Hello all,
A few days ago I received my Raspberry Pi and I am quite happy with it, I only have one question.
When I try to connect the Raspberry to my (quite old) TV using Composite there are no colors on the screen, just black and white. All my other devices that I connect with Composite (gamecube, PSX, N64 etc.) do have color. On another (newer) TV Composite does work with the same cable, so I know the problem is probably on the TV's end.
The TV is a Sony KV-14M1D and is +/- 10 years old.
Is there anything that I can do to fix this? I would like the TV to use in some sort of Mame machine because of the classic looks.
Edit:
Almost forgot, the sides of the output image fall off the monitor. Maybe because Its 4:3?
Composite does only show black and white/no colors
Composite output defaults to NTSC. Most TVs will accept either PAL or NTSC. Older ones may not, but the usual failure mode is displaying monochrome.
Try:
sdtvmode=2
Look here for more info: http://elinux.org/RPi_config.txt
You can also try adding overscan_left=32 (and right,top,bottom) to create larger borders around image to handle overscan.
Try:
sdtvmode=2
- Moderator
I can"t answer the question about black and white, but the cut off image is due to overscan.
You can fix this by using http://elinux.org/RPi_config.txt
Editing config.txt can be done from the Pi or from a Windows/Linux/Mac x86 computer.
From the Pi:
From a computer:
Another thing to add-
For reading text, it might be a bit fuzzy and tiny on a larger screen. Something you may want to consider is doubling the pixel size with
overscan_bottom= overscan_top= overscan_left= overscan_right=
From the Pi:
- Open up a terminal
- Type "sudo nano /boot/config.txt" (no quotes)
- Add the lines about overscan to the document
- Hit Control-X, then hit the y key
- Reboot
From a computer:
- Insert img"d SD card in your non-Pi computer
- Open up the FAT partition in your computer"s file manager (Windows Explorer, Finder, etc.) On Windows and Mac, this should be the only viewable partition.
- Create a new file called "config.txt" and add the lines about overscan
- Eject the card
- Insert in Pi and reboot
framebuffer_width=320
framebuffer_height=240
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
Thanks dom, (edit: and Jeremy F, saw you reply after i reloaded
The overscan fix worked, but the switch to PAL did not. Any other possible fixes?
possibly a silly question, but in the VIDEO menu on the TV, is the COLOR adjustment set at midrange?
EDIT- nevermind, you said the other devices do show color.
Just for fun, try sdtv_mode=3
I have no idea, tbh.
Solved by using sdtv_mode=2
Dom: I copy/pasted your solution but you missed the underscore ;-p Thanks though, my Pi is running great
Mame Machine here I come
JeremyF wrote:Another thing to add-
I was looking to sort out another problem, and found this comment of yours useful for working with my old Sylvania 20" TV. Cutting down to half-standard resolution made things more readable, but didn't give much room for the text, so I went to a "three quarters" setting of 480x360 and it now looks wonderful!
I sometimes ride my Pi to the Forum.
Robert_M wrote:JeremyF wrote:Another thing to add-
Thanks, always happy to help.
