Is anyone else using geany on pisces? I installed it using the standard apt-get install geany (I made sure to refresh the package listing). It seems to work fine however the color scheme for the editor window is really broken. It uses teal and green and the font color for some syntax highlighting is the same as the background. I found some color schemes through the geany site and installed them as well, but they are also broken and do not match the description.
-kap
Geany Color Issues
I'm actually having this same issue with the new Wheezy Beta image, so maybe it's more of a general "Wheezy" thing?
dihm wrote:I'm actually having this same issue with the new Wheezy Beta image, so maybe it's more of a general "Wheezy" thing?
Could be, when I get a moment I'll install a minimal wheezy image in a vm directly from Debian and see if the issue is upstream. If it is, I'll report it.
-kap
I have the same problem on wheezy beta. You can get a marginally better colour scheme by view>editor>colour scheme>alternate.
If I run Geany via tightvnc on my windows 7 PC the background colours of the Geany editor are now white; all the other colours on the screen are unchanged from the normal display ones. Odd?
kaplanfx wrote:dihm wrote:I'm actually having this same issue with the new Wheezy Beta image, so maybe it's more of a general "Wheezy" thing?
-kap
Ok, so I checked out the official Debian Wheezy Alpha (amd64) in a VM on my Lion host. No issues for geany with that config.
-kap
I have the same problem. I downloaded and installed Geany -- the programming utility.
And, I don't know if its Wheezy related (although it was not a problem with Squeezy) the editor window is overlayd by a "blue-green transparent film. I.e. the editor window is not white.
I have tried to cure the problem by installing *.conf files in the /usr/share/geany/colorschemes directory but this does not cure the problem.
Any suggestions welcome!
All the best
Jeff
All the best
Jeff
same issue here, some character have almost the same color as the background, so its not readable at all.
Latest upgrade appears to have cured this. Last Friday was still a problem but after upgrading today automatically white background.
bbncomms wrote:Latest upgrade appears to have cured this. Last Friday was still a problem but after upgrading today automatically white background.
thanks for your post -- Upgraded too, and problem solved
All the best
Jeff
jeffhaddow wrote:bbncomms wrote:Latest upgrade appears to have cured this. Last Friday was still a problem but after upgrading today automatically white background.
Can you just confirm, this was an "apt-get upgrade" rather than a "rpi-update" ?
- Moderator
dom wrote:jeffhaddow wrote:bbncomms wrote:Latest upgrade appears to have cured this. Last Friday was still a problem but after upgrading today automatically white background.
Yes I used "sudo apt-get update && sudo apt-get upgrade" to update and this cured the problem with Geany.
All the best
Jeff
Just wanted to chime in and say it's fixed for me as well, just ran my first python prog on the pi, it's working nicely.
-kap
-kap
