Audio input
Suggestions and requests for the Raspberry Pi Foundation
by rwk » Fri Dec 23, 2011 6:42 pm
Hello, I have searched through the past posts on this topic, but I see no clear answer. What are the audio input capabilities? I don't see an audio-in jack. But perhaps there is some other way? Yes I am sure I can get a USB sound card but I am trying to avoid that. I don't need stereo or very low delay. I do need the ability to do audio out and audio in at the same time, with a moderate amount of signal processing.
by Jessie » Fri Dec 23, 2011 10:06 pm
There is no audio in. You can buy a usb device, or write some code to bitbang an input through the gpio pins.
Moderator
by updatelee » Sat Dec 24, 2011 8:15 am
The specs on the audio codec show a mic in, wire up a header and see what you get.
by Gert van Loo » Sat Dec 24, 2011 7:17 pm
That is not true, there is NO audio in. There is no audio codec.
Moderator
