XBMC can't read files! [Help!]
by bob.exe » Tue Jun 05, 2012 4:02 am
I have tried both OpenELEC + XBMC, and Raspbmc
http://www.raspbmc.com/2012/05/raspbmc-is-now-in-beta/
http://openelec.tv/component/k2/item/23 ... -supported
but both fail to see the files on my harddrive (powered external WD 2TB connected to powered hub)
it sees the drive, and sees the folders, but my (.mp4) files are not listed, even under 'file manager'
by abishur » Tue Jun 05, 2012 3:38 pm
What filesystem is the drive using?
Dear forum: Play nice ;-)
Moderator
by AndrewS » Fri Jun 15, 2012 3:54 pm
You're not spamming, are you Airstream? :| Seems to be a bit of a pattern to your recent posts...
I'm not accusing you of anything, just trying to make sure your account doesn't get blocked :)
by abishur » Fri Jun 15, 2012 4:20 pm
Airstream, I believe we've discussed this before and even if you're just trying to be helpful, all your posts consist of advertising this one product. I've given you a week ban as a second warning, if you continue to promote this one product it will become permanent.
Moderator
