ArchlinuxARM on Raspberry Pi
146 posts   Page 4 of 6   1, 2, 3, 4, 5, 6
by rbn » Wed Apr 18, 2012 4:18 pm
This worked for me. Using  Panasonic Viesa TV (32 inch). Now happily runs at 1280x720, which is the same setting as under the debian distro.
Thanks for the solution.
by pepedog » Wed Apr 18, 2012 6:18 pm
Looks like the update to latest version removes the cmdline.txt (and config.txt).
This has the negative effect that the GPU bootloader doesn"t append the extra arguments (e.g. framebuffer width/height, serial number, mac address)
This results in 800x480 framebuffer console.
Creating a suitable cmdline.txt fixes it:
echo "dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext3 rootwait" >/boot/cmdline.txt
@pepedog - can you fix this?
I will fix. The txt files are there but with pacsave on the end.
Thanks for pointing out
by pepedog » Wed Apr 18, 2012 11:33 pm
All fixed
Edit, no it"s not, will post when it is
by pepedog » Thu Apr 19, 2012 12:39 pm
I am making a new rootfs. Alsa working, disable obvious in /etc/rc.conf
All new kernel and firmware. Will post when done (zip -9 is the longest part of process, wish xz could be used)
Looks like new firmware takes care of some overscan problems, on my monitor area has shrunk
by dom » Thu Apr 19, 2012 1:33 pm
Yes, latest firmware defaults to overscan of 32 for SD resolutions, and 48 for HD (width>=1280).
If you have already set overscan, you may have too much now.
disable_overscan=1 to go back to no-overscan scheme.
Moderator
by envy270 » Thu Apr 19, 2012 3:46 pm
Hi pepedog,
Thanks for your contribution. Can you please post a link for download once done.
Regards
envy
by pepedog » Thu Apr 19, 2012 4:05 pm
Will do envy, I am pming you
Thank you Dom.
Dave
by pepedog » Thu Apr 19, 2012 8:25 pm
Just a note on updating this one time, force update with
pacman -Syuf
Sync after.
Liberal use of sync seems to help after large downloads or writes. Become a fan of sync.
by iciclethief » Fri Apr 20, 2012 6:42 pm
I've had a little trouble with updates.  Install with archlinuxarm-01-03-2012 works great but any later kernel doesn't boot, I receive the following error:
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
Copying over the previous kernel has got me back up and running, but what could I be doing wrong?  I've done plenty of 'sync'ing before rebooting after update.
Also, is nfsd compiled into the kernel?
by iciclethief » Sat Apr 21, 2012 9:08 am
Setting log level to 7 has thrown some more light onto this.  It would appear that the later kernels don't like either of my sd cards (one of them being the SanDisk Ultra II 2GB 15MB/s that should be 'pi compatible'). The error during boot up is:
mmcblk0: error -84 transferring data, sector 195313, nr 8, cmd response 0x900, card status 0xc00
and on the other card:
mmcblk0: error -84 transferring data, sector 197265, nr 8, cmd response 0x900, card status 0xd00
I guess I've just been unlucky here with my cards here.  What I really don't understand is why the 3.1.9.6+ kernel boots without any problems.
by pepedog » Sat Apr 21, 2012 12:53 pm
I am really just keeping up with the kernel on github
https://github.com/raspberrypi/linux
Just different config options, I'm sure Dom would have told me if there was a critical change.
Just for a laugh, precompile kernel + modules and firmware are here, you could graft them in easily enough
https://github.com/raspberrypi/firmware
With my own rootfs on a sandisk 2Gb class 2 I had bad experience, burned image again and no more problems. Don't know if sync actually does anything after dd but I have taken to using it
by pepedog » Sat Apr 21, 2012 1:17 pm
Incidentally, because firmware packaged off github, the default start.elf only gives 128Mb ram.
cp arm192_start.elf start.elf
That will give 192Mb ram after reboot
Think you can work out how to get 224Mb ram from that
by pepedog » Sat Apr 21, 2012 1:38 pm
In this new rootfs I enabled alsa sound. I thought if there was any problems it would be when messing with sound, I was wrong. A panic pointed to these modules.
Disable by editing /etc/rc.conf, Look for line where it says MODULES and delete everything between brackets, sync and reboot
by selsinork » Sat Apr 21, 2012 2:33 pm
pepedog, any chance you could remove the hard coded mac address from cmdline.txt next time round ?
the firmware then supplies a mac address in the RPF owned range based on the serial number
by pepedog » Sat Apr 21, 2012 2:39 pm
I have an alpha board which doesn't have serial.
If I had a production board I would have spotted that. Yes, next rootfs will remove
by iciclethief » Sat Apr 21, 2012 5:18 pm
Thanks for the tips.
I purchased a transcend 4GB class 4 and I'm pleased to say everything is now working great - also much faster than on the Sandisks I was using.
by pepedog » Mon Apr 30, 2012 11:53 am
There is a new kernel in updates, backup /boot/config.txt and /boot/cmdline.txt first, they will disappear.
I have new rootfs ready, awaiting inclusion to downloads page.
Why new rootfs? There was a bug in kernel which might have prevented updates.
Charges are -
Rootfs now ext4
NFS and ipv6 kernel modules
Latest kernel and firmware.
Above txt files never touched on updates
Hostname is alarmpi
Mac address removed from cmdline.txt
Default (700Mhz) CPU, overscan off, 720p default hdmi in config.txt
Dave
by pepedog » Tue May 01, 2012 7:20 pm
by sironitomas » Fri May 04, 2012 2:32 pm
It isn't clear to me if we must use a new image each time you release one, or a pacman -Syu is just enough.
by maribu » Fri May 04, 2012 2:49 pm
Hi sironitomas!
Arch Linux is a rolling release, which means performing an update leads always to the newest version of Arch Linux no matter with which version you started.
But there are is a reasons why you might want to use the newest image:
The new image uses ext4 instead of ext3. Personally the first thing I did with my SD-Card was to change file format to ext4. ext4 is faster than ext3, has more features than ext3 and personally I consider it to be more stable than ext3.
Cheers,
Maribu
by pepedog » Sat May 05, 2012 9:44 am
maribu said:
Hi sironitomas!
Cheers,
Maribu
This should be it from now on. As maribu said, changed rootfs to ext4, there were kernel problems that might have prevented updates, and update problems where the 2 config files might disappear.
Looks like midori package is broken, btw, might be something to do with libwebkit
by nick.mccloud » Mon May 07, 2012 7:42 am
I tried Arch yesterday but got bizarrely roadblocked running X with lxde because my mouse wouldn't respond. It's seen in
/proc/bus/input/devices as a Microsoft Basic Mouse - which it is - and this rodent works in Debian. Both udev and evdev are installed. LXDE comes up fine, it just won't move the pointer.
FWIW, installing X & lxde was somewhat error prone - if I tried it all in one hit I usually got a kernel panic relating to timers & sound. If I did an update then installed xinit then lxde it survived unscathed.
Any thoughts anyone on getting this mouse going - I've ordered a cheap & cheerful mouse plus a branded mouse from eBay to try them out but I'd like to think that the MS mouse was pretty standard.
by pepedog » Mon May 07, 2012 8:01 am
Which image did you burn, because the panics are a symptom of the old one, see my sig for new image.
by nick.mccloud » Mon May 07, 2012 9:21 am
Tried both 19 April and the 27 March - will download from sig and try that this afternoon. Any thoughts on the mouse issue?
by liamfraser280 » Mon May 07, 2012 11:00 am
The latest image is the 29th of april. Pepedog has posted it on the 1st of may (few posts back).
Not sure why it's not on the downloads page yet. Will get onto Liz and Eben.
May want to try that :)
