Hi, linux newbie here, but loving my Rpi, looking forward to learning a whole new operating system.
So far my Rpi is working and I've managed with the help of the Internet to resize the partition to make full use of the 8gb sd card, my next two issues are getting the wifi working and then connecting to my Iomega NAS.
1st though is my linksys wusb100 v2 wireless adapter.
I have been looking but I am unable to follow some instuctions as they are for other linux distros and not specifically for the Rpi.
I've seen request in these posts for lsusb results so hear goes
Lsusb
Bus 001 device 003: Id 0424:ec00 standard Microsystems corp
Bus 001 device 005: id 1020:0106 labtec wireless optical mouse
Bus 001 device 004: id 1737:0078 linksys WUSB100 v2 rangeplus wireless network adapter (ralink rt3070)
Bus 001 device 002: id 0424:9512 standard Microsystems corp
Bus 001 device 001: id 1d6b:0002 Linux foundation 2.0 root hub
Since its listed here does that mean it has a software issue? Please help, anymore info required will gladly be posted
Daz
Linksys wusb100 wireless
Forgot to say I was using Debian squeeze, does wheezy have more support?
Can no-one give me any pointers? Have I posted it in the right place?
OK then
Having struggled through this issue myself not so long back, try having a look at this:
http://wiki.debian.org/WiFi#USB_Devices
It's not looking too clever for the RT3070 chipset device that you're running - If I where to be recommending a wireless USB device for the RPi, I'd recommend one based on the Realtek RTL8187 chipset (put Alfa networks realtek 8187 into an ebay search for a few suggestions) - I've had no luck whatsoever with Ralink devices so far - he says, casting an eye at the five such things lying on his desk.
-Rob
-Rob
Sorry to hear you have similar problems, I'll have to get a new adapter, thanks for the reply.
Daz
Daz
I have a Linksys WUSB100 and I made it to work on Raspbian: yuo can find detailed steps on http://www.brucalipto.org/linux/the-raspberry-diary-wusb100-wireless-n/. Please leave a feedback here or there to let us know if it works for you too.
Hope this helps
Bye
Piero
Hope this helps
Bye
Piero
Hi!
I got a similar problem:
I bought a ALFA AWUS036NEH with a rt3070 chipset which ran great using the Debian Squeeze Image. Unfortunatelly, when using the Raspberry Image I encountered some problems:
As soon as I plug in the device the whole systems starts to be very slow or even freezes completely. Using iwconfig I am able to see the device. But WICD is not seeing it.
Another interessting effect: I have a keyboard pluged into the same active USB hub as the ALFA. When I unplug the keyboard it sometimes shows the effect that the system seems to run a lot faster. But I am still not able to configure the ALFA using WICD.
Has anybody here encountered a problem like this, too?
Greetz,
maw_hn
Greetz,
maw_hn
