Hi, does the real Raspberry PI work with KVM acceleration?
My question is still, if we can make power of simulation 70 % :-)
near to original.
I got boottime until now with small 50MB XP in Ram with Internet at about
30 sec. Moorhuhn is playable.
There exists Android Phones, which always work on Qemu for Arm.
A slightly modified Linux 2.6.27 and 2.6.29 kernel runs on a KVM patched kernel compiled for ARMv6 and ARMv7.
There can be done much more, when you get real Raspi,
Dietmar
KVM on ARM
My understanding was that the KVM stuff for Arm was very much work-in-progress and targetted at the Cortex-A-something chips, which have a bunch of virtualisation stuff built in. I'd be happy to hear otherwise, though.
Simon
Simon
"QEMU can make use of KVM when running a target architecture that is the same as the host architecture..."
Ok, this is not what I wish :-)
Dietmar
Dietmar
KVM ARM will only work for ARMv7a processors with virtualization extensions.
If you still want to virtualize Raspberry Pi then I would suggest to use Xvisor ARM. It supports following set of ARM processors currently:
- ARM9 (Boards: VersatilePB)
- Cortex-A8 (Boards: Realview-PB-A8)
- OMAP3 (Boards: BeagleBoard-xM)
- Cortex-A9 (UP) (Boards: Vexpress-A9)
- Cortex-A15 (UP) Without VE (Boards: Vexpress-A15)
- Cortex-A15 (UP) With VE (Boards: Vexpress-A15)
Xvisor ARM works even without virtualization extensions. For using it on Raspberry Pi would require to add board support for Raspberry Pi in Xvisor ARM.
For more details visit:
http://brainfault.blogspot.in/
https://github.com/xvisor/xvisor/wiki
Regards,
Anup patel
Regards,
Anup patel
