Wallpaper
Hello, how would you change the wallpaper in Wheezy?
"All day every day, making tomorrow seem like yesterday."
Blank Reg wrote:Hello, how would you change the wallpaper in Wheezy?
Hi Reg,
Right click on desktop, choose 'Desktop Preferences', select 'Wallpaper' and then choose one of the image files such as 'desktop-grub'.
Good luck!
If it doesn't fit, use a larger hammer, else fit a bigger fuse and 'tune' for maximum smoke
Doesn't work.
When i Rightclick on the Desktop i can only choose between:
Terminal Emulator
Web Browser
Dekstops ->
obConfig
Reconfigure
Restart
Exit
I googled this for two days. seems like i am missing something very important here. please help me. i am using the normal raspian debian squeeze.
Terminal Emulator
Web Browser
Dekstops ->
obConfig
Reconfigure
Restart
Exit
Quickest way to change LXDE Wallpaper :
1) Open a terminal session
2) Type :
You may also (for conveniance) want to create an icon on your desktop.
Proceed as follow :
1) Using you favorite editor (nano/vi/...), create a desktopchanger.desktop file, located in /home/pi/Desktop (assuming you're logged in as 'pi'...)
2) Copy/paste the following lines into this brand new file
3) save and exit. That's all
2) Type :
- Code: Select all
pcmanfm --desktop-pref
Proceed as follow :
- Code: Select all
[Desktop Entry]
Type=Application
Name=Desktop Changer
GenericName=Desktop Changer
Comment=Change LXDE Desktop wallpaper
Categories=FileManager;Utility;Core;GTK;
Exec=pcmanfm --desktop-pref
Icon=/usr/share/icons/nuoveXT2/64x64/apps/xscreensaver.png
StartupNotify=true
Terminal=false
MimeType=x-directory/normal;inode/directory;
Jean-Philippe
Jean-Philippe
Hi, I'm very new to Raspberry Pi as well as unix environment, and I'm having this same issue. It seems I somehow got Openbox to replace the normal X11 desktop manager? Trying the above solution didn't work, as it outputs
- and nothing else. Am I missing something here?
Cannot open display:
Ah, figured it out. You have to be inside X and use LXTerminal when doing the steps.
How I got rid of Desktop Preferences in the contextual menu in the first place and replaced the menu with that of the Openbox was foolhardily checking a checkbox labeled "Show menus provided by the window manager when desktop is clicked" under the Advanced tab in the Desktop Preferences. Apparently there is no GUI way of getting it to reverse afterwards, only that described above. Lesson learned.
Fancy losing your desktop context menus!
Anyway, I Googled the interweb and found this terminal command that gets the desktop preferences back.
Then untick the 'Show menus provided by the window manager when desktop is clicked' box.
Roy Leith
Roy Leith
