I am currently compiling OpenELEC at this moment.
I'm using Ubuntu in VMware. I set total of 16GB for VMware. I left it compiling overnight and when I woke up it was still compiling so I check the total size the build is currently and its 4.2GB!
I wanted to be sure if I am doing this right. Anybody know how much space requirement I will need to compile OpenELEC?
OpenELEC compile space requirement.
8 Gb, so you should be half way.
max@lynx:/hdd/max/dev/OpenELEC.tv$ du --max-depth=1
76864 ./.git
112 ./config
324 ./licenses
23720 ./packages
14296 ./projects
144 ./scripts
384 ./tools
7747636 ./build.OpenELEC-RPi.arm-devel
517692 ./sources
299076 ./target
8680272 .
76864 ./.git
112 ./config
324 ./licenses
23720 ./packages
14296 ./projects
144 ./scripts
384 ./tools
517692 ./sources
299076 ./target
8680272 .
