Quake 3 on Raspbian wheezy
by dmtben » Wed Oct 31, 2012 12:39 pm
I am really struggling with compiling Quake 3 on my Raspberry Pi.
I dont know what i am doing wrong on it, but it will not even download the source files.
I am using the files from https://github.com/raspberrypi/quake3.git and following the instructions from http://www.raspbian.org/RaspbianQuake3 .
I am running it off the LXterminal on my Pi and it will not download. Should i try on the Root terminal?
I am only 14 and struggle very much with this type of thing, so can responses be in easy to follow instructions, thankyou! :D
by raspberrypiguy1 » Wed Oct 31, 2012 12:55 pm
Hello my dear friend! Those instructions, I think, are outdated!
I have a quick tutorial on how to build Quake 3 on Raspbian... Your thoughts and ideas would be appreciated! (Sorry that I am a bit unclear when it comes to the Pak files and the baseq3 part! REMEMBER: the Pak files need to be in the baseq3 folder... Not in another baseq3 folder inside the baseq3 folder!) Don't worry you will understand when you come to that part!
http://www.youtube.com/watch?v=nSqFdguPEzI
Good luck
The Raspberry Pi Guy
Check out my awesome new tutorial series on youtube:
http://www.youtube.com/user/TheRaspberryPiGuy?feature=mhee
For simple tutorials from writing an OS to an SD card and then all the way up to controlling robots with the GPIO! Enjoy! :)
by jonas » Sun Nov 04, 2012 4:25 pm
Just so you know it is posible and i'm 10. :oops:
but i just transferd the files from another computer. :arrow:
by Synthetic_Darkness » Mon Nov 05, 2012 12:27 pm
Are you sure that your Raspberry Pi has internet access? Sounds like it doesn't. Although what error does it give you?
Try using Midori to go to any webpage.
http://codefridge.com/ - where cool code comes to chill.
