Hi meigrafd,
give me your mailadress
and I send it to you.
Mine is
dietmar.stoelting@t-online.de
Just unrar and copy and paste the compiled qemuadlib,
have a nicer day
Dietmar
Win95 on real Raspi
Page 4 of 5 1, 2, 3, 4, 5
Internet works also,
little bit slow until now
greetings Dietmar
greetings Dietmar
Why are you teasing us ?
ghans
ghans
I think it should be better to give all here a link to your modified qemu instead of get in contact with you via email..
i dont think you want to get 100's of emails or?
use something like rghost.net or so for upload
Hi all,
I just uploaded it to rghost.net.
I split it into two parts,
qemuADLI.part1.rar
qemuADLI.part2.rar
Copy and past it to your Raspi. It is the compiled Qemu version 15.50 from Thoronir with corrections. To set the pathes, just type at commandline as root
make install
Without make install, you can copy your Windows Image to the folder qemu/i386-softmmu
and type there ./qemu for to start.
You can start any Windows with Sound and Internet with it via
if you install the driver for soundblaster Creative Labs Sound Blaster 16 oder AWE-32
and network card Realtek RTL8139
Good luck,
I am going to improve Qemu velocity,
Dietmar
qemuADLI.part1.rar
qemuADLI.part2.rar
make install
- Code: Select all
qemu win95.img -soundhw sb16 -net nic,model=rtl8139 -net user
Good luck,
Dietmar
Hello Ditmar,
I don´t see a download link , plase post the direkt link.
Deutsch:
Hallo Ditmar kanst du den Direkten Link zum download posten ?
Danke Schön THS
Deutsch:
Danke Schön THS
I noticed,
that it may be just enough to copy the executable
file qemu from i386-softmmu
to the folder /usr/local/bin of your working Qemu
Dietmar
Dietmar
Thanx!
So in the Archive is not only the already compiled binary, you've also include the source?
How's the command line with whitch you compiled it?
Hi meigrafd,
yes, it contains also the Source code, because so you can see my changes.
The command line for configure is
Important is, that you change to alsa oss
sequence because strange behavior of Qemu. For esd sound I got always error :Missing headers and libs, even I installed esound^^. So I put esd out from configure.
At the moment I test the new tcg from Qemu 1.3.0
also with --enable-tcg-interpreter
Dietmar
- Code: Select all
./configure --target-list="i386-softmmu" --enable-sdl --extra-cflags="-O3 -mfloat-abi=hard -mfpu=vfp -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -march=armv6zk" --audio-drv-list="alsa oss sdl pa" --audio-card-list="ac97 es1370 sb16 cs4231a adlib gus hda"
Dietmar
Also only
crash crash crash with newest fresh compiled qemu-linaro-1.3.0-2012.12
It crashes a few sec later with tcg than with tci, brrrrr
greetings
Dietmar
greetings
Dietmar
which pakages should be installed?
coz when i want to start i get
- Code: Select all
Could not initialize SDL(No available video device) - exiting
qemu with SDL can only start after startx in commandline,
greetings Dietmar
greetings Dietmar
It doesen´t work . It says ./qemu = Permission Denied. Can you Help me ?
When I do make install it says:
Makefile:11: /home/pi/raspidev/qemu/rules.mak: No such file or directory
Makefile:23: /home/pi/raspidev/qemu/Makefile.objs: No such file or directory
make: *** No rule to make target `/home/pi/raspidev/qemu/Makefile.objs'. Stop.
THS
THS
Hi THS,
just go to the folder, where this qemu stays and type from this folder in commandline
this works,
Moorhuhn and Settlers 2 are playable like normal with sound,
Dietmar
- Code: Select all
chmod 777 qemu
this works,
Dietmar
Dietmar wrote:http://rghost.net/42415417
http://rghost.net/42415597
Hmm... either I'm too stupid to download the files, or the support for Safari (Mac), FF17 (Mac) and IE9 (Win7) is broken for this site. Anyone else who has problems or anybody who could successfully download the files?
-> Resolved: clicking about 100times the link leads to a result. I've uploaded the files with unlimited transfer limit to my webserver at http://c-works.net/rasp/. Download it as long as it's availble
@Dietmar: If you want, I can offer you a free "mirror" for your files.
Es funkuniert immer noch nicht .
Welche Raspbian Version nutzt du ?
Grüße THS
Grüße THS
Hallo THS,
ich benutze die Raspbian Version vom 16. Dezember 2012.
Was passiert, wenn du jetzt ./qemu eintippst?
Es müsste sich das Qemu Fenster öffnen, auch ohne win95.img Datei.
Das funktioniert aber nur nach startx Eingabe wegen SDL Ausgabe in Qemu.
Ich kann auch mein komplettes Raspbian Image auf Torrent hochladen, falls jemand Interesse hat.
Das sind ca. komprimiert 600 MB,
Gruß Dietmar
Gruß Dietmar
Hi segfault1978,
I just downloaded my own 2 files from there,
Dietmar
Dietmar
Ich hab intresse an einem Image ,aber nicht als torrent kannst du es nicht rghost oder hier im Forum oder mediafire oder auf deiner eingen HP hochladen?
Grüße THS
PS : ich poste die Fehler nicht von mir sondern für flussotter aus dem [url]Raspberrycenter.de[/url] Forum
Grüße THS
Hi THS,
bei rghost dauert das uploaden 7 Stunden
, da alles 50 MB Pakete sind,
da ist Torrent besser. Vielleicht hast du ja auch eine andere Idee. Mir ist nicht klar, wo das Problem liegt.
Ich lade jetzt die gepatchte Qemu Thoronir Version hoch.
Die ist noch nicht compiliert.
Unrar und copy und paste den ganzen Ordner qemu in den Ordner /home/pi auf dem Raspi.
Dann tippe aus dem Ordner /home/pi/qemu in der Kommandozeile als root ein:
Dann gib in der Kommandozeile als root aus dem Ordner /home/pi/qemu ein
Nach ca. 1 Minute dann
und nach ca. 1,5 Stunden, wenn wieder die Kommandozeile erreicht wurde
Dann ist das Qemu fertig und kann mit qemu gestartet werden,
Gruß Dietmar
http://rghost.net/42461226
qemudidi2.rar 39,9 MB
- Code: Select all
chmod 777 configure
- Code: Select all
- Code: Select all
make
- Code: Select all
make install
Gruß Dietmar
Erstell dir einfach ein Verzeichnis /home/pi/raspidevTHS wrote:When I do make install it says:
mkdir -p /home/pi/raspidev
verschieb das entpackte qemuADLIB Verzeichnis dann als /home/pi/raspidev/qemu
mv qemuADLIB /home/pi/raspidev/qemu
und dann funktioniert auch "make install"
I've uploaded the files to my server. You can download it directly to your rpi with wget:
- Code: Select all
wget 198.154.101.186/RaspberryPI/qemudidi2.rar
- Code: Select all
wget 198.154.101.186/RaspberryPI/qemuADLI.part1.rar
wget 198.154.101.186/RaspberryPI/qemuADLI.part2.rar
Du soltest aber dann die Sachen als tar oder zip hochladen ,oder wie entpacke ich ein rar Datei auf dem Pi.
Grüße THS
Grüße THS
To unrar *.rar under Linux:
- Code: Select all
apt-get update
apt-get install unrar
unrar x qemuADLI.part1.rar
or:
unrar x qemudidi2.rar
