Dynamic DNS with the Pi
by recantha » Thu Jul 26, 2012 8:25 pm
New Blog post about setting up your Pi with ddclient and a dynamic DNS server so you can host your own website from your Pi behind your home router.
http://raspberrypipod.blogspot.co.uk/20 ... erver.html
My Raspberry Pi blog with all my latest projects and links to articles
http://raspberrypipod.blogspot.com. +++ Current project: PiPodTricorder - lots of sensors, lots of mini-displays, breadboarding, bit of programming.
by Casalor » Thu Aug 09, 2012 12:27 pm
I've used ddclient with success. The only problem I found is that it used too much precious memory as it uses 'sleep' between scheduled ip checks. What I've done instead is use a python script that I can put in the cron to check checkip.dyndns.org at very regular intervals and update my DNS provider (zoneedit in this case). http://zoneclient.sourceforge.net/
I'm sure there must be other generic scripts out there that can do the same thing for other DNS providers.
by recantha » Thu Aug 09, 2012 12:34 pm
Now _that's_ creative thinking. Thanks! Will grab that script when I get home! :-)
by omiez » Sun Nov 04, 2012 3:39 am
If you have a Router supporting DDNS you can setup there, so you avoid installing one more thing on the Pi.
Nr.1 Raspberry Pi Mod.B Rev.2 256Mb Ram (Raspbian)
Raspberry Pi Mod.B Rev.2 512Mb Ram (Maybe i´ll get one)
by Polydnj » Tue Nov 27, 2012 4:55 am
What are some routers that support this, that you recommend :?: that will run out of the box?
by tomw889 » Thu Jan 31, 2013 1:01 am
Here is a similar tutorial for beginners.. from start to finish for the beginners out there:
http://www.administeria.com/raspberry-pi-dynamic-dns-on-raspbian/
