Using the latest debian squeeze image I downloaded a free to play mp3 file to test the audio. I added to the LXMusic play list and hit the play button but nothing happens?
Can LXMusic play mp3 files?
or is ther some configuration I need to do first
I have a monitor without sound via dvi from the hdmi port and headphones plugged in to the audio output jack
LXMusic does it play mp3 files?
I'm not sure but are the mp3 drivers (called "non-free" and sometimes have to be downloaded manually) included by default?
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
Update
sudo apt-get install vlc
I instaled video lan client and audo plays on the headphones
with the vlc player of course, LXMusic still does nothing
RussIT said:
http://packages.debian.org/sea.....ywords=vlc
So VLC works on the Pi, as I had suspected a long time ago...
So, 2 questions:
Update
So, 2 questions:
- Playing accelerated-by-GPU video: Does VLC know to do that?
- I assume it automatically downloaded 1.1.3, not an unstable 2.0.1, right?
It is vlc 1.1.3 but it hasnt managed to play a video file yet although I did glimps a picture for a few seconds on a home movie in mpg format
Unless the video was encoded in Xvid or H264...it's not going to play period (the CPU will max out in less then a second)
Tip we picked up from somewhere else to enable the audio (ASLA) driver:
sudo modprobe snd_bcm2835
Then LXMusic played MP3 files OK.
To get LXMusic to work I had to install decoders. I did the following:
This installs a lot of decoders*, many of which I am unlikely to ever use, so being more selective could save some space on RPi using smaller SD-Cards.
* Including:
MPeg layers 1, 2 and 3
Vocoder
Vorbis
MP4
FLAC
- Code: Select all
sudo apt-get install xmms2-plugin-all
* Including:
Vocoder
Vorbis
MP4
FLAC
Thanks for this little gem - Pi R1 is sat behind my Big Plasma TV throwing media out on it.
R1 is running Debian Wheezy on an Aldi 8Gb card with this update hooked up via ethernet
JeremyF wrote:Playing accelerated-by-GPU video: Does VLC know to do that?
At this stage AFAIK only omxplayer and the various XBMC distros know how to play hardware-accelerated video.
robotmad wrote:Tip we picked up from somewhere else to enable the audio (ASLA) driver:
Thanks, that was helpful! I was going nuts as I couldn't get to play any music for my first steps.
I get audio with omxplayer, guayadeque, lxmusic.
I don't get any audio with audicious, vlc. I don't know why vlc such a nice app don't get audio output, I went into preferences and changed all kind of audio out and didn't get any sound.
