@meltwater
ax206term is just a terminal console. The other ported programs can be found here. The dpf-ax SVN comes with a sample lcd4linux conf file and the build script should work too. I'll be trying lcd4linux out on my R-Pi soon. lcd4linux can certainly display images and pydpf would too.
Photo keyring as screen
ax206geek wrote:@meltwater
Thanks very much! I'll have a go and see how I get on.
_________________________________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
Released at the start of each month.
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
meltwater wrote:Thanks to some help from doozan.com I now have a hacked picture frame.
http://forum.doozan.com/read.php?2,2435 ... 9#msg-8330
Hopefully that will also help you out. Happy to give more details if needed.
Now comes the small task of trying to work out how to use lcd4linux...
cud u plz give that ebay link to buy these kinda frames!!
funny wrote:meltwater wrote:Thanks to some help from doozan.com I now have a hacked picture frame.
It was posted above...
http://www.dealextreme.com/p/1-5-lcd-re ... rage-27893
Mine was from dealextreme.com, but be warned they can change stock. It works with Ax206term, yet to try the others though.
@ meltwater, ax206geek - Thanks, will check out dealextreme
This is one neat little trick. Too bad the larger photo frames tend to run off memory cards instead of direct USB transfers to internal memory. *clicks the "watch thread" button*
clickykbd wrote:Too bad the larger photo frames tend to run off memory cards instead of direct USB transfers to internal memory.
Going slightly off-topic here, but some Samsung frames - the larger frames can do these:
http://web.media.mit.edu/%7Egracewoo/stuff/picframe/
http://pyframe.blogspot.sg/2011/12/usin ... or_16.html
http://www.puschmann.net/page/?page_id=62
Nice work with the ax206term! Did anyone of you get the DPF working with lcd4linux on the RPi? I successfully flashed my DPF (it's the China Version, dx21334b). However, with the example config from dpf-ax, lcd4linux cannot find the DPF:
My guess is that the port identifier is different on the RPi, i already tried usb, or usbdev1.4 (which is the the port reported by dmesg).
Can anyone help me? I'll try the st2205term/ax206term now, already compiling...
Best,
Max.
- Code: Select all
$ ./lcd4linux -f ../dpf.conf -F
Found AX206 DPF
Got LCD dimensions: 0x0
dpf: cannot open dpf device usb0
Error initializing driver DPF: Exit!
Best,
Max.
Shame on me... of course lcd4linux needs to run with sudo. It's working now
wonder what it would take to get them to make a raspberry shaped one:
http://www.dealextreme.com/p/1-5-lcd-he ... 32?item=14
(edited to the 1.5" display heart shaped one, more raspberry approximate already)
That one is so close, a little sharpie details and some glued on leaves and you are there.
clickykbd wrote:wonder what it would take to get them to make a raspberry shaped one:
http://www.dealextreme.com/p/1-1-inch-h ... 515?item=2
nice idea!
funny, I cannot send PMs yet (started posting here today) -- I bought this display from eBay (Germany in my case, but it's an international seller):
http://www.ebay.de/itm/260978964426?ssP ... 1439.l2649
funny wrote:nice idea!
Alas, too nice/tempting. Ordered one on the off chance it's a supported model.
kontextbewusst wrote:Shame on me... of course lcd4linux needs to run with sudo. It's working now
Hello, can explain how you installed the LCD in the RPI?
You can do a How to, what I have with the Firm_21334a of Superelchi, but when compiling in Raspberry does not work. I have the same error as above you.
regards
gabychan wrote:Hello, can explain how you installed the LCD in the RPI?
regards
I can try to help. Do you have errors with compiling lcd4linux or with permissions
- Code: Select all
If it is compiling errors, just make sure the dependencies are sorted out, this is IIRC
- Code: Select all
sudo apt-get install autoconf libtool libusb-dev python2.6-dev
then build-dpf-lcd4linux.sh should execute smoothly.
The permission error was solved with sudo but lcd4linux will also complain on the permissions of dpf.conf so if this is done from lcd4linux directory inside dpf-ax directory
- Code: Select all
chmod g-r-x,o-r-x ../dpf.conf
Thank you so much
This is what I get on the console
- Code: Select all
Which drivers to compile checking ... done
configure: WARNING: dpf.h not found: DPF driver disabled
configure: error: You should activate at least one driver ...
make: *** No no target specified and no makefile found any. Alto.
@ raspberrypi ~ pi / dpf-ax $
gabychan wrote:This is what I get on the console
Try copying libdpf.so to /usr/local/lib. I've also uploaded my lcd4linux folder with compiled binary from my Pi to here
This is the error after installing the dependencies
- Code: Select all
pi@raspberrypi:~/dpf-ax$
pi@raspberrypi:~/dpf-ax$./build-dpf-lcd4linux.sh
- Code: Select all
/usr/bin/ld: cannot find -ldpf
collect2: ld returned 1 exit status
make[1]: *** [lcd4linux] Error 1
make[1]: se sale del directorio `/home/pi/dpf-ax/lcd4linux'
make: *** [all] Error 2
gabychan wrote:This is the error after installing the dependencies
- Code: Select all
Assuming libdpf.so is in /usr/local/lib, try this
- Code: Select all
ldconfig /usr/local/lib
ax206geek wrote:Assuming libdpf.so is in /usr/local/lib, try this
- Code: Select all
No I do not find on any side libdpf.so.
Sorry not to do more.
Thanks for your help
@gabychan
You were supposed to compile dpf-ax to obtain libdpf.so which is in the Debug folder of dpf-ax. Anyway here's my copy
Thanks,
My orders
My orders
- Code: Select all
# sudo rm -rf dpf-ax
# sudo svn co https://dpf-ax.svn.sourceforge.net/svnroot/dpf-ax/trunk dpf-ax
# cd dpf-ax
# sudo cp your_libdpf.so /usr/local/lib
# sudo chmod 755 dpf.conf
# sudo ./build-dpf-lcd4linux.sh
# cd lcd4linux
# sudo make
#pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo make
make all-am
make[1]: se ingresa al directorio `/home/pi/dpf-ax/lcd4linux'
pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo lcd4linux -l
lcd4linux: error while loading shared libraries: libdpf.so: cannot open shared object file: No such file or directory
pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo lcd4linux -Fvv
SOLVED
It seems that this fixed
Many thanks again
ax206geek wrote:@gabychan
Many thanks again
- Code: Select all
^Clcd4linux.c: got signal 2
lcd4linux.c: leaving main loop
DPF: shutting down.
drv_dpf.c: closing connection
pi@raspberrypi:~$
I have this photo keyring:
And want to write a image to it every x seconds, but dont know how to write to te correct sector on the chip. And dont know where to start
dmesg give me this info:
And lsusb:
Bus 001 Device 007: ID 18b6:1201 Mikkon Technology Limited
\dev\sr0 only contains a program for Windows.
- Code: Select all
[ 121.103956] usb 1-1.2: new full speed USB device number 5 using dwc_otg
[ 121.363980] usb 1-1.2: new full speed USB device number 6 using dwc_otg
[ 121.465356] usb 1-1.2: config 1 has an invalid descriptor of length 44, skipping remainder of the config
[ 121.466350] usb 1-1.2: New USB device found, idVendor=18b6, idProduct=1201
[ 121.466379] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 121.466400] usb 1-1.2: Product: MOS003-USB ALBUM
[ 121.482424] scsi0 : usb-storage 1-1.2:1.0
[ 122.485637] scsi 0:0:0:0: CD-ROM MKU007- USB PHOTO ALBUM 1.00 PQ: 0 ANSI: 2
[ 122.534992] sr0: scsi3-mmc drive: 0x/0x caddy
[ 122.535027] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 122.539917] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 122.574855] sr0: Hmm, seems the drive doesn't support multisession CD's
And lsusb:
If it can help somebody, I already launched a subject about this in august (a long time ago ^^) :
viewtopic.php?f=46&t=428
Don't know if it may help but I had the hack working on a cheap asian NAS (so ARM hardware...).
In the last answers the subject was changing to "working lcd screens".
At least it will help google
Should I link this topic in a reply of the previous topic ? [which should be closed then]
Gabriel
ps : I'm going to use the screen of a "coby dp-152 keychain digital photo frame" in this project : viewtopic.php?f=35&t=7739 and I will add pictures soon.
Gabriel
My home-made case : http://goo.gl/nprcI ; My presentation http://goo.gl/5hSar et en français : http://goo.gl/28Vif ; Please think to the FAQ and to the Wiki
