Problem with Pi store
I got my Pi at Christmas and was able to log into Pi store, but couldn't load any applications as I got an error message every time. From the forum topic I think this has been fixed but earlier this week I did an update and I think a new version of pistore was installed. Now I cannot get into Pistore at all. I just get the loading screen and then nothing happens. Can anyone help?
Hrm - that's a strange one. How long have you tried leaving it for?
~Richard Williams
~Richard Williams
I left it until there was no processor activity as indicated by the bottom line task monitor , should I try removing and the re-installing?
Yeah - it definitely sounds like it's become stuck then.
It sounds like you might have the same problem as in this topic. Could you please try deleting everything in /var/lib/indiecity/pistore/GUI and restart Pi Store?
~Richard Williams
~Richard Williams
I am new to Linux, how do I delete the contents of this directory . It seems to include several directories and some of the files are write protected.
I Have worked out how to delete the contents of the /GUI directory but starting pistore gave the same result. I then tried removing and installing pistore wit update and upgrade both before and after. I now have the same problem as the other post, ie after a short while I get the user interface failed to load message
