New version of the Pi? (got one)
27 posts   Page 1 of 2   1, 2
by Homwer » Tue Sep 04, 2012 10:18 am
i've just got my new Raspberry Pi and it's diferent from my former one.
Is this the "new" build or version or just an upgrade?
Here is a picture
by SN » Tue Sep 04, 2012 11:35 am
nice...
mounting points too!
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
by liz » Tue Sep 04, 2012 11:42 am
Excellent - they're in the wild now!
Pete would like me to say that we are not *calling* them mounting points, because he has horrible images of people screwing stuff into them tightly and compressing the PCB until it breaks. Of course, you should feel free to *use* them as mounting points - just be judicious how much pressure you put on the surrounds.
Eben will be posting about the changes you'll be seeing on more recent boards soon. It's really good fun for us watching them arrive and confuse you guys. :)
by Ravenous » Tue Sep 04, 2012 11:45 am
If you really wanted to confuse you could have called this the Model "C" :)
"Raspberry Pi - The PC With The Hole."
by redhawk » Tue Sep 04, 2012 11:51 am
Why is P2 missing connector pins isn't this where the digital camera interface goes??
Also has the LAN overheating problem been fixed with this rev??
Richard S.
by MmmPi » Tue Sep 04, 2012 11:57 am
@redhawk P2 is jtag. There are a few pics with connectors labeled http://elinux.org/RPi_Hardware
In case anyone isn't aware: Don't order from RS / Allied if you can avoid it. Unless you like frustration that is
by meltwater » Tue Sep 04, 2012 12:04 pm
redhawk wrote:Why is P2 missing connector pins is this where the digital camera interface goes??
Richard S.
S5 is the camera CSI-2 connector. P2 is JTAG, not much use for most mortals.
The extra pin holes near P1 look interesting...am I correct in thinking we have some extra goodies from those extended pins...I2S...perhaps?
They just happen to sit where the ID resistors used to be, R3-R10 (GPIO28 to GPIO31).
The USB polyfuses also appear to be relocated/removed. And looks like new test point added by the power input, or something.
_________________________________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
Released at the start of each month.
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
by MmmPi » Tue Sep 04, 2012 12:08 pm
Liz & Eben mentioned elsewhere that the two USB port polyfuses would been removed completely. Before this rev some boards have shown up with polyfuses replaced with 0 ohm links.
by liz » Tue Sep 04, 2012 12:10 pm
MmmPi - check your PMs!
by pygmy_giant » Tue Sep 04, 2012 12:43 pm
Great - thanks for nothing! I mean it - literally - thanks for the hole. I note that this hole can be used for both security and fixing purposes.
I am pleased to see that development is on-going.
What improvements are us early adopters missing out on - what would be the advantages to us of buying another revised board?
Ostendo ignarus addo scientia.
by meltwater » Tue Sep 04, 2012 12:46 pm
pygmy_giant wrote:Great - thanks for nothing! I mean it - literally - thanks for the hole. I am pleased to see that development is on-going.
There are no improvements on perfection...
by pygmy_giant » Tue Sep 04, 2012 12:51 pm
Flattering but that does not answer my question.
From a philosophical standpoint perfection is the achievement of defined goals - so you actually can improve on perfection by better achieving those goals or achieving additional ones, which may be the case here.
Personally I prefer adequate to perfect as perfect often implies wasted effort.
So apart from the hole, what am I missing out on?
by bredman » Tue Sep 04, 2012 12:54 pm
To make you even happier, you got a double-dose of nothing. It looks like there is a second mounting hole hiding behind the USB ports.
by RaTTuS » Tue Sep 04, 2012 1:00 pm
it's not a mounting hole - just just a hole ;-p
but maybe you can put it in your pocket ?
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by meltwater » Tue Sep 04, 2012 1:02 pm
Holes are expensive you know!
"Eben will be posting about the changes you'll be seeing on more recent boards soon."
So far it looks to me that there are a few smaller changes rather than a radical redesign, which to be fair is probably less annoying to those who have Rev1 boards.
Although, the extra pin holes sure look inviting (odd pin 1 is on the other side to pin 1 of P1...). The pinholes next to the power supply look interesting too, power for the camera module maybe or test points (or bypass of the regulator - less likely).
I'm sure the quadcore cpu they've hidden under the (quad stacked 4x256Mb) 1Gb ram will please most. :mrgreen:
I also sense there is some other good news on it in general though.
by pygmy_giant » Tue Sep 04, 2012 1:07 pm
I'm going to see if I can get my first edition signed.
I note that new logos advise us not to throw our Pi's away and that there is an 'FCC' logo that actually stands for Futuristic Centi-Core (quad cores are so 2011).
by pluggy » Tue Sep 04, 2012 1:18 pm
Where the dreaded USB polyfuses used to go. C32 looks a bit lonely now as it used to sit between said polyfuses.
by meltwater » Tue Sep 04, 2012 1:20 pm
So lonely it has turned yellow (mine are black). It is worried that the hole may swallow it.
by mikerr » Tue Sep 04, 2012 1:48 pm
Surely there'll be a reduction in price now as less components are used ?
<joking of course!> :lol:
Pi count: 4 - File & print server / Wifi Webcam server, XBMC and tinkerPi !
by bredman » Tue Sep 04, 2012 1:49 pm
mikerr wrote:Surely there'll be a reduction in price now as less components are used ?
And a discount because of all the holes in the PCB.
by pygmy_giant » Tue Sep 04, 2012 1:53 pm
That reduction is cancelled out by the gilt edging.
by chickey » Tue Sep 04, 2012 2:35 pm
mmm had one delivered last saturday or at least the postie tried, will get it once i'm back off my trip. Curious if i one one of the new ones :)
by scruss » Tue Sep 04, 2012 2:38 pm
liz wrote:Pete would like me to say that we are not *calling* them mounting points, because he has horrible images of people screwing stuff into them tightly and compressing the PCB until it breaks.
One of the rather high-end network video players beloved of AV types has just such a hole, and it extends through the rather nice aluminium case. They're designed to be just mounted directly to a wall ...
by meltwater » Tue Sep 04, 2012 2:39 pm
Nail gun would do the job nicely! :mrgreen:
by jojopi » Tue Sep 04, 2012 2:53 pm
Somebody, presumably an admin, has substituted OP's original image with a slightly gimped version. So presumably we are not to talk about that particular silkscreen detail. Consequently, I shall restrict my silkscreen comments to a congratulation on fixing the "10M" problem with the lan speed led. Without wishing to sound overly pedantic, that was quite literally the most infuriating design error possible ;)
