Raspberry PI MJPEG stream to RCA (playing mjpeg stream!)
by Xapepam » Tue Feb 12, 2013 8:32 pm
Hi guys! A lot of information about streaming with raspberry pi. But no information about PLAYING mjpeg, h264 stream!
Is it possible? Im trying in firefox (iceweasel) but its no use slowwww..
My idea: use raspberry to convert mjpeg stream from camera to DVR (rca out).
Its a simply: one cam, one stream, one play stream to rca video out.
How to play mjpeg stream(link example: http://tra-lalaa=stream&main) on raspberry pi with GPU accelerated?
Thanks.
by SirLagz » Wed Feb 13, 2013 2:49 am
vlc can play a stream. direct from the source too !
e.g /dev/video0
don't know about speed though
My Blog - http://www.sirlagz.net
Visit my blog for ffmpeg Webcam streaming, Raspbian Server Edition, RaspAP Hotspot guides and more !
Home of PiParted - A custom GParted LiveCD to make installing OSes onto the SD Card easier !!
by Xapepam » Wed Feb 13, 2013 5:22 am
No. /dev/video0 - is wrong.
Camera streaming from lan.
NO Usb camera directly attached to raspberry pi!
I have trying do this with VLC. Its working! But 0-1 fps in one minute! Its awesome slowwww!
by ghans » Wed Feb 13, 2013 7:07 am
You can try omxplayer , but MJPEG is one of the many
unaccelerated codecs (currently) ... AFAIK.
ghans
by Xapepam » Wed Feb 13, 2013 8:10 am
http://www.cnx-software.com/tag/omxplayer/ - guy in this page written experimental method to plaing mjpeg files on omxplayer with mjpeg encoding.
Its works! Very fast work!
But on localy storage files.(via sdcard: sdb1/home/tra-la-la.MOV)
How Omxplayer get stream from web? Example: "omxplayer -o hdmi http://some IP/stream&mjpeg=main" - as browser? Is it possible?
by ghans » Wed Feb 13, 2013 8:37 am
Use mplayer to dump it to a named pipe , and
have omxplayer read from that.
Very neat find BTW , i wasn't aware of those experimental
omxplayer features.
ghans
by Xapepam » Wed Feb 13, 2013 9:22 am
- please take me more detail. Im noob.
by Xapepam » Wed Feb 13, 2013 10:24 am
sudo mplayer -dumpvideo rtsp://ipnumber/stream -dumpfile /home/pi/stream1.mkv
No rtsp stream.. Im tell about simply http stream. A lot of camera make this simply stream, and have a link Example: http://213.110.198.66:555/aV6NQZzB?cont ... tream=main
How this to play? (Not in browser! Is not usable, very slow on PI)
by ghans » Wed Feb 13, 2013 10:58 am
Try this :
mkfifo  /tmp/streampipe
mplayer  http://www.example.com/path?container=mjpeg&stream=main -dumpstream -dumpfile /tmp/streampipe 1>null 2>null &
omxplayer -r /tmp/streampipe
ghans
by Xapepam » Wed Feb 13, 2013 11:58 am
System answer:
mplayer: could not connect to socket
mplayer: No such file or directory
by ghans » Wed Feb 13, 2013 1:31 pm
Try this instead :
mkfifo /tmp/stream.mjpeg
wget -O /tmp/stream.mjpeg http://213.110.198.66:555/aV6NQZzB?container=mjpeg&stream=main
omxplayer -r /tmp/stream.mjpeg
I gave an example URL , you had to subsitute it for a real one !
ghans
by Xapepam » Wed Feb 13, 2013 1:42 pm
Did you execute all the commands i posted exactly
the same way ?
yes of course!
The mplayer url is a example URL ,
you have to subsitute it for a real one !
Im reading and undestand code. Also im undestand what im do. Im used working link, check before link in firefox browser on PC x86, after that im tested this link on raspberry pi..
wget -O /tmp/stream.mjpeg http://213.110.198.66:555/aV6NQZzB?cont ... tream=main
Genius!
But not work.
Wget start non stop downloading to file, but omxplayer cant view content of file..
Wait a minute! Idea!.
by ghans » Wed Feb 13, 2013 2:05 pm
Try appending
&> /dev/null &
to the wget command.
ghans
by Xapepam » Wed Feb 13, 2013 3:18 pm
ghans, this is great! Your last idea is WORKED!
Im see mjpeg stream from omxplayer!
Thank you very match!
But, Wget non-stop downloading file, and file in tmp has become bigger and bigger. How resolve this? Any idea?
P.S. Im so stupid!
Add &> /dev/null & - tadam! File in tmp = 0 kb ever! GREAT WORK! THANK YOU!
P.P.S. Guys! Who read this post for resolve mjpeg stream view. This http://www.cnx-software.com/tag/omxplayer/ - needed. Without this omxplayer dont undestand mjpeg stream!
by Xapepam » Wed Feb 13, 2013 5:16 pm
Total, step-by-step to view mjpeg stream.
Do this (here is detailed: http://www.cnx-software.com/tag/omxplayer/):
wget https://github.com/Hexxeh/rpi-update/ra ... rpi-update
chmod 755 rpi-update
sudo ./rpi-update
Add the following two lines to /boot/config.txt:
start_file=start_x.elf
fixup_file=fixup_x.elf
Install precompilled omxplayer with mjpeg support:
cd /
tar xzvf omxplayer-dist.tar.gz
cd omxplayer-dist
sudo cp * / -rf
Distr link: http://ubuntuone.com/77X6Mr23tdS2orm16tbzj4
Make this:
wget -O /tmp/stream.mjpeg 'http://213.110.198.66:555/aV6NQZzB?container=mjpeg&stream=main' &> /dev/null &
Go!
Im add in system autostart script. After im switch on raspberry last strings make automatics.
cd home
nano start_stream.sh
wget -O /tmp/stream.mjpeg 'http://some_ip:some port/aV6NQZzB?container=mjpeg&stream=main' &> /dev/null &
ctrl+O, ctrl+x
And put to rc.local
sh /home/start_stream.sh
by dom » Wed Feb 13, 2013 5:36 pm
Xapepam wrote:Total, step-by-step to view mjpeg stream.
Couple of simplifications:
Xapepam wrote:Do this (here is detailed: http://www.cnx-software.com/tag/omxplayer/):
sudo ./rpi-update
sudo apt-get update && sudo apt-get upgrade
has been updated recently, and gets firmware with MJPEG support
Xapepam wrote:Add the following two lines to /boot/config.txt:
while you need this for VP6/VP7/Theora, MPJEG support is included with default start.elf image.
Xapepam wrote:Install precompilled omxplayer with mjpeg support:
cd /
cd omxplayer-dist
sudo cp * / -rf
The previous apt-get upgrade will have updated omxplayer to a version that supports MJPEG.
Moderator
by Xapepam » Wed Feb 13, 2013 6:41 pm
Dom, thank you. All variants worked, but your little shortest and rightest :)
by Xapepam » Sun Feb 17, 2013 7:30 pm
Guys, again Im with little problem.
One stupid question: If stream will work with cgi auth, how to get it?
Example 1: wget -O /tmp/stream.mjpeg 'http://213.110.198.66:555/aV6NQZzB?container=mjpeg&stream=main' - this link work well.
Example 2: wget -O /tmp/stream.mjpeg 'http://some_IP:some_port/cgi-bin/CGIProxy.fcgi?usr=username&pwd=password&cmd=GetMJStream ' - this will not work.. :(
What command will help me in Example 2?
Thanks!
by ghans » Sun Feb 17, 2013 8:01 pm
That could be anything ... try changing the user-agent.
man wget should tell how.
Any googled Mozilla user-agent should work.
ghans
by Xapepam » Sun Feb 17, 2013 10:54 pm
Im very noob :)
But im finded solution:
curl -s -o /tmp/stream.mjpeg 'http://http://some_ip/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=username&pwd=password' &> /dev/null &
Works well! Thanks!
by Xapepam » Tue Feb 26, 2013 12:26 pm
I continue this subject..
Guys.
This works great,
wget -O /tmp/stream.mjpeg 'http://[u]SOME_IP[/u]:555/aV6NQZzB?container=mjpeg&stream=main' &> /dev/null &
but if the link isn't available to downloading any more - omxplayer totaly hangs. Screen is totaly freeze.
Im put this code to rc.local and autostart streaming every boot. But im dont know how restart streaming after link is up, without manual reboot. (If needed i agree to automatic reboot.)
I need automaticaly start stream after link is down some times without my promt or ssh coonect. Please help. Thanks!
P.S. Ok. Im use wget timeout and win in this battle. Thanks all!
by alphyddan » Sun May 12, 2013 7:44 pm
omxplayer worked fine with mjpeg streaming from a network camera. Good performance in terms of images per second but I wonder why there is a 5 seconds lag? Is there some buffer that I should reduce?
Thanks.
