Beta Boards mechanical data
73 posts   Page 1 of 3   1, 2, 3
by Gert van Loo » Tue Jan 10, 2012 4:53 pm
I have taken one of the Beta boards and a digital ruler/caliper. The measurements I have taken are posted below. I can not give the measurements of the SD-card holder as the first boards are mounted with a temporary SD-card holder. We have to wait for the final one.
I have opened a new topic instead of posting the data in the various topics dealing with the casing of the raspberry-pi. I leave it up to you guy to link this post into all those posts :-)
As usual: Not guarantees, best effort etc. The PDF is here:
http://www.scribd.com/doc/77785093
(Post edited. Hit return by accident)
Moderator
by jojopi » Tue Jan 10, 2012 5:45 pm
Interesting, thanks.
I note that your PCB measurements of 85×56 are squarer than the advertised 85.60×53.98 — and agree better with the board photos and Gerber screenshots.
Edit: though, according to your conventions it should be 56×85.
by stormy1 » Tue Jan 10, 2012 5:49 pm
Thank you!
by Gert van Loo » Tue Jan 10, 2012 5:53 pm
Ooops, yes you are right!
Good I put in all the disclaimers.
Moderator
by mobeyduck » Tue Jan 10, 2012 6:02 pm
looks great but im missing the highest point on the board as in total hight/max hight
it looks like 15.3 from the usb + 1.6mm from the board 16,9mm +5mm from the sd card makes it 21,9
by Gert van Loo » Tue Jan 10, 2012 6:57 pm
I know, I assumed people can add. I did not give the max. width or max. lenght either. Also with no definitive SD-card holder and not knowing if components change for the next batch all figures are indicative anyway. I suggest whoever makes a case adds some slack.
Moderator
by arm2 » Tue Jan 10, 2012 9:21 pm
Thanks Gert.
Are the "Flange sticks out 0.6mm on all four sides" where the boards were attached to their carrier as shown in the first photo's of the PCB?
I can't see the positioning dimension for the USB sockets! Am I being stupid?
by Gert van Loo » Wed Jan 11, 2012 8:02 am
arm2 said:
Thanks Gert.
Yep, I missed the USB position. I have uploaded Rev1.1 with corrections.
The Flange is a where the outside of the metal USB connector case is 90 degr. folded outwards. So the bulk of the connector is 15.3 high and 13.25 wide, but at the opening it has another 0.6 mm sticking out at each of the four sides. Thus you need a hole in your case which is (15.3+0.6+0.6) x (13.25+0.6+0.6) to pass it through.
Moderator
by arm2 » Fri Jan 13, 2012 8:35 pm
Thanks Gert, I've update the design of our cases appropriately. I'll post photos of the mock ups we've made next week.
Now that production has started can the Foundation tell us the part number of the connectors being used?
I'll track down the mechanical data and post here the information so that anyone can start making cases!
Many connectors are not going to be very different in shape and size to those used on the Beta boards, but I suspect the SD card holder will be quite different, apart from sticking out the side it is down as protruduing 5mm below the PCB, all other SD card holders I've measured are 3.0 - 3.3mm in that dimension.
Also I've picked up some samples of possible suitable materials for Mass produced cases, that I think might be of interest to the Foundation. Is there a postal address I can send them to?
by Borg 1.0 » Wed Jan 18, 2012 12:00 am
Gert, is it possible that the PCB design file could be used to get the exact measurements, instead of the ruler/string method? :)
I can send the PCB file to a local CNC place for making a case. But that requires the actual PCB data, whether it's a Gerber or a PCB (Eagle, Altium, etc) file.
Instead of releasing the actual PCB data, would it be easier/safer to do a fabrication print with all the dimensions? That way, we can read the data without having access to edit/change it. Just a thought...
It's not that I don't trust your calipers, I just naturally work better with mils/thous....
by Gert van Loo » Wed Jan 18, 2012 12:42 am
Although I designed the Alpha boards and was involved in the Beta re-design I do not have access to the Beta boards database. That is owned by the Raspberry-Pi foundation.
Moderator
by liz » Wed Jan 18, 2012 12:53 am
And unfortunately Eben and I don't have access to those files until we're back in the UK. Poke me next week and I'll try to get him to get the measurements off the datasheet.
by rurwin » Thu Jan 19, 2012 8:46 am
Gert, could I ask you to take out your tape measure again?
It seems to me that for a case to hold the board securely, it will have to have a lip that the board sits on. It would be good to know how wide the lip can be. Ideally we would want the board to sit flat on it; there should be no joints or components between the lip and the board.
So we need to know the minimum clearance from the edge of the board, on the underside. (Ignoring the area around the SD socket of course.) That may not even be measurable from the schematics, because it includes the space taken by solder.
Moderator
by slurp » Fri Jan 20, 2012 8:16 pm
This is good to see, it'll help me start planning an interface I have in mind for a small robot.
I'd been thinking about placing mounting holes on this new board and that utilising a connector in the P2 or P3 location would make the Pi mount a little more stable. I do note that I should leave these pins isolated.
I'm guessing I can make an approximation from the Gert's drawing but it would be fantastic if Liz could include this in the publication (next week?).
Best regards,
Colin
by lanica » Sun Jan 22, 2012 3:46 am
Made a Google Sketch-Up.  Assume the same disclaimer.  Might be easier for some to make a case using sketch-up…
Wish the board supported attachments.  Here it is for download:
http://www.filedropper.com/raspberrypi
by tzj » Sun Jan 22, 2012 3:56 am
makes me wonder what"s wrong with 3d warehouse when sharing sketchup models...
http://www.themagpi.com <---- Checkout the MagPi
(The MagPi - Co-Founder)
by mspice » Sun Jan 22, 2012 5:12 am
If we could also have a BOM with part numbers, we could model every connector very accurately.
by HansH » Sun Jan 22, 2012 9:01 am
Ok I am lost...
Is the actual pcb   56mm  or  53.98mm width ?
by lanica » Sun Jan 22, 2012 4:37 pm
Likely nothing.  I'm not that experienced with Google SketchUp... Just didn't think about it I suppose.
Its in the 3D warehouse:
http://sketchup.google.com/3dw.....f459967fe5
It is also publicly editable, so feel free to update/tweak it.  If someone defaces the model then I'll turn public off and just add individuals as collaborators.
by lanica » Sun Jan 22, 2012 4:41 pm
Ok...looks like you had one as well ... you could have just said that :P   Anyone else who stumbles upon this topic, tzj has one at:
http://sketchup.google.com/3dw.....659e23ee1a
I'm assuming you posted this elsewhere in which I entirely missed....
by Gert van Loo » Sun Jan 22, 2012 6:41 pm
Sorry, I did not see your post until today. I don't mind PM's as long as there are not too many.
I started measurements but I stopped after half an hour. This is significantly more complex then the connectors. There are lots of tiny components at the bottom and all kind of pieces of metal sticking out. Also some pins/metal have solder round them and the distance to the edge is set by how much solder is present.
I estimate is that you have about 1.6 mm free around the edge, except the Ethernet mechanical pin sticking out which is about 1.3.
Looks to me your best chance for support is not a ledge but some pillars at the right places. I will see what I can come up with but I would suggest you look at the photo's of the bottom, select some reasonble large flat places and put pillars there. Now you know that the PCB is 56x85 you can get the rest of the measurements from that.
Moderator
by rurwin » Sun Jan 22, 2012 9:31 pm
Thanks. So probably 1mm or pillars. I'll take a look at the photos.
Edit: done.
The photos of the beta boards need to be corrected for perspective before measurements can be taken from them. I have done that, and the results can be found here. I think they can be trusted to within 1mm, but no guarantees.
Edit again:
I've added some suggested support locations to the page given above. The locations I suggest only require measuring in 5mm steps, and should allow a couple of mm error.
Moderator
by HansH » Mon Jan 23, 2012 11:52 am
rurwin said:
Thanks. So probably 1mm or pillars. I"ll take a look at the photos.
Edit: done.
Edit again:
I am not so sure about that support bridge.... depends a bit how far the SDcard will go in...
by rurwin » Mon Jan 23, 2012 12:40 pm
That's a fair point. I was assuming it would come no further than the silkscreen shows it. The same technique should be useful; the bridge could be moved back about 4mm, or the pillars could be moved closer to the edge of the board by about the same amount. But those reduce the error margin and make the measurements more fiddly. We wont know if there is a problem or how to solve it until the production boards arrive, since the beta boards do not have the correct SD socket.
Moderator
by HansH » Mon Jan 23, 2012 1:45 pm
well, it looks like they were meaning to use something like this:
http://www.harwin.com/include/.....860942.PDF
a half length sd slot connecter, measurements seems the same as the markings
The sdcard will stick outside the pcb for approx 18mm
So your bridge is ok...
