I'm using Debian 2012-06-18-wheezy-beta with and DVI monitor. I have headphones connected.
If I play a MP3 with mpg123 or VLC, there are "glitches", scratches, while playing the sound.
mpg123 outputs this
MPEG 1.0 layer III, 320 kbit/s, 44100 Hz joint-stereo
Title: Someone Like You Artist: Adele
Comment: Album: 21
Year: 2011 Genre: Pop
After, if I try to play the same MP3 with OMXPlayer, it outputs this
[mp3 @ 0x1399720] max_analyze_duration reached
[mp3 @ 0x1399720] Estimating duration from bitrate, this may be inaccurate
file : Desktop/11%20Adele%20-%20Someone%20Like%20You.mp3 reult 0 format mp3 audio streams 1 video streams 0 chapters 0 subtitles 0
Audio codec mp3 channels 2 samplerate 44100 bitspersample 16
And there is no sound.
And after (a try with OMXPlayer), if I try to play again the MP3 with mpg123, there is nothing in headphones and mpg123 displays nothing as output. With VLC, there is nothing in headphones too and it hangs.
In addition, I have never heard sound from OMXPlayer.
I tried this movie : http://www.digital-digest.com/movies/Te ... ailer.html
The video is playing but without sound.
I tried the following commands, but nothing changed.
- Code: Select all
sudo modprobe snd_bcm2835
sudo amixer cset numid=3 1
Do you have any ideas ?
Thank you very much
