Received my real Pi yesterday & loaded the Debian image. Boots OK but when connected to a Sony 32" TV (1366x768 but I would have to take the TV off the wall to find the model number) the picture is much smaller than the screen (say 15% smaller all the way round). The TV reports the correct signal at 1366x768 @ 60Hz. I also compiled and loaded the 30/04 build of OpenElec & put it onto another SD card - the display from OpenElec is OK and fills the screen.
On another subject, my Pi does not work with a Microsoft wireless keyboard 800 (which was the spare unit I had lying around). With this keyboard it either does not register key presses or registers random ones - it was so bad that I could not log in then the unit crashed while filling the screen with the letter "p" as I tried to type "pi". The Pi does work fine with a Globlink GKM-700 wireless keyboard (http://globlink.en.ecplaza.net.....06172.html). The Microsoft keyboard works OK with other PCs.
I am an experienced Linux user and system administrator but have not had time to investigate either issue properly yet.
Has anybody else had similar issues on a real Pi?
Display and keyboard issues (on a real Pi)
Sorry – I meant to post this in the Debian section - that was where I was reading when I started the post. Please move the post.
create a file /boot/config.txt containing:
disable_overscan=1
The keyboard uses too much current to be directly connected to Pi. Use a powered USB hub or a different keyboard.
disable_overscan=1
- Moderator
dom said:
I suspect it's more likely to be the wireless dongle than the keyboard that's pulling too much juice. That or some other USB peripheral. The hint is in the name.
Alun - are you using the same dongle between the two keyboards?
Thanks for the replies - each keyboard has its own dongle. I suspected it may be a power issue but the Microsoft dongle has 5V 50mA written on it which should be OK. The unit that works is a multimedia keyboard designed to be used across a room so I suspect may take more power - the dongle is about 20x the physical size of the Microsoft unit but does not have anything written on it.
I'll try the overscan bit & report back.
The overscan bit worked great thanks dom.
For anyone unfamiliar with Linux the file can be created from the command line by:
sudo nano /boot/config.txt
Unless you have set a root password the default appears to be blank therefore it should just work. Instructions on setting a root password are here:
After wrestling with the search "feature" of this forum I have found a number of other references to the same problem with a Microsoft Wireless Keyboard 800.
It appears not to work so until I get time to investigate why I'll use in on my Linux Mint 12 machine and use the Globlink keyboard for the Pi.
I have a logitech Illuminated keyboard it's rated 5v and 300mA.
I also use a 5v 750mA power source for my Pi.
The pi senses the key strokes, but will often hold the last hitted key down, so it seems to be a problem with this keyboard, even though I have turned the lights off.
300mA is your problem – way over the raspi usb limit
SN said:
Thought so, brought a basic keyboard still rated 100mA but works with no issues
Another problem, the pi does'nt seem to understand my monitor. It worked great at my Sony 40" tv with hdmi cable. Now I bought a hdmi to dvi adapter for my benq monitor, first of all I got all these green dots all over the screen where the text appears. Then when I manage to go inte Xwin I can really see that the pi did'nt understand my monitor settings. The graphical desktop is much smaller than It should be.
Any suggestions?
Any suggestions?
Please read the following post:
http://www.raspberrypi.org/for.....corruption
Also, have a look about for overscan / underscan etc in the forums. The screen being smaller than expected has been done to death ;P . It is intentional, and it is adjustable to output to how you'd expect it to be. config.txt is your friend.
Should be the same problem you are having. I'll not rewrite the solution as it's always better to not start a game of Chinese whispers*.
*of course, no disrespect intended
thanks alot!!
This solved it:
config_hdmi_boost=4
disable_overscan=1
This solved it:
config_hdmi_boost=4
disable_overscan=1
Hello All,
I am running debian6-19-04-2012 on a SanDisk 4GB SDHC 30MB/s.
I also had trouble with a Microsoft Wireless 800 keyboard, even when the dongle was connected to a powered hub. It either missed keystrokes or repeated them. I guess that the repeats are due to the driver not seing a 'key released' message.
A Dell SK-8115 keyboard (borrowed from work) works fine, whether in the hub or by direct connection. It is rated at 100 mA but may well draw less.
A PC World esssentials keyboard always causes a kernel panic as soon as it is connected to the hub. It is rated at 50 mA. The keyboard works fine on a Toshiba WinXP laptop.
I guess that there may be a keyboard driver problem.
My monitor is a Toshiba LT22A350 monitor/TV connected on HDMI. It runs at its native 1920x1080p 60 Hz in text mode at startup. LXDE shows the resolution to 1824x984 (as reported by LXRandR 0.1.1), although the monitor is still seeing 1092x1080p 60 Hz. The fonts do appear to be slightly re-sampled so I am not sure if all is quite correct. I see that there is a beginner's FAQ on this, so I'll look into the issue.
Win32 disk imager failed to see the SD card when it was mounted in the built-in slot in my oldish Tosh XP sp3 laptop. I tried flashnul-1rc1, it saw the SD card and reported success at transferring the debian image. But the R-Pi didn't do anything - the SD card image was faulty.
However, Win32 disk imager worked correctly on a Win7-64 laptop.
At present my Pi is running at TP1-TP2 = 4.57 V, powered from a Cerulian N10JB 4-port USB hub with a 5V 2A rated PSU, with LDXE running but idle. The input to the hub is 5.16V. The hub drops this to 4.82 V on its USB A sockets via a diode. The hub-to-Pi micro USB cable and polyfuse drop the remaining 0.25V.
I tried another micro USB cable. The Pi seemed fine but TP1-TP2 was just 3.8 V. This cable is marked 28AWG but the resistance on the 5V line is about 5 ohms!. No wonder my phone was taking a while to charge.
I have compiled and run a canonical 'Hello.c' on the Pi. That is about the extent of my Linux knowledge.
Have fun, all.
Richard
Have fun, all.
Richard
