I see that a cross-compilation toolchain is available for the Raspberry Pi on github in https://github.com/raspberrypi/tools, and that this includes headers and libraries for the standard stuff like the C library, maths library, pthreads, etc...
Where can I find the headers and libraries to add to that for graphics libraries (OpenGLES, OpenVG, etc.)?
Thanks,
Rob.
headers/libs for cross-compiling graphics programs
they are all in /opt/vc
What I do is make a copy of this on my target machine and cross compile using a simple makefile like this one (see the hard coded paths etc just alter for your own system) For easy I also copy other libs I use (such as image magic to the same directory on the host machine as well)
- Code: Select all
CC=arm-none-linux-gnueabi-g++
CFLAGS=-c -Wall -O3 -I/Volumes/home/jmacey/boost_1_49_0/ -I/opt/vc/include/interface/vcos/pthreads -I/Volumes/home/jmacey/teaching/pi/opt/vc/includ
e -I/Volumes/home/jmacey/teaching/pi/opt/vc/include/ImageMagick -Iinclude/ngl -Isrc/ngl -Isrc/shaders -DNGL_DEBUG -DLARGEMODELS
LDFLAGS=-shared -L/Volumes/home/jmacey/teaching/pi/opt/vc/lib -lMagickCore -lMagick++
SOURCES=$(shell find ./ -name *.cpp)
OBJECTS=$(SOURCES:%.cpp=%.o)
EXECUTABLE=lib/libNGL.so
all: $(SOURCES) $(EXECUTABLE)
$(EXECUTABLE): $(OBJECTS)
$(CC) $(LDFLAGS) $(OBJECTS) -o $@
.cpp.o:
$(CC) $(CFLAGS) $< -o $@
Thanks jmacey. I guess you mean /opt/vc in the target filesystem? Will this contain the same files no matter which OS distribution I choose?
Thanks,
Rob.
Thanks,
Rob.
yes from the target system. IIRC the /opt/vc is part if the main firmware / kernel so all "official" distros should have it (I think vc stands for Video Core) You can also download it from here https://github.com/raspberrypi/firmware/
Ah, I see now - thanks.
Rob.
Rob.
