http://www.youtube.com/watch?v=zPGt2EmQ ... e=youtu.be
The converter is made from plexiglass and the switch is cutting the CEC/DDC ground pin
so no power consumption when it's off. I am waiting for the supercap to install it in the converter.
Chris1975 wrote:I have everything working except the sound. Anyone care to help? Thanks in advance
sudo nano /boot/config.txt
hdmi_drive=2sudo modprobe snd_bcm2835
sudo amixer cset numid=3 0Mr Floppy wrote:Just got delivery of the English/Hebrew version of the dock ...
Mr Floppy wrote:Just got delivery of the English/Hebrew version of the dock. Only problem is that it is in the US still awaiting forwarding. Can't wait to join the ranks here.
Has anyone created a wiki on this? Can't seem to find one at eLinux.
Chris1975 wrote:USB wire color codes in case someone might need it.
FlipBumWalla wrote:Did you get your dock from Ben's Outlet?
How long do you think it will take to get it?
terrycarlin wrote:I have run into a problem when trying to back power the rpi from the dock. I get low voltage between tp1 and tp2. Down around 4.1v. I run into the typical problems of low voltage like repeating keys. When I power the rpi from a PSU, the voltages come up to 4.8 or so and things work fine. There is nothing on the rpi usb buss except the connection to the dock. I am wondering if my usb cable is giving me heartburn. It is a 12" male A to male A. I have an adapter to convert from the dock to the male A.
o19 wrote:Hey,
I'm on my way copying this great idea, but I've some trouble with the keyboard. I've built myself a nice y-cable for powering and keyboard as described in various places around here. Power works fine and I get a screen over HDMI. However, I can not get my Pi to react on any keyboard input.
I opened the lapdock and checked the connectivity between the 30-pin connector inside and my custom usb-a end and that seems to be fine. Pin 23 goes to D+ and pin 22 to D-, both showing 0.6 ohm.
I did not dare to check voltage or current on the board or the dock, since I've never worked with electronics before. What's the things that you'd check next? Either on the software or the electronics side? I thought about asking the guys at work to use an oscilloscope to monitor the output on the data lines, when a key is pressed to make sure the lapdock is working properly (and just because I always wanted to use one of those for something non-educational), but then I've already bothered them a lot...
Any other suggestions? Maybe someone with a similar problem...
Looking forward to hearing back from you guys...
o19 wrote:Okay, thanks for the suggestions. I won't be able to check anything before Monday, but now I have at least a few things to try. Backpowering is not an option for me, since I have one of the older boards. At least not at this point in time, with some of the other options still present.
What do I need to do to power the Pi from something other than the dock? I think I still might have to do something with the Vbus of the the micro-usb on the dock or can I just leave it disconnected?
