Touchscreens for Raspberry Pi
73 posts   Page 3 of 3   1, 2, 3
by msmithy12 » Fri Oct 19, 2012 11:18 am
aragats wrote:The "xinput_calibrator" program is self-explaining, just run it in graphical environment from a terminal emulator (xterm, urxvt etc.) and it will ask to touch the screen at drawn crosses sequentially in 4 corners and in the center, then it will produce a textual output with simple instructions. ...
Thats the way i did it, i'd love to post a video but Im using the pi/touchscreen for a company project and uploading a youtube a vid of what im doing would get me fired.
But if you follow my previous instructions and then theres a calibrate touchscreen option in system tools or settings (sorry im away from my pi ATM)
Also someone PMd me about the screen im using and a link to it: http://www.carcomputer.co.uk/index.php?/monitors/hdmi-monitors/lilliput-669gl-70np/c/t-7-hdmi-touch-screen-monitor?keyword=669gl
its a lilliput 669gl which is 7" but im sure they do a 896gl which is 9" and they delivered in like 3days.
I assume I know what I`m talking about... I probably don`t
Home: 256mb Made in UK, Rasbmc, 40" Sony Bravia KDL-40v3000
Work: 256mb Made in China, Rasbian, 6" Lilliput touchscreen
by Mezo » Sun Oct 21, 2012 7:29 am
Touch screens are notoriously expensive, why not just buy a $10 Chinese touch screen overlay? they sell them on ebay & you just plug them in via USB,
After all like a previous poster said "its only resistive film overlay" that you can put on any old monitor.
Mezo.
by ChristianB » Mon Oct 22, 2012 1:38 am
I'm trying to follow what you did but I've got stuck at the "make then make install" part. I think you need to point it at the make file? Is it the am or the in file? Am I missing something?
by ChristianB » Mon Oct 22, 2012 6:43 am
Ok so I had been trying to do this on a raspbmc img. I got all the things I needed installed (I think) including gcc and other things. But I still don't know how to actually run xinput-calibrator from the terminal. I went back to a weezy Raspbian img and these instructions worked great. So can I take some config files from raspbian and use apt-get for installing xinput and get the touch screen working for raspbmc?
by SF4444 » Sat Oct 27, 2012 11:18 pm
I have a few 3com Audreys collecting dust in the garage and was thinking of updating one of them with the rasberry pi. The problem is if the LCD could be interfaced to it. It has a PANASONIC EDMGRB8KJF 640 x 480 color stn display with resistive touchscreen. there is a powering board for the ccft light that could be reused. Interfacing without some supporting hardware might be a problem. Data (pdf) for lcd can be found @ www.openhardware.net/Documents_Lib. Might anyone have any ideas? Thanks -SF
by cracker0501 » Sun Nov 04, 2012 10:28 am
Mezo wrote:Touch screens are notoriously expensive, why not just buy a $10 Chinese touch screen overlay? they sell them on ebay & you just plug them in via USB,
Mezo.
I would be interested in one but couldn't find any that cost less then 100$ on ebay or any other site, culd you please post a link?
by diegocarrera » Mon Nov 05, 2012 4:13 pm
Hi thutchis,
please let us know, if your touchscreen monitor works fine on raspbian??
Diego
thutchis wrote:Looks very nice. I think it must scale down 1080p to the native resolution. IMO, with a 7" screen, 1920x1080 would make everything so tiny you would need a magnifying glass to use it. I think in all of these products, finding a touchscreen driver will be the challenge. I am hoping the Touchkit Driver for Debian will work http://www.touchkit.com/drivers.htm for these cheap LCD screens. We'll see when my AliExpress touchscreen arrives.
Wolfram23 wrote:Has anyone tried this one:
http://www.ebay.com/itm/New-SAMSUNG-7-L ... 0659973152
At $140 it's a pretty good deal for a 7" touch screen, HDMI input with USB for the touch feature. I'd like an explanation on the resolution though, it says 800x480 native but somehow it can use up to 1080p? What? I'm sure that's some kind of marketing scam but they do show a screenshot of choosing the resolution and sure enough, it lists up to 1920x1080.
by kefrifd » Tue Nov 20, 2012 1:29 pm
Just thought I'd nip to this conversation. We've been doing some dev work and having some good success using the Lilliput FA1011-NP/C/T monitor for our application (interactive taxi advertising). We picked it up from:-
http://www.carcomputer.co.uk/index.php? ... ord=FA1011
Interestingly, it looks the exact same model as the below one:-
http://www.carcomputer.co.uk/index.php? ... spberry+pi
... which they also sell - and they're the same price.
Cheers,
KefrifD
by lsces » Fri Nov 30, 2012 3:26 pm
KefrifD - what are you using to talk to the touch screen. I've got a media player setup, but I suspect I'm going to need to start from a more generic kernel :(
by Rushy » Thu Dec 13, 2012 8:56 am
Bump!
by phybrgj » Thu Dec 20, 2012 2:11 pm
HI,
I've just purchased the Lilliput 10.1" touchscreen FA1012-NP/C/T. Following the above info I'm trying to install xinput-calibrator. However when I try to 'install it' by running autogen.sh I get an error saying it can't find the packages: xext or xi.
From searching on line, I've installed xinput and the x11proto-xext-dev, but they aren't being found by the pkg-config.
Has anyone else had this problem, please?
by ShawnSinister » Sun Dec 23, 2012 3:08 am
aragats wrote:Some people mentioned Lilliput monitors here. I've ordered and received one:
http://lilliputweb.net/index.php?Controller=User_Product&action=ShowProduct&product_id=41
(although mine is marked as 619AT).
HDMI video works out of the box, but with trial and errors I've found the optimal resolution 720x480 using the following settings in "config.txt":
hdmi_group=1
hdmi_mode=3
hdmi_drive=2
hdmi_ignore_edid=0xa5000080
The touchscreen "eGalax Inc. USB TouchController" works with X without special drivers (although the vendor provides ones in binary form, but only for x86/amd64). I'm running Archlinux, tried with both 3.1.9 and 3.2.27 kernels, xorg-server 1.12.4. However, it is not usable without calibration (the axes are swapped too). I've compiled "xinput_calibrator" from:
http://www.freedesktop.org/wiki/Software/xinput_calibrator
Archlinux AUR:
https://aur.archlinux.org/packages.php?ID=35031
After 2 iterations of calibration I've got the following options to store in "/etc/X11/xorg.conf.d/99-touch-calibr.conf":
Section "InputClass"
   Identifier   "calibration"
   MatchProduct   "eGalax Inc. USB TouchController"
   Option   "Calibration"   "79 4012 3895 262"
   Option   "SwapAxes"   "1"
EndSection
Thus now the touchscreen works fine. The problem remaining at the moment is the HDMI audio. Principally it works, but there are strange issues I described in the post:
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=178247#p178247
The overall impression of Lilliput HDMI touchscreen monitor is really good.
What did it cost?
by ShawnSinister » Sun Dec 23, 2012 3:12 am
Mezo.
I'm interested in the touch overlay, however I can't find one as cheap as you say. Help please?
by GamesBond » Sun Dec 23, 2012 9:32 pm
Has anyone found any touchscreens that are nicely integrated in a headrest for use in a car?
2 touch-screen HDMI monitors combined with 2 Raspberry Pi's sharing an external hard drive with UTP network interface would make a very nice car entertainment system.
by Rushy » Mon Dec 24, 2012 4:59 pm
Has anyone had any luck with a USB monitor using Displaylink on Rasbian?
by webdirector » Fri Jan 04, 2013 2:29 pm
msmithy12 wrote:You guys are amazing, thank you!
Incase anyone is on here in the future heres what i did to get my touchscreen running.
sudo apt-get install libx11-dev
sudo apt-get install libxext-dev
sudo apt-get install libxi-dev
sudo apt-get install x11proto-input-dev
if any of those fail run update and upgrade and try again
then
download http://github.com/downloads/tias/xinput_calibrator/xinput_calibrator-0.7.5.tar.gz
tar xvzf (downloaded file)
cd (downloaded file)
./configure
make
sudo make install
then
prefrances/calibrate touchscreen
Thanks this really helped me. I wanted to make the calibration more permanent but I do not have the directory you are showing .
I mean I do not have the "xorh.conf.d/99.calibration.conf" any Idea why ?
by BladeFury1789 » Sun Jan 06, 2013 2:59 am
Would a Kindle Fire work, anyone? And how?
by lokiji » Thu Jan 17, 2013 3:01 pm
guys do u think this could work with raspberry pi:
http://www.ebay.com/itm/7-0-inch-4-wire ... 43b47101fa
+ this:
http://www.ebay.com/itm/New-7-inch-4-wi ... 3a772512a3
has anyone of your tried it?
by Mechduino » Thu Jan 17, 2013 5:39 pm
I have tried similar but cannot get it to work.
Bluebian, the better Raspbian, okay maybe worse, well...definitely worse.
by advanced » Sun Jan 20, 2013 9:41 pm
Hello, I just got my 10" Capacitive touchscreen from chalktech and wrote a small tutorial about it : it seems to work fine for me!
http://pikiosk.tumblr.com/post/41042790814/capacitive-touchscreen-raspberry
PS: Maybe I did something wrong but the LCD makes an awful and annoying noise (an high-frequency whistle that changes with colors )
hints?
by bboyandru » Wed Apr 17, 2013 5:45 am
lokiji wrote:guys do u think this could work with raspberry pi:
+ this:
Hi!
I am using these parts with Raspbian(with new kernel module) and XBMC(with patches for touchscreens).
Please look at my tutorials to be able to use them:
http://www.engineering-diy.blogspot.ro/ ... lax-7.html
Andrei
http://www.engineering-diy.blogspot.com
by compidrae » Fri May 03, 2013 1:10 am
here is a confirmed working 7" touch screen with screen shots of the screen and touch screen working as well as details on how to get it all working
https://www.tindie.com/products/gotindi ... sberry-pi/
by CapCave » Mon Jun 10, 2013 11:03 am
Another way to think about it is to run a webserver on the Pi and make a decent set responsive design pages for tablets/mobile. Run the webserver to distribute the interface.
