https://orjoules.wordpress.com/2011/10/ ... ar-laptop/
I decided to wait about a year before looking into it again to see if more recent advancements have been encouraging, and they are.
From what I've gathered, solar panels have already been made to power the Raspberry pi, using a 4watt panel with a 12V, 1.3amp charger here: http://raspberrypi-projects.com/categor ... ing/solar/
http://www.instructables.com/id/Solar-P ... pberry-Pi/
An HDMI to LVDS adapter has been made by Chalkboard Electronics which allows connection to various LCD screens. http://www.chalk-elec.com/?page_id=1280
Low-powered E-ink/like displays, among dual-mode ones (B&W & Color), such as Pixel Qi, have kits that connect to LVDS, such as by TinCanTools: http://tincantools.com/product.php?prod ... 256&page=1
5W solar panels by Bootstrap solar, could be mounted on the backpanel of an e-ink screen, and use a mirror, like a fresnel concentrator (can be found in one of of Apple's patent applications)
http://www.bootstrapsolar.com/collectio ... olar-panel
So far the materials are quite costly (especially the low-powered display, although an e-ink displayby Pearl would be interesting), and I'm seeing some costs/availabilities have improved since last year.
The costs so far:
Raspberry Pi: $25
HDMI to LVDS adapter: $35 from Chalkboard Electronics
Pixel Qi LCD to LVDS DIY kit: $299 from TinCanTools; works with Pandaboard, not sure about R-pi
5W Solar Panel: $31 from Bootstrap Solar
12V 7Ah Lithium Iron Phosphate Battery with BMS: $139 from K2 Energy K2B12V7EB (I'm picking this slightly oversized battery because LifePO4 batteries are superior to Lithium polymers and they will last 5-10 years like a good battery should. It can be used with future SoCs anyways. Plus, it's just a prototype, but a coordinated design could allow a flatter, more compact one as are in laptops: http://www.amazon.com/K2-K2B12V7EB-Lith ... sbs_auto_6 (the battery would need to power both the SoC plus the LVDS adapter, which outputs to the screen, so I don't know if it needs two 6V outputs or one 12V, etc, from a controller)
Lastly, a USB keyboard with a built-in touchpad for clicking and scrolling (wherever one can find one) $30-40.
Total cost for a solar laptop: $569, excluding charge controller, which Bootstrap solar sells (may have other alternatives. some solar panels have them built in when using less than a number of Amps)
I recall one forum post that said there is an LVDS adapter being worked on that works specifically for the Pixel Qi to the Rasp Pi. I will post that soon when I find it.
Lastly, the goal of this design is not just to make a solar laptop that can be run after a long enough wait in the sun, but one that can make use of the lowest power SoCs (the 5V 3.5w on the Rasp Pi is good, 2 watts for a Pixel Qi is great, but together it's 5.5 watts, which benefits from a battery that's 10Ah at minimum for all-day computing (9hrs+). Thus, we're still not quite at instant-on power-up the way amorphous silicon can charge a 4-function calculator, but that comparison is not too far from being reached. For example, within the past year, Intel demonstrated a Claremont processor that charged a Pentium x86 processor running at Near-threshold voltage, using just 2 milliwatts.
http://semiaccurate.com/2011/09/28/inte ... mpressive/
In practice, they may run at 300 milliwatts (active) to be of mainstream attractiveness. But also, more recently, ARM announced their highest efficiency ARMv8 A53 and A57 64-bit processors for use in servers, which use 500milliwatts on idle and 2 watts on load, which is great for future Raspberry Pis.
However, a B&W solar using a newer Pearl e-ink display with fast refresh could be attractive for those interested in solar netbooks under $300 (excluding the One-Laptop-Per-Child XO-3, which sells for $200-$400, thus comparable), if it has LVDS inputs and is compatible with pins and electrical. They sell for about $60 on Ebay: http://www.ebay.com/sch/Computer-Compon ... _nkw=e-ink
