a Y-Cable) and your wlan module.
I run my setup with a powered 7-port hub on a 5V/3.5A power supply
upstream plug of hub -> one of the PI's USB ports
PI's power socket -> via USB-Y-cable in two ports on the hub (gives the PI 1 Amp)
wlan dongle -> hub
keyboard -> hub
mouse -> hub
once I get around to it I'll try running a 2.5" USB drive off the hub with another Y cable.
All this with one power supply, so minumum amount of mains cabling.
wlan dongle -> hub
keyboard -> hub
mouse -> hub
CCitizenTO wrote:. I was wondering if you use a more powerful power supply to give power to the Pi if it's possible to put higher powered USB devices into the USB port directly without needing a powered hub to give them juice.
No, due to the polyfuses used in the Pi on the USB, which are rated 140mA- they will "blow" (well, stop current until they reset over time).
Mmmm ok, too bad.It seems I can't get the TP-Link dongle to work without a powerd hub.
Fortunately I could try the same thing with a spare Micro-USB dongle that seems to draw less power (it's "Digitus DN-7042" ) and costs almost the same. I got it to work after a little hassle compiling the Realtek hostapd version and 8192cu.ko drivers. No hub required, range seems to be ok for my purpose.
Thanks everybody for your input! Now that I have a working access point with the RPi I can continue working on my secret evil genius project
Hey Roughnecks !!
Thanks for this tip !! I've been struggling with a 300Mbit D-Link DWA-140 that eventually didn't work with the RPI (it was a B3 rev., anyway..). I'm trying to figure a way to create a wifi AP just like you did and so i just ordered a DN-7042-1 on your advice.
Please, could you be kind enough to tell me (us) how you successfully:
1) installed the wifi usb key on the RPI ?
2) installed the hostap on the RPI ?
(sorry i'm not a big linux expert so details on command lines would be more than welcome..)
Thank you so much
Thank you so much
Hi piranha!
I'll post a detailed instruction later this week, unfortunately I'm a bit busy this week.
Maybe this helps you already:
- latest raspbian image
- install kernel 3.2 and the kernel sources and headers! (<- really important!)
- download the realtek 8192cu driver package from.. (sorry, wrong computer, don't have the link now, just google please)
- extract the zip on your real computer and see the documentation folder for a PDF file that describes how to compile a) the driver and b) the realtek-hostap version (yes it's different from that from debian)
- be sure after you compiled the driver that it is loaded! mine was put into another directory and I had a the debian-driver and the realtek-driver and the debian driver was loaded by default (i then simply copied the realtek over the debian)
- use the realtek hostap binary, not the one from debian (that's why above i had to install kernel 3.2 with sources), then you should get your very own access point on the Raspberry Pi
Ok, that was almost step by step from my memory. Again, I hope I can post more detailed later this week. Hope that helps a bit already
Thank you for these informations, Roughnecks !!
I'll try these once i receive my wifi usb key !!
Hey Roughnecks (& others!),
I received my digitus wifi usb dongle and am trying to follow your instructions.
Obviously, a lot of issues are coming and help would be more than appreciated
So:
- latest raspbian image CHECK
- install kernel 3.2 FAILED
here is what i did:
I followed the instructions on this website:
http://www.bootc.net/projects/raspberry-pi-kernel/
I started by updating the firmware of my RPi by doing this:
https://github.com/Hexxeh/rpi-update
http://goo.gl/1BOfJ -> copy paste file /usr/bin/rpi-update
chmod +x /usr/bin/rpi-update
sudo apt-get install ca-certificates git-core
rpi-update
reboot
works fine!!!
then i resume on the kernel 3.2 installation and as i try to install the linux image package:
"dpkg -i linux-image-3.2.23-rpi1+_1_armel.deb"
then i get a : "package architecture (armel) does not match system (armhf)"
I understand that my architecture does not match what i m trying to install but i don't see a solution at this point. Could you please give me details on how to install kernel 3.2 ? Thank you !!
- install .. kernel sources and headers! (<- really important!)
apt-get install linux-source-3.2 linux-headers-3.2.0-3-all
works fine, i hope these are what will be required afterwards ..
i took it from http://www.realtek.com.tw/downloads/sea ... ord=8192cu
the corresponding pdf file lacks a bit of details.
please could you help (again, sorry..)
there is a driver folder, i guess i am meant to perform:
make clean
make
make install ?
as for the hostap application, should i do the same for the folder "wpa_supplicant_hostapd-0.8" ?
how to ensure your drivers are properly loaded ?
could you be kind enough to give an example of your hostapd.conf file please?
i know it's a lot of questions
but again, i would really appreciate these informations !!
cheers !!
So:
here is what i did:
rpi-update
reboot
works fine!!!
make clean
make
make install ?
cheers !!
here's what I did (hope it works!), If not, tell me what doesn't work please, then I'll have a look what's wrong.
For ease of use, login as root (and save your data from the sd card before...).
First the commands what to do, afterwards my configuration files.
Download and "install" the 3.2 kernel (plus header files):
Download the "RTL8188C_8192C_USB_linux_v3.4.3_4369.20120622" driver file from realtek.
Unzip it (I unzipped to /rtl ("mkdir /rtl"))
now we have: the realtek driver, and the realtek hostapd binary
the install.sh script put the driver into the wrong(?) directory.
because I didn't know better, I just copied the realtek driver over the debian driver:
now reboot. It should work if you start as root:
If all is ok, you now have your own wifi access point on the raspberry pi
attention: if you don't use "./" before hostapd, it will run the debian version, not the realtek hostapd from the directory you did cd into!
Ok, here my configuration files:
/etc/network/interfaces
your network configuration may be different!
/etc/hostapd/hostapd.rtl8192.conf
Instead of wlan1 you can also use wlan0 (this is because I tried another wifi-usb-dongle before).
attention: this is the MOST BASIC hostapd configuration I there is. Use it only for testing purposes.
If your hostapd is running, check with your mobile phone for an open wifi called "abcdefg".
If you see it, everything works fine. You can't connect to it yet, though. You need to setup a bridge network.
For PROPER!!! hostapd config (with wpa2 encryption, bridging to your own network, and so on) see these links:
https://bbs.archlinux.org/viewtopic.php?id=135974
http://forum.doozan.com/read.php?2,6300
For a bridged setup you will need to: apt-get install bridge-utils
Good luck, tell me how it went
- Ben
P.S.: I really do not know if you need that... please try without it first:
apt-get install rfkill network-manager
- Code: Select all
apt-get update
apt-get install linux-image-3.2.0-3-rpi linux-headers-3.2.0-3-rpi
cd /boot/
cp kernel.img kernel.img.3.1.9.backup
mv vmlinuz-3.2.0-3-rpi kernel.img
reboot
- Code: Select all
cd /rtl/RTL8188C_8192C_USB_linux_v3.4.3_4369.20120622/
chmod +x install.sh
./install.sh
cd wpa_supplicant_hostapd/
unzip wpa_supplicant_hostapd-0.8_rtw_20120622.zip
cd wpa_supplicant_hostapd-0.8
cd hostapd/
make
- Code: Select all
cp /lib/modules/3.2.0-3-rpi/kernel/drivers/net/wireless/8192cu.ko /lib/modules/3.2.0-3-rpi/kernel/drivers/net/wireless/rtlwifi/rtl8192cu/rtl8192cu.ko
- Code: Select all
cd /rtl/RTL8188C_8192C_USB_linux_v3.4.3_4369.20120622/wpa_supplicant_hostapd/wpa_supplicant_hostapd-0.8/hostapd/
./hostapd -dd /etc/hostapd/hostapd.rtl8192.conf
auto lo eth0 #br0
iface lo inet loopback
iface eth0 inet static
address 192.168.1.14
gateway 192.168.1.1
network 192.168.1.0
netmask 255.255.255.0
broadcast 192.168.1.255
# Wireless Interface
iface wlan1 inet static
network 192.168.1.0
gateway 192.168.1.1
interface=wlan1
ssid=abcdefg
channel=1
#hw_mode=g
#bridge=br0
- Ben
Hey Ben !
I can't tell you how much i appreciate your reply. Thank you so much for giving me so many details !!
I will be able to resume my Raspberrian activities tonight .. so i'll follow your instructions, and will definitely give you a feedback on how it went !!
How about you, how is your secret evil genius project doing ?
cheers,
Fabien
cheers,
Fabien
Hey Ben,
So i followed your instructions and it worked great.
However, i can't seem to easily set up my access point, but since it appeared once i'll keep working on in, might be a bit unstable -- obviously it is a configuration issue and i'll try to read the links in your posts.
As you asked, i tried without using "apt-get install rfkill network-manager" and it was ok !!
Thank you again!
Fab
Thank you again!
Fab
Hi Fab,
that's strange. do you have the dongle plugged in during boot? do you use any other USB devices at the same time? can you post the output of dmesg? do you get any "smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped" errors during boot maybe?
maybe it helps to increase vm.min_free_kbytes or to disable the ethernet turbomode with smsc95xx.turbo_mode=N (mentioned here: viewtopic.php?p=134136#p134136).
hope you get it stable and working again!
- Ben
- Ben
I did reinstall from scratch, performed once again your instructions and this time i got everything working fine except that after 45 seconds of working wifi AP, the console (that shows the ourput of ./hostapd -dd ..) displays this message:
"l2_packet_receive - recvfrom: Network is down"
then the LED of the dongle stops working and the wifi AP disappears..
I have not found the cause yet, although i have the feeling it may be linked to power saving configuration since the output of dmesg gives:
http://pastebin.com/uukqw1Bm
To answer your questions: i do have the dongle plugged in during boot and i do not have any other USB device plugged apart from the dongle.
I saw your advices related to vm.min_free_kbytes or smsc95xx.turbo_mode=N, but i am not sure that they are linked to this issue since the first one is for OOM and the second one is for the "smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped", which both issues i don't seem to have..
Didn't you meet this behavior on your RPi too ?
Thank you,
-Fab
Thank you,
-Fab
huh.. strange! maybe you need more stuff that I have installed accidentially.
I mentioned:
above. maybe that solves the problem already. Please check "wpasupplicant" too:
if that doesn't work either, I have no clue... maybe just post all your config files.. but I guess they don't look much different then the ones I posted...
During the 45 seconds, can you "connect"? Your mobile should say something like "trying to get IP address..." ....?
- Ben
by the way, that's my output:
I mentioned:
- Code: Select all
- Code: Select all
apt-get install wpasupplicant
- Ben
- Code: Select all
root@raspberrypi:/home/pi# /rtl/RTL8188C_8192C_USB_linux_v3.4.3_4369.20120622/wpa_supplicant_hostapd/wpa_supplicant_hostapd-0.8/hostapd/hostapd -dd /etc/hostapd/hostapd.rtl8192.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd/hostapd.rtl8192.conf
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0x48d650
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=52 freq=5260 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=56 freq=5280 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=60 freq=5300 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=64 freq=5320 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=100 freq=5500 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=104 freq=5520 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=108 freq=5540 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=112 freq=5560 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=116 freq=5580 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=120 freq=5600 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=124 freq=5620 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=128 freq=5640 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=132 freq=5660 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=136 freq=5680 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=140 freq=5700 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=0 dBm
Completing interface initialization
Mode: IEEE 802.11g Channel: 1 Frequency: 2412 MHz
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
Flushing old station entries
Deauthenticate all stations
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan3 with hwaddr 00:e0:4c:09:e9:97 and ssid 'test'
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid_ops
wlan3: Setup of interface done.
random: Got 20/20 bytes from /dev/random
Wireless event: cmd=0x8b15 len=20
Thanks, but i tried with the 3 packages and it didn't change much (except maybe buying one more minute.. weird). I tried to reinstall everything from scratch, just in case, and it's still the same behavior. I have no idea.
Configuration files have been kept as minimal/unchanged as possible. Actually, i'm just changing the hostapd.conf and nothing else ..
I have been trying with other wifi channels, just in case, but no ..
Also i tried to upgrade the firmware (the wlan0 interface disappeared), hence i reinstalled from scratch ..
What's different from you is that the output of my hostapd gives:
It's just so weird that we have the same hardware and settings and we don't get similar behaviors
- Fab
ps: to answer your question, the client tries to get an IP indeed.
- Code: Select all
Wireless event: cmd=0x8b19 len=8
- Fab
really strange
can you post your hostapd.conf? I'll try with your config... maybe I can reproduce it.
what's "uname -r" telling you?
greetings,
Ben
greetings,
Ben
Hey Ben !
uname -r returns "3.2.0-3-rpi".
hostapd.conf is the one you wrote in your post:
I also tried with the hostapd.conf found in the "/rtl/wpa..../hostapd" original folder.
Always, after a while, the message "l2_packet_receive - recvfrom: Network is down" shows up, the dongle LED stops working and the Wifi AP signal is dropped.
Do you think of other files that you may have modified ?
Could i see your hostapd.conf please ?
Thank you!!
- Fab
- Code: Select all
interface=wlan0
ssid=abcdefg
channel=1
#hw_mode=g
#bridge=br0
Thank you!!
- Fab
Also, by the way, could it be an electric power issue ?
How do you "feed" your RPi ?
Do you think trying ArchLinux might help somehow .. ?
(not sure that evolving to kernel 3.2 would be that easy with Arch)
I use a 1000mAh power supply. But I don't think it's power related. As you say it works for a minute or so...
Do you start the LXDE gui? Have you tried the vm.min_free_kbytes settings meanwhile?
I've never used ArchLinux and I don't know wether it would change anything, anyway, you could give it a try.
If I find enough time I'll dd my SD-Card and upload it somehwere, or - if it's possible for you - you could upload your image. I'm a bit busy, as usually...
Greetings,
Ben
Greetings,
Ben
Hi Fab, sent you a private message just in case you didn't notice
Hi i wonder if any one can help.
i have got wireless USB "Sitecom 150N" apart from seeing it on my >lsusb.
not sure how to make it work .i 'm familiar with linux but not to the extend that the other guys are showing in this post.
thank you
David A
thank you
David A
Hi avitada,
can you post the exact model? It should be somewhere in the "lsusb" output.
Greetings,
Ben
Greetings,
Ben
Thank you Ben
when the system bootup i can see under USB product RTL8188S adaptor.
under >lsusb sitecom Europe B.V
i also loaded network manager GUI from synaptic.
when i try to give myself a static ip address (in order to connect to my laptop)
it does not look like it change it /etc/network/interfaces have just dhcp. this is my second issue..
thank you for your help Ben
Here is a great walkthrough: http://omer.me/2012/04/setting-up-wirel ... pberry-pi/
If you can't get it to work with that tutorial, please come back here
