PI Heatsinks Wanted.
Any heatsink for any chip wanted. Preferably easy to fit (thermal pads), Also it must fit into an adverage size case. Thanks
RPI Model b.
HDMI
Ethernet.
Powered 4 USB port.
23" Monitor.
Keyboard & Mouse.
Wheezy (mainly used).
HDMI
Ethernet.
Powered 4 USB port.
23" Monitor.
Keyboard & Mouse.
any RAM chips ones will do - why are you sure you need them ?
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
I have a heat sink that I salvaged from a PC. It will need cutting into smaller pieces, and thermal pads. Don't tknow what case you are looking at, but the sink is 12mm high so would stand the same height as the top of the LAN socket.
G
G
christianwls wrote:Any heatsink for any chip wanted. Preferably easy to fit (thermal pads), Also it must fit into an adverage size case. Thanks
I picked up a package fo these:
http://www.newegg.ca/Product/Product.as ... 6835708012
But they have been discontinued
Also any kit that is designed to fit Video card memory chips work perfectly such as the zerotherm zh100.
Bit late -
I bought these - 8 peices for $2.40
They are only slightly bigger than the CPU and looks perfect installed
Aluminum Cooler Heat Sink Chipset for RAM Memory - W Type
Need accessories?
Checkout my verified list of cheap DX.com accessories.
http://furyfi.re/raspberrypi/accessories.pdf
