Also, because of the thin side-walls, a bit of additional hacksawing or dremeling shouldn't be too difficult.
I've limited myself to only using pieces that are currently available from Lego's "Pick a Brick" shop, in red.
I've tried to fit everything into an 8*12 grid footprint, which will hopefully fit ... but I don't have the specs of the thickness of the thin wall-pieces, so no guarantees. One thing that might screw things up is the height of the board's connectors: I don't know whether they'll all fit within the upper and lower lip of the side-wall pieces. If the board's "USB port stack" is too high, I guess the "roof" could be raised by a tile or two.
I knocked it up with Lego's Digital Designer program (free download from their site). The critical Lego piece is the repeated hollowed-out "side wall" ("[") brick ("wall element 1*2*2, w. window"), which you'll find on LDD's parts palette behind the little "door" symbol, or under the Pick a Brick page ( http://shop.lego.com/en-GB/Pic.....ck-ByTheme ), as element #4507686, design #60032 (red), cost 8 pence each.
Feel free to hack, mangle or otherwise rework. If anyone wants the file to mess around with, they're welcome to that, too (can we upload files here?). Whatever.
Eric
