Repository Hiccup?
by Jame_s » Fri Oct 19, 2012 3:26 pm
as of 2 minutes ago i'm getting this when i try to apt-get update:-
W: Failed to fetch gzip:/var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_wheezy_main_binary-armhf_Packages Hash Sum mismatch
this is a right out of the box install of raspbian downloaded today
does anybody know if this has affected all the mirrors or if its local to me (usa eastern).
thx
by plugwash » Fri Oct 19, 2012 4:06 pm
That error is reffereing not to the main raspbian repository but to the repository maintained by the Raspberry Pi Foundation for Pi specific packages.
It's possible that you caught their repository mid-update, it's also possible that it is broken. Finally it's possible it's a problem with your internet connection.
Can you try again in half an hour or so and report back.
Moderator
by Jame_s » Fri Oct 19, 2012 5:03 pm
still returning the same error. could be the repository i'm being directed to only updates daily.
by Jame_s » Fri Oct 19, 2012 8:10 pm
i just checked it again with the sources set directly to the raspbian repository and get the same results.
is this really just me?
by Jame_s » Fri Oct 19, 2012 8:32 pm
i took the raspberrypi.org source out and the update worked, looks like their repository is busted for now.
by Sander » Sat Oct 20, 2012 6:25 am
No problems here:
pi@raspberrypi ~ $ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org wheezy InRelease [12.5 kB]
Get:2 http://archive.raspberrypi.org wheezy InRelease [7,665 B]
Get:3 http://archive.raspberrypi.org wheezy/main armhf Packages [5,738 B]
Can you manually reach http://archive.raspberrypi.org/debian/ with your webbrowser?
by terl84 » Mon Nov 05, 2012 1:14 pm
I am having the exact same problem as James. In addition to getting the hash sum mismatch when trying to update packages, when I try to search for any packages with the apt-cache search command I get the following.
pi@raspberrypi ~ $ apt-cache search game
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_contrib_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
Jame_s, were you/are you having the same problem? If removing the source worked for you can you let me know how to do that?
by RaTTuS » Mon Nov 05, 2012 1:30 pm
try
sudo apt-get update && sudo apt-get upgrade
just worked for me
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by terl84 » Mon Nov 05, 2012 2:13 pm
I am having the same issue as Jame_s was originally, so when I try the sudo get-apt update I get the hash sum mismatch error. When I try sudo apt-get upgrade I get:
pi@raspberrypi ~ $ sudo apt-get upgrade
Reading package lists... Error!
pi@raspberrypi ~ $
It is a strange issue, and I have tried many times on Friday and today so I don't think I am catching them at some kind of server update unless I have the worst luck in the world.
