MC FOR RASPBERRY PI!!!!!!!!!!!!!!!!!!
by jonas » Fri Nov 02, 2012 1:57 am
hello my name is jonas. 8-)
I have set up these steps to help you get vanila minecraft to work on your raspberry!
(if you are helpfull plese leave coments in the post so I know how to use java applets) :oops:
missing!
(I need you to tell me how to work java applets for raspberry.)
steps:
1.go to MC.net
2.login or register
3.play demo
4.play world on demo
(stop the demo world while loading or it will not work)
5.download minecraft linux.jar
6.run it
7.login
(or if you do not have a account just type your name and login for offline moad)
8.play it and it will work! :D :D :D :mrgreen:
by 6677 » Fri Nov 02, 2012 8:51 pm
you can skip 2, 3 and 4 entirely. Then you'll find out the lack of GPU acceleration through LWJGL and glitchy OpenGL support (due to pi plain not supporting it which is common on ARM), slow CPU and little RAM all stack up to make 1 fps.
by MrMonotone » Sat Nov 03, 2012 6:02 am
Sorry Jonas! The Raspberry Pi isn't powerful enough to run Minecraft! Believe me I wish it could too! :D
by jonas » Sun Nov 04, 2012 3:58 pm
I belive it is.
My dad is a programer :geek: and he thinks it is possible with a little work and time! :D
Just so you know, i will post steps for it. :D
Although i still like all your coments. ;)
by jackjt8 » Tue Nov 06, 2012 6:24 pm
MrMonotone wrote:Sorry Jonas! The Raspberry Pi isn't powerful enough to run Minecraft! Believe me I wish it could too! :D
You are correct, in regards to Minecraft PC...
However, don't forget Minecraft Pocket Edition. It runs on mobile devices, with the same specs as the RPi- 1GHz Processer, (As low as 700MHz) 512mb ram, running Android OS (Linux based), with OpenGL ES 2.
by mahjongg » Tue Nov 06, 2012 9:39 pm
Is the source of minecraft pocked edition available, otherwise I don't see how you can port it to the PI....
Moderator
by xranby » Fri Nov 09, 2012 1:04 pm
spsn have done an initial hardware accelerated Raspberry Pi port of opengles LWJGL!
viewtopic.php?p=211087
spsn have also released Not Minecraft, but Blocky, using it!
viewtopic.php?p=211054
It is running 60fps 1080p using JamVM + OpenJDK + Raspbian armhf.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
by 6677 » Fri Nov 09, 2012 7:38 pm
mahjongg wrote:Is the source of minecraft pocked edition available, otherwise I don't see how you can port it to the PI....
It is closed source and is actually written in C++ according to jeb on twitter (current lead MC dev) in order for them to be able to support iOS. It also was made specifically for ARMv7 not v6 although that shouldnt be the hardest thing in the world to correct.
