Ethernet 10M only [solved]
by KevinM » Sat May 05, 2012 7:48 pm
The problem is in the title - my Pi will only connect at 10M to the ethernet switch - all other devices connect at 100M or 1000M as expected. I cannot find a way to force the network link speed on Arch. Not a big issue for me but one I would like to fix if possible. Any suggestions...
by mahjongg » Sat May 05, 2012 9:18 pm
Try another distro (debian) to see it is software (distro) related.
Moderator
by KevinM » Sun May 06, 2012 7:12 am
Ok - good suggestion. Does the Debian startup without a keyboard and with SSH access enabled? I"m using the Arch distro headless and with no keyboard or mouse.
I"ll try it and see.
by KevinM » Sun May 06, 2012 8:17 am
Ok - problem solved I think...
Its the same on Debian 6 so hardware issue.
Re-label orange 10M led to 100M :)
Is this right?
by mahjongg » Sun May 06, 2012 3:47 pm
Well, maybe you have discovered something, I was thinking you could detect the connection speed somehow, but if you are only looking at the LED then yes, it being on probably means 100M, the schematic (sheet 3 G8) describes D9 as "yellow", and is labeled "100M", not 10M.
it might also be possible to program the chip to either go on or off for 100M, so it might be a software issue.
A reading of the datasheet of the LAN9512 chip might clarify this.
Maybe you should open a new thread about this issue.
Moderator
by nick.mccloud » Sun May 06, 2012 4:10 pm
For what it's worth, my 100M network has the Pi with it's 10M light on and I've used Debian & Arch on it thus far.
by dom » Sun May 06, 2012 4:19 pm
@KevimM Can you check the dmesg log? I get:
smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Do you?
Also can you run iperf or similar to see what the actual speed is?
Moderator
by jamesh » Sun May 06, 2012 4:48 pm
Just out of interest I ran iperf betwen the Raspi and my Ubuntu box, and got these figures as something for people to compare against.
Client connecting to 192.168.1.13, TCP port 5001
TCP window size: 16.0 KByte (default)
[ 3] local 192.168.1.6 port 56756 connected with 192.168.1.13 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 91.0 MBytes 76.3 Mbits/sec
Moderator
by dom » Sun May 06, 2012 5:16 pm
My numbers (connecting to windows 7 machine)
pi@raspberrypi:~$ iperf -i2 -c 192.168.4.9
Client connecting to 192.168.4.9, TCP port 5001
[ 3] local 192.168.4.40 port 36334 connected with 192.168.4.9 port 5001
[ 3] 0.0- 2.0 sec 21.5 MBytes 90.3 Mbits/sec
[ 3] 2.0- 4.0 sec 21.6 MBytes 90.4 Mbits/sec
[ 3] 4.0- 6.0 sec 21.6 MBytes 90.4 Mbits/sec
[ 3] 6.0- 8.0 sec 21.5 MBytes 90.2 Mbits/sec
[ 3] 8.0-10.0 sec 21.3 MBytes 89.5 Mbits/sec
[ 3] 0.0-10.0 sec 108 MBytes 90.2 Mbits/sec
Moderator
by bredman » Sun May 06, 2012 5:24 pm
I'm sure I read an interview with one of the hardware designers. He said that the 10/100 LED was labelled incorrectly but it was too late to change it.
Maybe I imagined it.
by bredman » Sun May 06, 2012 5:31 pm
If you want to know what your RPi thinks of the network speed, try the following command
cat /var/log/messages | grep duplex
You should see the report of the ethernet speed.
by KevinM » Sun May 06, 2012 5:52 pm
@dom
p.s. this is Arch
The dmesg log only has these lines for the smsc95:
smsc95xx v1.0.4
smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:85:2c:9f
Here is iPerf result - just confirms the led is labelled wrong... (it is
[root@alarmpi /]# iperf -c 192.168.1.9
Client connecting to 192.168.1.9, TCP port 5001
[ 3] local 192.168.1.97 port 57838 connected with 192.168.1.9 port 5001
[ 3] 0.0-10.0 sec 112 MBytes 94.1 Mbits/sec
[root@alarmpi /]#
Looks like its simply the ident on the PCB.
by mahjongg » Sun May 06, 2012 10:52 pm
from the LAN9512 datasheet:
This pin is driven low (LED on) when the Ethernet
operating speed is 100Mbs, or during autonegotiation.
This pin is driven high during 10Mbs
operation, or during line isolation.
The pin also can act as a GPIO (under complete software control, as are the other two LED's) but its very unlikely that that is happening, so yes, the LED is ON during 100Mbps operation!
Perhaps this should be documented somewhere.
Moderator
by jbeale » Mon May 07, 2012 2:11 am
I added it to the "Troubleshooting" part of the wiki, but maybe it should be somewhere else as well (?)
http://elinux.org/R-Pi_Trouble.....ad_of_100M
by error404 » Mon May 07, 2012 3:20 am
Pretty impressed by the performance over USB actually, it's better than I'd expect.
Don't look in dmesg output for interface state. cat /sys/class/net/eth0/speed will give you current state.
by Michael » Mon May 07, 2012 9:30 am
It is also documented in the schematics errata.  Apparently it is due to space constraints on the silkscreen.
http://elinux.org/RPi_schemati.....fied_typos
by jbeale » Fri Jun 29, 2012 6:31 am
Not that it matters much, perhaps but my 100 Mbps home network shows only 62 Mb/s, not the 90+ that others are reporting, is it something about my Pi, or my network? This is going from the Pi to a quad-core 2.5 GHz machine running WinXP.
pi@raspberrypi:~$ iperf -c 192.168.10.104
Client connecting to 192.168.10.104, TCP port 5001
[  3] local 192.168.10.113 port 40662 connected with 192.168.10.104 port 5001
[  3]  0.0-10.0 sec  75.0 MBytes  62.9 Mbits/sec
pi@raspberrypi:~$ uname -a
Linux raspberrypi 3.1.9+ #138 PREEMPT Tue Jun 26 16:27:52 BST 2012 armv6l GNU/Linux
by jbeale » Fri Jun 29, 2012 2:35 pm
As a followup, my WinXP laptop does achieve about 90 Mbps going to the same desktop over the same network cable, although I see the TCP window size here is 63k instead of 16k.
C:\Documents and Settings\John\My Documents\Downloads>iperf -c 192.168.10.104
TCP window size: 63.0 KByte (default)
[1900] local 192.168.10.102 port 1225 connected with 192.168.10.104 port 5001
[1900]  0.0-10.0 sec   107 MBytes  89.8 Mbits/sec
