Raspbmc Wireless Networking?
Has anyone managed to get wifi working on raspbmc?
Free photoshop Tutorials - www.howtophotoshop.co.uk/forum
230 views and no one got any ideas?
hah
I read that post wrong. No I haven't tried.
Has anyone had trouble with the longin? I tried the default pi raspberry but no go? Any help would be great. tried is a million time and no luck. Thanks
Hi jmprnbr1,
I had issues finding the login, Username and password both turned out to be "root" on the image I used, then get stuck at the command line. can't get the GUI to load, don't know the command to do it.
jmprnbr1 wrote:Has anyone had trouble with the longin? I tried the default pi raspberry but no go? Any help would be great. tried is a million time and no luck. Thanks
chrishill88 wrote:Hi jmprnbr1,
I had issues finding the login, Username and password both turned out to be "root" on the image I used, then get stuck at the command line. can't get the GUI to load, don't know the command to do it.jmprnbr1 wrote:Has anyone had trouble with the longin? I tried the default pi raspberry but no go? Any help would be great. tried is a million time and no luck. Thanks
With RC3 should go straight into XMBC without a login.
If ssh then user is "pi" and password is "raspberry"
Yeah, ive been trying to get wifi working for a while, then I could truly use it as a media centre..
Shame im not much of a programmer so don't know much about linux :/
I am successfully using Raspbmc on a wireless network. Have you got your wireless dongle working or is that what you are having trouble with?
Matthew
Matthew
"I'm selling these fine leather jackets"
I have the same newbie problem getting wifi working.
I have raspbmc up and running all right with a wired connection, but now I want to switch to my Edimax wifi dongle. I know the dongle works fine on another SD card, but I installed that using the script and instructions from MrEngman (viewtopic.php?f=26&t=6256).
Now I'm stuck.
Now I'm stuck.
What version of 8192cu.ko are you usin (i.e. where did you download it from?)
Matthew
Matthew
MattPoat wrote:What version of 8192cu.ko are you usin (i.e. where did you download it from?)
Matthew
I got it from here - http://dl.dropbox.com/u/80256631/8192cu-latest.tar.gz
I think it's dated 19.07.12
Am I supposed to repeat MrEngman's instructions and copy all the files/script/driver to the raspbmc SD Card as I did before, and then run the script, then plug in the wifi dongle?
Sorry for asking basic questions.
Thanks.
This was the version I used and got working
Sudo wget http://db.tt/i10Dt561
I listed my instructions on how I got the Edimax dongle working on RaspBMC in the Raspbian forum. PM me if you want any additional help.
Matthew
Matthew
Just checked and the kernel you are using doesn't work with RaspBMC, only Raspbian. Use the one I linked to above and you should be up and running.
Matthew
Matthew
i have got a powered hub from ebay and then i can run a
but cant get it to do anything else
- Code: Select all
pi@raspbmc:/lib$ sudo lsusb
Bus 001 Device 004: ID 0bda:8172 Realtek Semiconductor Corp. RTL8191SU 802.11n WLAN Adapter
