The relevant content of the dmseg can be seen below:
- Code: Select all
[317211.217423] wlan0: No basic rates in AssocResp. Using min supported rate instead.
[324920.877001] ieee80211 phy0: wlan0: No probe response from AP f8:d1:11:b7:de:2c after 500ms, disconnecting.
[324920.903592] cfg80211: Calling CRDA to update world regulatory domain
[324922.230940] wlan0: authenticate with f8:d1:11:b7:de:2c (try 1)
[324922.233325] wlan0: authenticated
[324922.255323] wlan0: associate with f8:d1:11:b7:de:2c (try 1)
[324922.258298] wlan0: RX ReassocResp from f8:d1:11:b7:de:2c (capab=0x431 status=0 aid=1)
[324922.258329] wlan0: associated
[324922.258354] wlan0: No basic rates in AssocResp. Using min supported rate instead.
[333926.834244] ieee80211 phy0: wlan0: No probe response from AP f8:d1:11:b7:de:2c after 500ms, disconnecting.
[333926.861008] cfg80211: Calling CRDA to update world regulatory domain
[333928.187751] wlan0: authenticate with f8:d1:11:b7:de:2c (try 1)
[333928.189840] wlan0: authenticated
[333928.212250] wlan0: associate with f8:d1:11:b7:de:2c (try 1)
[333928.215202] wlan0: RX ReassocResp from f8:d1:11:b7:de:2c (capab=0x431 status=0 aid=1)
[333928.215233] wlan0: associated
[333928.215257] wlan0: No basic rates in AssocResp. Using min supported rate instead.
[350923.916712] ieee80211 phy0: wlan0: No probe response from AP f8:d1:11:b7:de:2c after 500ms, disconnecting.
[350923.943610] cfg80211: Calling CRDA for country: RO
[350925.270226] wlan0: authenticate with f8:d1:11:b7:de:2c (try 1)
[350925.272762] wlan0: authenticated
[350925.294846] wlan0: associate with f8:d1:11:b7:de:2c (try 1)
[350925.297761] wlan0: RX ReassocResp from f8:d1:11:b7:de:2c (capab=0x431 status=0 aid=1)
[350925.297789] wlan0: associated
[350925.297813] wlan0: No basic rates in AssocResp. Using min supported rate instead.
[353674.395707] sd 0:0:0:0: Device offlined - not ready after error recovery
[353674.395875] sd 0:0:0:0: [sda] Unhandled error code
[353674.395896] sd 0:0:0:0: [sda] Result: hostbyte=0x05 driverbyte=0x00
[353674.395957] sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 05 1b 6b 17 00 00 58 00
[353674.396003] end_request: I/O error, dev sda, sector 85682967
[353674.396118] EXT4-fs (sda1): delayed block allocation failed for inode 1835027 at logical offset 154974 with max blocks 8 with error -5
[353674.417234] EXT4-fs (sda1): This should not happen!! Data will be lost
[353674.417257]
[353674.442864] usb 1-1.2.3: USB disconnect, device number 6
[353674.446956] JBD2: Detected IO errors while flushing file data on sda1-8
[353674.447058] Aborting journal on device sda1-8.
[353674.447129] JBD2: I/O error detected when updating journal superblock for sda1-8.
[353674.447584] EXT4-fs error (device sda1): ext4_journal_start_sb:327:
[353674.454916] EXT4-fs (sda1): previous I/O error to superblock detected
[353674.464242] Detected aborted journal
[353674.464328] EXT4-fs (sda1): Remounting filesystem read-only
[353674.479035] EXT4-fs error (device sda1): ext4_journal_start_sb:327: Detected aborted journal
[353674.496953] EXT4-fs (sda1): previous I/O error to superblock detected
[353674.528874] EXT4-fs (sda1): ext4_da_writepages: jbd2_start: 7762 pages, ino 1835027; err -30
[353674.693212] ------------[ cut here ]------------
[353674.693286] WARNING: at fs/buffer.c:668 __set_page_dirty+0xbc/0xd8()
[353674.693300] Modules linked in: aes_generic snd_bcm2835 snd_pcm snd_seq snd_timer snd_seq_device snd snd_page_alloc arc4 rt73usb rt2x00usb rt2x00lib mac80211 cfg80211
[353674.693422] [<c0013e1c>] (unwind_backtrace+0x0/0xf0) from [<c0028b24>] (warn_slowpath_common+0x4c/0x64)
[353674.693460] [<c0028b24>] (warn_slowpath_common+0x4c/0x64) from [<c0028b58>] (warn_slowpath_null+0x1c/0x24)
[353674.693494] [<c0028b58>] (warn_slowpath_null+0x1c/0x24) from [<c00e0810>] (__set_page_dirty+0xbc/0xd8)
[353674.693529] [<c00e0810>] (__set_page_dirty+0xbc/0xd8) from [<c00e0928>] (__set_page_dirty_buffers+0xfc/0x124)
[353674.693578] [<c00e0928>] (__set_page_dirty_buffers+0xfc/0x124) from [<c0091490>] (set_page_dirty+0x8c/0xa8)
[353674.693630] [<c0091490>] (set_page_dirty+0x8c/0xa8) from [<c00a30d0>] (unmap_vmas+0x438/0x5ec)
[353674.693666] [<c00a30d0>] (unmap_vmas+0x438/0x5ec) from [<c00a8964>] (exit_mmap+0x100/0x268)
[353674.693703] [<c00a8964>] (exit_mmap+0x100/0x268) from [<c00267b0>] (mmput+0x34/0x110)
[353674.693736] [<c00267b0>] (mmput+0x34/0x110) from [<c002aa08>] (exit_mm+0x130/0x150)
[353674.693765] [<c002aa08>] (exit_mm+0x130/0x150) from [<c002c778>] (do_exit+0x52c/0x704)
[353674.693795] [<c002c778>] (do_exit+0x52c/0x704) from [<c002cbf0>] (do_group_exit+0x3c/0xc4)
[353674.693830] [<c002cbf0>] (do_group_exit+0x3c/0xc4) from [<c0037a44>] (get_signal_to_deliver+0x158/0x56c)
[353674.693879] [<c0037a44>] (get_signal_to_deliver+0x158/0x56c) from [<c00103e4>] (do_signal+0x64/0x544)
[353674.693915] [<c00103e4>] (do_signal+0x64/0x544) from [<c0010e84>] (do_notify_resume+0x5c/0x68)
[353674.693947] [<c0010e84>] (do_notify_resume+0x5c/0x68) from [<c000d9d8>] (work_pending+0x24/0x28)
[353674.693966] ---[ end trace 67cbc78d8b934ac5 ]---
[353674.703327] EXT4-fs error (device sda1): ext4_discard_preallocations:3885: comm rtorrent: Error loading buddy information for 322
[353674.746222] EXT4-fs error (device sda1): ext4_discard_preallocations:3885: comm rtorrent: Error loading buddy information for 327
[353674.804693] usb 1-1.2.3: new high-speed USB device number 7 using dwc_otg
[353674.905899] usb 1-1.2.3: New USB device found, idVendor=152d, idProduct=2329
[353674.905933] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[353674.905951] usb 1-1.2.3: Product: USB to ATA/ATAPI Bridge
[353674.905965] usb 1-1.2.3: Manufacturer: JMicron
[353674.905977] usb 1-1.2.3: SerialNumber: 091008B20013
[353674.911306] usb-storage 1-1.2.3:1.0: Quirks match for vid 152d pid 2329: 8020
[353674.911507] scsi1 : usb-storage 1-1.2.3:1.0
[353675.946981] scsi 1:0:0:0: Direct-Access Hitachi HTS545025B9A300 PQ: 0 ANSI: 2 CCS
[353676.022137] sd 1:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[353676.023227] sd 1:0:0:0: [sdb] Write Protect is off
[353676.023258] sd 1:0:0:0: [sdb] Mode Sense: 34 00 00 00
[353676.025294] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[353676.056798] sdb: sdb1
[353676.060620] sd 1:0:0:0: [sdb] Attached SCSI disk
[353846.167907] EXT4-fs error (device sda1): ext4_find_entry:935: inode #1835009: comm rtorrent: reading directory lblock 0
[353887.571953] EXT4-fs (sdb1): recovery complete
[353887.573403] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[354001.908736] Buffer I/O error on device sda1, logical block 10622049
[354001.908761] lost page write due to I/O error on sda1
[354177.488549] Buffer I/O error on device sda1, logical block 10710374
[354177.488575] lost page write due to I/O error on sda1
[354177.488640] Buffer I/O error on device sda1, logical block 10710606
[354177.488656] lost page write due to I/O error on sda1
[354177.488702] Buffer I/O error on device sda1, logical block 10710710
[354177.488718] lost page write due to I/O error on sda1
[354187.028834] Buffer I/O error on device sda1, logical block 10708262
[354187.028860] lost page write due to I/O error on sda1
[354204.795591] Buffer I/O error on device sda1, logical block 10712670
[354204.795618] lost page write due to I/O error on sda1
[354488.398835] sd 1:0:0:0: Device offlined - not ready after error recovery
[354488.398896] sd 1:0:0:0: [sdb] Unhandled error code
[354488.398910] sd 1:0:0:0: [sdb] Result: hostbyte=0x05 driverbyte=0x00
[354488.398931] sd 1:0:0:0: [sdb] CDB: cdb[0]=0x2a: 2a 00 05 15 a6 3f 00 00 10 00
[354488.398973] end_request: I/O error, dev sdb, sector 85304895
[354488.399070] Buffer I/O error on device sdb1, logical block 10663104
[354488.399104] Buffer I/O error on device sdb1, logical block 10663105
[354488.399131] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 441188352 size 8192 starting block 10663113)
[354488.399183] sd 1:0:0:0: rejecting I/O to offline device
[354488.399205] sd 1:0:0:0: [sdb] killing request
[354488.399243] sd 1:0:0:0: rejecting I/O to offline device
[354488.399271] Buffer I/O error on device sdb1, logical block 10663715
[354488.399293] Buffer I/O error on device sdb1, logical block 10663716
[354488.399312] Buffer I/O error on device sdb1, logical block 10663717
[354488.399329] Buffer I/O error on device sdb1, logical block 10663718
[354488.399353] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 443691008 size 16384 starting block 10663726)
[354488.399388] sd 1:0:0:0: rejecting I/O to offline device
[354488.399411] Buffer I/O error on device sdb1, logical block 10663767
[354488.399431] Buffer I/O error on device sdb1, logical block 10663768
[354488.399450] Buffer I/O error on device sdb1, logical block 10663769
[354488.399468] Buffer I/O error on device sdb1, logical block 10663770
[354488.399487] Buffer I/O error on device sdb1, logical block 10663771
[354488.399505] Buffer I/O error on device sdb1, logical block 10663772
[354488.399522] Buffer I/O error on device sdb1, logical block 10663773
[354488.399540] Buffer I/O error on device sdb1, logical block 10663774
[354488.399557] Buffer I/O error on device sdb1, logical block 10663775
[354488.399574] Buffer I/O error on device sdb1, logical block 10663776
[354488.399592] Buffer I/O error on device sdb1, logical block 10663777
[354488.399610] Buffer I/O error on device sdb1, logical block 10663778
[354488.399628] Buffer I/O error on device sdb1, logical block 10663779
[354488.399646] Buffer I/O error on device sdb1, logical block 10663780
[354488.399669] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 443904000 size 57344 starting block 10663788)
[354488.399699] sd 1:0:0:0: rejecting I/O to offline device
[354488.399723] Buffer I/O error on device sdb1, logical block 10663971
[354488.399744] Buffer I/O error on device sdb1, logical block 10663972
[354488.399767] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 444739584 size 8192 starting block 10663980)
[354488.399796] sd 1:0:0:0: rejecting I/O to offline device
[354488.399821] Buffer I/O error on device sdb1, logical block 10664403
[354488.399842] Buffer I/O error on device sdb1, logical block 10664404
[354488.399861] Buffer I/O error on device sdb1, logical block 10664405
[354488.399879] Buffer I/O error on device sdb1, logical block 10664406
[354488.399897] Buffer I/O error on device sdb1, logical block 10664407
[354488.399914] Buffer I/O error on device sdb1, logical block 10664408
[354488.399932] Buffer I/O error on device sdb1, logical block 10664409
[354488.399950] Buffer I/O error on device sdb1, logical block 10664410
[354488.399967] Buffer I/O error on device sdb1, logical block 10664411
[354488.399986] Buffer I/O error on device sdb1, logical block 10664412
[354488.400004] Buffer I/O error on device sdb1, logical block 10664413
[354488.400021] Buffer I/O error on device sdb1, logical block 10664414
[354488.400039] Buffer I/O error on device sdb1, logical block 10664415
[354488.400056] Buffer I/O error on device sdb1, logical block 10664416
[354488.400073] Buffer I/O error on device sdb1, logical block 10664417
[354488.400090] Buffer I/O error on device sdb1, logical block 10664418
[354488.400108] Buffer I/O error on device sdb1, logical block 10664419
[354488.400125] Buffer I/O error on device sdb1, logical block 10664420
[354488.400143] Buffer I/O error on device sdb1, logical block 10664421
[354488.400161] Buffer I/O error on device sdb1, logical block 10664422
[354488.400179] Buffer I/O error on device sdb1, logical block 10664423
[354488.400196] Buffer I/O error on device sdb1, logical block 10664424
[354488.400214] Buffer I/O error on device sdb1, logical block 10664425
[354488.400232] Buffer I/O error on device sdb1, logical block 10664426
[354488.400250] Buffer I/O error on device sdb1, logical block 10664427
[354488.400267] Buffer I/O error on device sdb1, logical block 10664428
[354488.400284] Buffer I/O error on device sdb1, logical block 10664429
[354488.400301] Buffer I/O error on device sdb1, logical block 10664430
[354488.400318] Buffer I/O error on device sdb1, logical block 10664431
[354488.400335] Buffer I/O error on device sdb1, logical block 10664432
[354488.400358] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 446509056 size 126976 starting block 10664440)
[354488.400389] sd 1:0:0:0: rejecting I/O to offline device
[354488.400412] Buffer I/O error on device sdb1, logical block 10664433
[354488.400432] Buffer I/O error on device sdb1, logical block 10664434
[354488.400451] Buffer I/O error on device sdb1, logical block 10664435
[354488.400468] Buffer I/O error on device sdb1, logical block 10664436
[354488.400487] Buffer I/O error on device sdb1, logical block 10664437
[354488.400504] Buffer I/O error on device sdb1, logical block 10664438
[354488.400522] Buffer I/O error on device sdb1, logical block 10664439
[354488.400539] Buffer I/O error on device sdb1, logical block 10664440
[354488.400556] Buffer I/O error on device sdb1, logical block 10664441
[354488.400573] Buffer I/O error on device sdb1, logical block 10664442
[354488.400591] Buffer I/O error on device sdb1, logical block 10664443
[354488.400610] Buffer I/O error on device sdb1, logical block 10664444
[354488.400627] Buffer I/O error on device sdb1, logical block 10664445
[354488.400644] Buffer I/O error on device sdb1, logical block 10664446
[354488.400667] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 446631936 size 57344 starting block 10664454)
[354488.400697] sd 1:0:0:0: rejecting I/O to offline device
[354488.400721] Buffer I/O error on device sdb1, logical block 10665470
[354488.400741] Buffer I/O error on device sdb1, logical block 10665471
[354488.400759] Buffer I/O error on device sdb1, logical block 10665472
[354488.400776] Buffer I/O error on device sdb1, logical block 10665473
[354488.400793] Buffer I/O error on device sdb1, logical block 10665474
[354488.400810] Buffer I/O error on device sdb1, logical block 10665475
[354488.400827] Buffer I/O error on device sdb1, logical block 10665476
[354488.400843] Buffer I/O error on device sdb1, logical block 10665477
[354488.400862] Buffer I/O error on device sdb1, logical block 10665478
[354488.400879] Buffer I/O error on device sdb1, logical block 10665479
[354488.400896] Buffer I/O error on device sdb1, logical block 10665480
[354488.400912] Buffer I/O error on device sdb1, logical block 10665481
[354488.400930] Buffer I/O error on device sdb1, logical block 10665482
[354488.400947] Buffer I/O error on device sdb1, logical block 10665483
[354488.400965] Buffer I/O error on device sdb1, logical block 10665484
[354488.400983] Buffer I/O error on device sdb1, logical block 10665485
[354488.401005] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 450879488 size 65536 starting block 10665493)
[354488.401035] sd 1:0:0:0: rejecting I/O to offline device
[354488.401058] Buffer I/O error on device sdb1, logical block 10665549
[354488.401077] Buffer I/O error on device sdb1, logical block 10665550
[354488.401095] Buffer I/O error on device sdb1, logical block 10665551
[354488.401113] Buffer I/O error on device sdb1, logical block 10665552
[354488.401130] Buffer I/O error on device sdb1, logical block 10665553
[354488.401147] Buffer I/O error on device sdb1, logical block 10665554
[354488.401164] Buffer I/O error on device sdb1, logical block 10665555
[354488.401181] Buffer I/O error on device sdb1, logical block 10665556
[354488.401197] Buffer I/O error on device sdb1, logical block 10665557
[354488.401214] Buffer I/O error on device sdb1, logical block 10665558
[354488.401232] Buffer I/O error on device sdb1, logical block 10665559
[354488.401250] Buffer I/O error on device sdb1, logical block 10665560
[354488.401267] Buffer I/O error on device sdb1, logical block 10665561
[354488.401284] Buffer I/O error on device sdb1, logical block 10665562
[354488.401306] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 451203072 size 57344 starting block 10665570)
[354488.401335] sd 1:0:0:0: rejecting I/O to offline device
[354488.401385] sd 1:0:0:0: rejecting I/O to offline device
[354488.401429] sd 1:0:0:0: rejecting I/O to offline device
[354488.401512] EXT4-fs (sdb1): delayed block allocation failed for inode 1835027 at logical offset 110354 with max blocks 3 with error -5
[354488.423185] sd 1:0:0:0: [sdb] Unhandled error code
[354488.423217] sd 1:0:0:0: [sdb] Result: hostbyte=0x01 driverbyte=0x00
[354488.423242] sd 1:0:0:0: [sdb] CDB: cdb[0]=0x2a: 2a 00 05 15 ab 27 00 00 30 00
[354488.423289] end_request: I/O error, dev sdb, sector 85306151
[354488.423318] Buffer I/O error on device sdb1, logical block 10663261
[354488.423350] Buffer I/O error on device sdb1, logical block 10663262
[354488.423370] Buffer I/O error on device sdb1, logical block 10663263
[354488.423388] Buffer I/O error on device sdb1, logical block 10663264
[354488.423405] Buffer I/O error on device sdb1, logical block 10663265
[354488.423423] Buffer I/O error on device sdb1, logical block 10663266
[354488.423450] EXT4-fs warning (device sdb1): ext4_end_bio:251: I/O error writing to inode 1835027 (offset 441831424 size 24576 starting block 10663274)
[354488.425266] sd 1:0:0:0: rejecting I/O to offline device
[354488.426259] EXT4-fs (sdb1): This should not happen!! Data will be lost
[354488.426273]
[354488.454438] usb 1-1.2.3: USB disconnect, device number 7
[354488.462476] JBD2: Detected IO errors while flushing file data on sdb1-8
[354488.462582] Aborting journal on device sdb1-8.
[354488.462653] JBD2: I/O error detected when updating journal superblock for sdb1-8.
[354488.464254] EXT4-fs error (device sdb1): ext4_journal_start_sb:327:
[354488.474046] EXT4-fs (sdb1): previous I/O error to superblock detected
[354488.483831] Detected aborted journal
[354488.483872] EXT4-fs (sdb1): Remounting filesystem read-only
[354488.499699] EXT4-fs error (device sdb1): ext4_journal_start_sb:327: Detected aborted journal
[354488.519903] EXT4-fs (sdb1): previous I/O error to superblock detected
[354488.520283] EXT4-fs (sdb1): ext4_da_writepages: jbd2_start: 8051 pages, ino 1835027; err -30
[354488.797635] usb 1-1.2.3: new high-speed USB device number 8 using dwc_otg
[354488.899442] usb 1-1.2.3: New USB device found, idVendor=152d, idProduct=2329
[354488.899504] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[354488.899568] usb 1-1.2.3: Product: USB to ATA/ATAPI Bridge
[354488.899586] usb 1-1.2.3: Manufacturer: JMicron
[354488.899599] usb 1-1.2.3: SerialNumber: 091008B20013
[354488.906771] usb-storage 1-1.2.3:1.0: Quirks match for vid 152d pid 2329: 8020
[354488.909995] scsi2 : usb-storage 1-1.2.3:1.0
[354489.950091] scsi 2:0:0:0: Direct-Access Hitachi HTS545025B9A300 PQ: 0 ANSI: 2 CCS
[354490.026625] sd 2:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[354490.028119] sd 2:0:0:0: [sdc] Write Protect is off
[354490.028154] sd 2:0:0:0: [sdc] Mode Sense: 34 00 00 00
[354490.028954] sd 2:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[354490.057662] sdc: sdc1
[354490.061486] sd 2:0:0:0: [sdc] Attached SCSI disk
I know that there were/are several USB related issues, but i wonder why this did not manifest when I was using NTFS and if the USB issues are indeed linked to this behavior.
pi@raspberrypi /media/LG_EXT_HDD/torrent $ uname -a
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
