Has anyone tried to buy/make a usb cable with an integrated on/off switch?
I've found this : http://coolpc.com/Coolerguys-USB-OnOff- ... VRZPAM.htm but trying to get it delivered to the UK is proving a problem.
Does anyone know of a UK supplier of such a cable (it would save having to unplugging the usb power cable out all the time)?
usb cable with on-off switch
I would love one with an IR switch and remote, so I can reboot raspberry from a remote control. If anybody spots one please post.
simple solution to both your problems....
http://www.google.co.uk/products/catalo ... MUBEPICMAA
And use them to control your Fairy Lights at Christmas Time
Currently £14.99 at Asda, but a different make/model (badged as "STATUS"). I got 2 sets when they were on offer at a fiver a box of three with remote for 4 units. If they ever drop to that silly price again I`m having 2 more. Gave my brother 2 of the units and the spare remote so I use all four with one remote now. Fantastic idea they are and my RPi works off onr of them. They are worth £14.99 of anyones money, I`m just a cheapskate waiting for the fiver offer again.
EDIT: EBay has the same model as mine listed right down to £9.99
Steve
Steve
Thanks all. I had looked at these in various stores recently but the ones I saw were all RF not IR. I prefer IR as I have line of sight to the socket and can program it on an existing remote.
However following your links I found this which is much better for my purposes.
http://www.cable-universe.co.uk/5-gang- ... ntrol.html
Available from many sources, will order later today.
Darn I do like this one - another £20 to squeeze past the financial controller....
That's a really good idea. If you know how to solder or know someone who can, building one would be pretty trivial.
I just received my extension cable from eBay to butcher.
http://www.ebay.com.au/itm/Micro-usb-mi ... 4ab9496344
I will let you know how it goes
I've made one of these just this minute from an old USB iPAQ Hotsync/Charging Cable I found in the loft with a switch that changes between data and charging. I've just cut the end off and replaced it with a Micro USB one.
There are 5 wires inside, I've cut off the 3 that relate to "hotsync" and just used the red and black ones for the power. So when I switch it to hotsync the Pi turns off
I've just bodged it together for now so it's about 3 meters long lol, but I intend to cut it down to a shorter length and tidy up the join at some point. It's quality because it just happens to have a red led on it when it's off (in hotsync) and a green one on it when it's on (in charging)
Works really well using an old 5v 1A USB mains plug that I got with my HTC Touch Pro 2
