I have just uploaded a kernel package to raspbian based on incorporating bootc's patches with the debian kernel source.
I do not currently reccomend this kernel for general use because i'm having freezeup problems with it ( see: viewtopic.php?f=71&t=9468 ). Nevertheless I would appreciate people taking a look at it and telling me if anything they want is missing.
To install it (once it hits the public repo) use
apt-get install linux-image-3.2.0-3-rpi
There is nothing in place to automatically make this kernel bootable (a tool to do that will come later). You will have to manually copy the newly installed kernel from /boot/vmlinuz-3.2.0-3-rpi to /boot/kernel.img to use it. I recommend making a backup of your current kernel.img first so you can revert to it.
raspbian kernel alpha
- Moderator
Works fine so far. Thanks!
I'm not really sure about this: I have a feeling that "-buffers/cache" memory usage with my setup (few daemons) as measured by the "free" command line tool has increased from ~25MB with 3.1.9+ to ~39MB with 3.2.0-3-rpi. Maybe this is to be expected though, because the kernel now has more features built-in?
When I have the time I will try booting the older kernel again, re-check if I remember the 25MB correctly and compare "ps" output.
Works fine so far and the support for iptables, SCSI tape & NFS kernel server are working.
My tip for booting the new kernel would be instead of copying from /boot/vmlinuz-3.2.0-3-rpi to /boot/kernel.img to add a line to your /boot/config.txt file like so:
On my setup I don't have a /boot/kernel.img but simply point to the kernel to be booted via /boot/config.txt. I find this easier to figure out where I am up to and there is no need to copy the kernel image about all the time.
I'll be unable to do any more testing for about a week.
- Code: Select all
#kernel=kernel.img-3.1.9-clw
kernel=vmlinuz-3.2.0-3-rpi
No crashes so far, but I noticed that the SD slot performance regressed from the 3.1.9+ kernel.
3.1.9+
/dev/mmcblk0:
Timing cached reads: 388 MB in 2.01 seconds = 193.15 MB/sec
Timing buffered disk reads: 54 MB in 3.01 seconds = 17.93 MB/sec
3.2.0-3-rpi
/dev/mmcblk0:
Timing cached reads: 152 MB in 2.01 seconds = 75.77 MB/sec
Timing buffered disk reads: 10 MB in 5.43 seconds = 1.84 MB/sec
3.1.9+
/dev/mmcblk0:
3.2.0-3-rpi
/dev/mmcblk0:
I've got it installed and it seems to be running nicely. Purely anecdotally since I've done no proper testing, everything seems to be running smoother and quicker than before. No lock ups yet.
Forget about my suspicion of higher memory usage. Not exactly sure what caused it to use 39MB, but after a fresh boot, the 3.2 kernel uses only a few MB more than 3.1.9+ (if at all..). [Can't edit my post unfortunately.]
Just like you, I experienced a few hangs/freezes. I use the rpi headless, so my SSH client would eventually stop visually responding to input, and after some time I'd pull the plug and reboot. It seems like "heavy" I/O can lead to a hang. It happened once during a "dpkg -i" call with relatively big packages (all of the chromium debs), and I believe it also occured when I used apt-get one time, and once after starting chromium via VNC. I couldn't find anything interesting in the logs..
If there's any way in which we could help with debugging the problem, let us know. I got tired of pulling the plug every now and then (which corrupted my rootfs once, boot failure).. So for now I reverted to 3.1.9+ to enjoy some 24hours+ uptime.
Again, thanks for your hard work!
Hi plugwash,
I just installed your kernel because Bootc's didn't recognize my KVM switch properly and blocked the network as well and I wanted to play with the SPI and I2C busses.
Unfortunately your kernel is missing the I2C device.
SD-Performance is at over 20MB/s sequential read, so no problems there for me.
Regards
Aydan
Regards
Aydan
Hi again,
forget the I2C thing, I didn't know I had to modprobe it.
Otherwise it's been running OK. I'm seeding the Pisces image with transmission and haven't had any hangs or anything.
Only my USB harddrive doesn't work at all with this kernel, see here
Regards
Aydan
Regards
Aydan
i have a little problem with this kernel. i use qemu and by start freeze this system.
the qemu call is
qemu-system-arm -M versatilepb -cpu arm1136 -m 256 -kernel vmlinuz-3.2.0-3-rpi -initrd initrd.img-3.2.0-3-rpi -hda raspbian.img -append "root=/dev/sda1"
a idea? thanks for information
Regards
the qemu call is
Regards
Thanks to various people (foundation members included) being sloppy when discussing such things a lot of people seem to think that qemu can emulate a Pi.
This is not true. It can emulate a system with the same CPU core and the same ammount of memory as a Pi but the similarites between qemu-system-arm and a Pi pretty much end there. In particular the hardware surrounding the CPU core is different enough that different kernels are required.
- Moderator
I'm currently using your kernel and it works great for me. I have no problems with freezups even with heavy load over long time (although I'm using the RPi headless without X).
Maybe you could add the CONFIG_MODULE_FORCE_LOAD=y in a future build?
I have another question: Is apt-get source linux-image-3.2.0-3-rpi the correct way to obtain the source the kernel was built with?
Regards Peter
Regards Peter
Thank you plugwash!
Installed your kernel as described in the first post.
I use it together with an up-to-date Raspbian.
Is stable, tested GPIO, UART/serial and am just now trying to do my first steps in I2C (which is why I upraded to your kernel for the i2c_bcm2708 module...).
Thanks (to you and your team) for Raspbian and all your dedicated and professional work!
Just to let you know (not sure if this is the right place for it), I'm getting errors when installing:
At first i thought this may have had to do with me using a swedish locale, and the postinst trying to interpret some unexpected command output (since the "full line" message was originally in swedish), but i retried using LC_LANG=C (as seen above) with the same symptoms.
I see something in there about missing firmware, but the rest of the message doesn't make sense to me, at least in that context...
I do have a manually installed firmware for my wifi-plug (carl9170), could that be part of the issue?
Is this a bug or just something weird with my system?
- Code: Select all
Setting up linux-image-3.2.0-3-rpi (3.2.21-1+rpi1) ...
Running depmod.
Error setting debconf substitutions in linux-image-3.2.0-3-rpi/postinst/missing-firmware-3.2.0-3-rpi: Unsupported command "removing" (full line was "Removing 'diversion of /boot/vmlinuz-3.2.0-3-rpi to /usr/share/rpikernelhack/vmlinuz-3.2.0-3-rpi by rpikernelhack'") received from confmodule. at /var/lib/dpkg/info/linux-image-3.2.0-3-rpi.postinst line 606, <STDIN> line 3.
dpkg: error processing linux-image-3.2.0-3-rpi (--configure):
subprocess installed post-installation script returned error exit status 255
A package failed to install. Trying to recover:
Running depmod.
Error setting debconf substitutions in linux-image-3.2.0-3-rpi/postinst/missing-firmware-3.2.0-3-rpi: Unsupported command "no" (full line was "No diversion 'diversion of /boot/vmlinuz-3.2.0-3-rpi by rpikernelhack', none removed.") received from confmodule. at /var/lib/dpkg/info/linux-image-3.2.0-3-rpi.postinst line 606, <STDIN> line 3.
So I downloaded this kernel and then the source so I could add the easycap driver. It seems that the easycap directory was empty. I copied over from a different source and then compiled the module. It seemed to compile OK, but I am now getting just a green screen.
Thought I would post here to see if anyone had ideas: Here is a snippet from dmesg log:
1432.251055] bcm2708_fb_check_var info(cb8d0400) 1024x768 (1024x768), 1572864, 16
[ 1432.251079] bcm2708_fb_check_var var(c0fd5de0) 1024x768 (1024x1536), 16, 786432
[ 1432.251105] bcm2708_fb_set_par info(cb8d0400) 1024x768 (1024x1536), 1572864, 16
[ 1432.264941] BCM2708FB: start = cd800000,4d506000 width=1024, height=768, bpp=16, pitch=2048 size=3145728 success=0
[ 1440.266058] easycap::0easycap_complete: easycap driver shutting down on condition green
[ 1441.800855] easycap::0adjust_standard: selected standard: PAL_BGHIN
[ 1442.190022] easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mask
[ 1442.190061] easycap::0adjust_format: sought: V4L2_FIELD_NONE
[ 1442.190092] easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n
[ 1442.219908] easycap::0adjust_brightness: adjusting brightness to 0x7F
[ 1442.249906] easycap::0adjust_contrast: adjusting contrast to 0x3F
[ 1442.279894] easycap::0adjust_saturation: adjusting saturation to 0x2F
[ 1442.309905] easycap::0adjust_hue: adjusting hue to 0x00
[ 1449.682596] easycap::0easycap_complete: easycap driver shutting down on condition green
[ 1451.391390] easycap::0adjust_standard: selected standard: PAL_BGHIN
[ 1451.780185] easycap::0adjust_format: sought: 640x480,UYVY(0x59565955),1=field,0x00=std mask
[ 1451.780214] easycap::0adjust_format: sought: V4L2_FIELD_NONE
[ 1451.780243] easycap::0adjust_format: actioning: 640x480 PAL_BGHIN_AT_640x480_FMT_UYVY-n
[ 1451.810038] easycap::0adjust_brightness: adjusting brightness to 0x7F
[ 1451.840056] easycap::0adjust_contrast: adjusting contrast to 0x3F
[ 1451.870038] easycap::0adjust_saturation: adjusting saturation to 0x2F
[ 1451.900055] easycap::0adjust_hue: adjusting hue to 0x00
[ 1451.907300] easycap::0adjust_mute: adjusting mute: 1=peasycap->audio_idle
[ 1451.912866] bcm2708_fb_check_var info(cb8d0400) 1024x768 (1024x1536), 3145728, 16
[ 1451.912890] bcm2708_fb_check_var var(c0fd5de0) 1024x768 (1024x768), 16, 1572864
[ 1451.913195] bcm2708_fb_set_par info(cb8d0400) 1024x768 (1024x768), 3145728, 16
[ 1451.930388] BCM2708FB: start = cdc00000,4d385000 width=1024, height=768, bpp=16, pitch=2048 size=1572864 success=0
I have found that this kernel will not boot (doesn't get beyond multi-colour screen & sits with constant red pwr led & blinking green ok led) with the latest Foundation firmwares (20120714-1 or 20120801-2)
Same problem with the bootc kernel.
1) I'm guessing this is because the firmware no longer handles vmlinuz type kernels?
2) is there a workaround to this?
3) Does this scupper the idea of producing a fully debianised kernel package if this is a permanent firmware feature (assuming it is of course)?
re above post: when I ask about a workaround I mean "a workaround that will allow the use of this kernel and latest firmwares" (obviously using a Foundation kernel allows the RPI to boot)
Work on the kernel package will continue if/when someone can point me at usable* 3.2 based kernel sources for the Pi.
* by which I mean of similar stability to the foundation's 3.1 stuff.
- Moderator
