Vending Machine
I am a web developer (use PHP,JS etc daily) and would really, really like to start making some of the hardware projects I have dreamed of. I use Ubuntu everyday on my laptop for work and would like to get deeper into Linux.
I would like to build a vending machine which:
1. Accepted coins through a coin acceptor
2. When a coin is accepted a computer displays 5 different images on 5 different computer LCD screens, randomly picked from a folder
3. If nobody puts a coin in then the displays update anyway every X minutes
I'm thinking that running a Raspberry Pi for each screen would make sense and somehow 'delivering' an image to each one from the master which is attached to a coin acceptor.
I have found a coin acceptor at Adafruit and can follow their instructions on how to connect it to an Arduino. But from there I have no clue as to how to proceed.
Any ideas, broad brush strokes, directions much, much appreciated.
Many thanks,
Gwilym
Getting started creating a video vending machine
You could connect the Arduino to the Pi (for example http://raspberrypi.stackexchange.com/qu ... an-arduino). I assume this is just for playing around and not for actual use? Cause you should know that vending machines and the likes run either some microprocessor or else a dedicated RT os on tried and tested hardware. Not a linux distribution with stuff running in the background that might break things on a board that might, but might also not, be reliable.
See you the link. There you can get an idea of what you are looking for..
https://sites.google.com/site/caribouvending/
Thanks for the replies. So I am thinking...
- I get a Raspberry Pi (my Commander) and a USB Coin acceptor
- When a coin is dropped a receive the message from the coin acceptor (I wonder if I need a driver or if anybody knows of an acceptor that would work with the RP usb/serial driver I have read about?)
- When I get the coin message I generate a random number and store it in a text file
- I have another Raspberry Pi (actually several) linked via ethernet to the first, it is polling the Commander every second and reading the stored number, when it changes it delivers a different image to the screen it is attached to via HDMI
Does that sound feasible?
@ staple
I'm also looking for a solution that will connect the Raspberry Pi to a coin acceptor, but for a different purpose of controlling usage of a internet-connected public computer.
The closest proof of concept i've come across is Nick's Advice Machine http://blog.notdot.net/2012/09/Penny-for-your-thoughts
Unfortunately, although Nick answers questions from his blog visitors, he hasnt yet provided a step by step tutorial on how its built. A plus if he does it on Instructables.
Can anyone provide a better tip on how to link-up a Raspberry Pi to a coin acceptor via its GPIO using Python?
