I'm using the latest arch image and I've configured the mpeg2 license I purchased. I'm trying to convert an mpeg2 recording to h264. I keep getting errors from ffmpeg and I'm wondering if the armv6h package is older or if packages don't yet exist:
1) audio code (-acodec) libfaac doesn't seem to be offered by any package that I can find in the default repositories. I'm trying to use just 'aac' in the meantime....
2) I'm using a preset file that is from mid-2011 ( https://gist.github.com/1015107 ) so I'm not sure if it's wrong or out of date, but it has the option 'directpred=3'. ffmpeg gave an error, but I found that adding a hyphen resolved it: direct-pred=3.
3) Also from the preset file, ffmpeg gives an error about a missing constant or '(' on the flags2 option +wpred. I can't find any info on this or how to resolve it.
So, I'm looking for some general info about ffmpeg (and libfaac) in the Arch image: are these packages fairly current? Has anyone managed to convert mpeg2 to h264 using Arch on Pi? It seems that handbrake-cli is another option for this (and seemingly simpler) but that package isn't in the repositories for armv6h. I've used handbrake-cli on a Pogoplug with Arch, but it's simple arm, not armv6h. Are there any intentions of putting handbrake-cli in the repos for Pi?
My specific situation: I'm recording an mpeg2 stream from an HDHomeRun tuner. I need to convert it to h264/aac (not in real-time) so I can play it on a Roku.
Thanks,
Josh
ffmpeg
Since these all are available for other ArchLinux distributions, it may be a matter of whether the person doing the Alarm packages has gotten around to doing them for v6h.
https://www.archlinux.org/packages/extra/x86_64/ffmpeg/
https://www.archlinux.org/packages/extra/i686/faac/
https://www.archlinux.org/packages/comm ... brake-cli/
I see that ffmpeg is available in arm6vh, and handbrake-cli is in the soft float community directory but not the armv6h, so since it is in the soft float repository, a request to get it added should make it happen.
I do not see libfaac in the soft float repository.
Hopefully Pepedog or someone else who knows about making requests at github will be around shortly to comment.
FORUM TIP: To view just one person's posting history, sign in, click on their user name, then click on "Search User's Posts." || This Pi owner is running Arch on 512MB Model B.
Our builder guy has a lot on his hands, ideally he would like someone to tackle and solve using abs or aur or https://github.com/archlinuxarm/PKGBUILDs
Once there is a soloution, to pull, modify and then push.
There is only a smattering of things that didn't build for v6hf
http://archlinuxarm.org/forum/viewforum.php?f=15 might be a more informal way of discussing about why packages missing
I'm pretty sure libfaac came with tegra blobs on my trimslice, btw
Would mencoder be able to do what you want?
I've looked at mencoder some, but haven't tried yet. The Roku example I found split out the audio and converted it separately, then used 2 mencoder calls to convert the video, then merged the audio and video back together. This is way more complex than I want to mess with. I feel like I need to be a codec expert just to begin to understand the myriad of options to set. handbrake-cli was much simpler in this respect and I got it to work on my pogoplug where ffmpeg would eventually error out. I'm hoping the hardware x264 and mpeg2 encoder/decoder will make the RPi much quicker at transcoding.
