X forwarding over SSH
by magicstix » Sun Jul 15, 2012 6:46 am
Hi all,
I've been using my Pi with archlinux and ssh'ing into it remotely (with ssh -X or ssh -Y for X11 forwarding), but I've been unable to get X forwarding to work so far. I have X running, and it's created a :0 display, but when I run a program with DISPLAY=:0 <program> it just sits there, sometimes giving a warning message.
For example, running emacs:
DISPLAY=:0 emacs
Gives:
GLib-GIO-Message: Using the 'memory' GSettings backend. Your settings will not be saved or shared with other applications.
But after that nothing happens. I don't get an emacs window, and if I ctrl C it I get:
(emacs:1747) GConf-WARNING ** : Got disconnected from DBus.
Are the programs trying to pop up on the actual Pi display instead of my local machine? If so, what's the fix?
by joan » Sun Jul 15, 2012 7:31 am
What happens if you enter the command?
ssh -X raspberry-name-or-address xeyes
Does
xhost +
on your local machine make any difference?
by magicstix » Sun Jul 15, 2012 7:52 am
Nevermind, I figured it out. sshd wasn't configured correctly.
For those having the same problem:
In /etc/ssh/sshd_config
make sure X11ForwardingEnable and X11UseLocalhost are set to yes.
by hunterpi » Sat Sep 15, 2012 12:19 am
I use cygwin how terminal X Window
you make sure execute Cygwin-X -> XWin Server program, then login with ssh:
# ssh -Y root@192.168.1.xxx
then run any X program, for example the visual debuger (ddd):
# ddd
The main window of ddd appears in MSWindows.
