Enable ethernet?
by JollyRoger » Tue Jun 26, 2012 3:59 pm
I understand from other posts that ethernet may not be enabled by default on the Pi. Can anyone tell me how to enable it in Debian Squeeze?
by grumpyoldgit » Tue Jun 26, 2012 4:00 pm
You have been incorrectly advised. What post are you reading?
by JollyRoger » Tue Jun 26, 2012 4:24 pm
by itimpi » Tue Jun 26, 2012 4:31 pm
That post is specific to the Fedora Distribution which is currently deprecated.
On all other distributions Ethernet is definitely working out-of-the-box.
by JollyRoger » Tue Jun 26, 2012 4:56 pm
Many thanks for your advice. The reason for my query is that I have been unable to connect to my Pi using a direct connection (network port to network port) from an ancient laptop running Fedora 14 (I've tried both Putty on the laptop and a vnc client). I think the problem lies with my ancient laptop, though it could well be my own ignorance, as I've never done anything like this before.
by jbeale » Tue Jun 26, 2012 5:01 pm
On older hardware you may need something called a "crossover cable", although on newer hardware the ethernet port automatically switches to avoid needing that cable. Not sure if the R-Pi has that function, and an old laptop may not either. Can you connect using a hub?
by plugwash » Tue Jun 26, 2012 6:20 pm
jbeale wrote:On older hardware you may need something called a "crossover cable"
In my experiance "older" in this context translates to prety much any network adaptor (switches got the auto-MDIX feature much earlier than network adaptors did) that isn't gigabiit.
Moderator
by JollyRoger » Tue Jun 26, 2012 6:20 pm
Thanks for the hint. I'll try to get hold of such a cable.
by itimpi » Tue Jun 26, 2012 6:29 pm
You should not need such a cable as the Pi has such a facility built in.
I would expect that the problem is probably that the two ends are not getting compatible IP addresses. When using a direct cable there is no DHCP server, so you may need to assign at least one of them an IP address manually to ensure they finish on the same subnet.
