Sorry if this is a noob question and/or it's been asked before.
Has anybody managed to get their Raspberry Pi model B working with Slackware ARM using the full 512MB RAM? If so, how did you achieve it?
Many thanks,
sorinm wrote:Update to the latest firmware https://github.com/raspberrypi/firmware
Also splitting ram to the gpu is now done in /boot/config.txt and not start.elf anymore.
sorinm wrote:You didn`t update all the firmware files. Somewhere .. you messed up something. arm496_start.elf doesn`t control the amount of ram going to the gpu. Only start.elf controlled that but now this is done in config.txt
Before config.txt, you allocated ram to gpu only renaming arm496_start.elf to start.elf .
Penthux wrote:Ooops... SanDisk is the SDHC card that gave me problems in the first instance. Sorry I will be avoiding them like the plague.
