Using alsa as output, and no X.
Everything is from the default arch repos.
the output is (with error message at the end):
- Code: Select all
MPlayer UNKNOWN-4.6.3 (C) 2000-2012 MPlayer Team
183 audio & 398 video codecs
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /mnt/Music/Compilations - game/Stuart Chatwood/Prince of Persia Warrior Within Original/01 Welcome Within.mp3.
libavformat version 54.2.100 (internal)
Audio only file format detected.
Clip info:
Title: Welcome Within
Artist: Stuart Chatwood
Album: Prince of Persia Warrior Withi
Year: 2005
Comment:
Track: 1
Genre: Other
Load subtitles in /mnt/Music/Compilations - game/Stuart Chatwood/Prince of Persia Warrior Within Original/
Opening audio decoder: [mpg123] MPEG 1.0/2.0/2.5 layers I, II, III
AUDIO: 44100 Hz, 2 ch, s16le, 32.0 kbit/2.27% (ratio: 4000->176400)
Selected audio codec: [mpg123] afm: mpg123 (MPEG 1.0/2.0/2.5 layers I, II, III)
[AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or directory
AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
Starting playback...
A: 0.6 (00.5) of 203.0 (03:23.0) 5.7%
MPlayer interrupted by signal 2 in module: play_audio
[AO_ALSA] Write error: Operation not permitted
[AO_ALSA] Trying to reset soundcard.
[AO_ALSA] alsa-lib: pcm_hw.c:558:(snd_pcm_hw_prepare) SNDRV_PCM_IOCTL_PREPARE failed (-16): Device or resource busy
[AO_ALSA] pcm prepare error: Device or resource busy
A: 0.8 (00.7) of 203.0 (03:23.0) 5.9%
Exiting... (Quit)
After that, when I play a song again, it works, but only for a short time.
aplay and vlc work as supposed
