I'm trying to get my RTL8188CUS based adapter working, on a standard slackware install it's as simple as extracting and running the install script.
On armedslack I've installed make and gcc and got a copy of the kernel source from the raspberrypi github (/lib/modules/3.1.9+/build) but am still having problems.
- Code: Select all
make ARCH=armv6l CROSS_COMPILE= -C /lib/modules/3.1.9+/build M=/root/RTL8188C_8192C_8192D_USB_linux_v3.4.2_3727.20120404/driver/rtl8188C_8192C_8192D_usb_linux_v3.4.2_3727.20120404 modules
make[1]: Entering directory `/lib/modules/3.1.9+/build'
Makefile:567: /lib/modules/3.1.9+/build/arch/armv6l/Makefile: No such file or directory
make[1]: *** No rule to make target `/lib/modules/3.1.9+/build/arch/armv6l/Makefile'. Stop.
make[1]: Leaving directory `/lib/modules/3.1.9+/build'
make: *** [modules] Error 2
