Thx rurwin!
It's Work!:)
Debian ARM on Raspberry Pi
Note, incidentally, that the "you're a windows person, we'll give you a Linux virtualbox to run on your windows system, then you run QEMU under Linux (as God intended it to be run) to run the Pi simulation" really isn't necessary anymore.
If I can get it to run effectively directly under Windows (using QEMU for Windows), then anyone can. It wasn't really that hard. I was a little daunted at first, but really it's no harder running QEMU under Windows than it is to run it under Linux.
The Debian package includes Geany, but not "make" or "xterm" which Geany uses. I suggest including those two packages also. Kind of cool seeing Geany open an xterm window and showing my Ruby execution. apt-get install works for both.
I'm having a problem with the root password both using the GUI and using the su command.
In both cases I get a password prompt but nothing I have tried works. It gives the authentication failure message. I thought the default root password was suse.
This is using the debian6-17-02-2012.img image, zImage_3.1.9 and qemu-windows-1.0.1 - on a Windows system.
sudo works and does not require a password.
Thanks for any help,
Debian is like Ubuntu. You don't get direct access to root. The account is locked. Just sudo. I am sure someone can explain this better than me.
Is this what stops applications run from the LXDE GUI from getting root access?
Perhaps. I seem to recall having difficulties installing software on a couple of occasions.
The sudo security model is superior because it does not depend on the secrecy of a shared password. Also, it allows precise control of which users and groups can run what commands, and it has good logging.
But if you do want a root password, you can set one with "sudo passwd root".
In any case, it is really not recommended to log in to the GUI as superuser. Log in as a regular user and escalate privileges only when required.
I'm not trying to log onto the IDE as a superuser I enter the user name and password (pi/suse). This give me a prompt with a $ which I think means normal user.
I type startx and get the LXDE desktop.
Then, in the LXDE desktop I select - Gparted
And I get a window headed "Enter the administrative password" (sic) There is a place to type a password.
What do I type there?
It looks like this:
Posts: 239 Joined: Thu Jan 12, 2012 5:45 pm
It looks like this:
And I get the form back with a line:
"Incorrect password... try again".
After three tries I get a form - "Failed to run /usrsbin/gparted as user root."
Interestingly I don't. What are you trying to do?
I suspect I have the same setup; Debian Squeeze in Quemu.
It's running on Lubuntu 11.10, whether that makes any difference, which I doubt.
Have you tried password : raspberry
- Moderator
just tried it, exactly the same, incorrect password.
But I'm in!
I used the line that jojopi suggested, "sudo passwd root" and entered a password. That one works.
Total power is mine!
Thanks everyone.
But I'm in!
Thanks everyone.
That's broken.
Gparted seems to want to escalate permissions itself and expects the root password. On a Debian system there is no such thing; the root password hash is "*" which is not the hash of anything -- nothing you can type will be a valid root password.
Gparted should have invoked some GUI form of sudo and so taken your user password. The workaround would have been to give the command "sudo gparted".
Your workaround -- to create a root password -- is also good, although it leaves your computer infinitesimally less secure and may lead to confusion when you are asked for a password.
rurwin said:
It is not GParted itself. LXDE's menu system is using GKSu as a wrapper on graphical applications that need privilege. GKSu supports using either su or sudo to gain privilege, but it is defaulting to su, which is the wrong choice for this image.
To fix it, run the following command and then restart LXDE:
Note that this is a per-user setting, and it is the setting for the unprivileged user that is effective, so the configuration change should not be sudo'd.
Now the menu system will start privileged applications without asking for a password, just as sudo does. Unless you also remove "Defaults exempt_group = users" from sudoers, in which case both will ask for your password, not root's.
gconftool-2 -\-type bool -\-set /apps/gksu/sudo-mode true
You may run into similar issues with other packages, as Debian default is to set a root password and use su, not sudo.
I don't know if anyone is interested, but I've just worked out how to get an rt2870 WiFi USB dongle working with debian. Please excuse my nativity but until yesterday I'd never played with linux, rpi or debian.
As far as I can tell the distribution ends up with the wrong firmware (a 4k version of rt2870.bin rather than an 8k version). If you replace the .bin file with a suitable good one, wifi leaps into life.
Here's a quick rune summary of what I did (sudo / su permitting):
# Install wireless
vi /etc/apt/sources.list
change "deb http://ftp.us.debian.org/debian squeeze main" to "deb http://ftp.us.debian.org/debian squeeze main contrib non-free"
aptitude update && aptitude install firmware-ralink wireless-tools
aptitude install wicd
cp /mnt/myusb/rt2870.bin /lib/firmware
reboot
# Connect to a WiFi network
startx
run wicd
# Connect at start-up
vi /etc/network/interfaces
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "mynetworkname"
wpa-psk "mysecretpassphrase"
Hope it helps - caused me a little bit of a headache. Same headache appears in the Fedora remix except all that needs patching there is rt2870.bin and then a reboot.
Apologies if this isn't useful / involved egg sucking.
# Install wireless
reboot
startx
run wicd
auto wlan0
Just for completeness, there are other firmwares for other wifi adapters...
For a 3Com I have
sudo apt-get install zd1211-firmware
For a Sumvision N dongle
sudo apt-get install firmware-realtek
Also, if you are using a WPA network on the command line, you may need to install wpasuplicant, and do some jiggery pokery including setting a psk key and creating a conf file. Then grab a DHCP lease using dhclient (I think).
For a 3Com I have
- Moderator
True about the wpasuplicant. I think wicd does a chunk of the magic for you. Certainly I had everything I needed after installing it.
Yes, I think wicd does a lot of the hard lifting, otherwise there are quite a few command lines to type in, at least for setup.
- Moderator
