Broadcom documentation
by henle » Sun May 06, 2012 4:15 pm
As you know, the XBMC people have done a great job at making video play on the Pi.
If I understand correctly, they have used Broadcom specific documentation in addition to the standard OpenMAX IL specification.
Are there plans to release this particular documentation, and if not, what will it take to get access to it?
by dom » Sun May 06, 2012 4:33 pm
OpenMAX IL is a standard, so the first place to look is khronos.org.
We do also have some html documentation generated from comments in the source which describes some of the extensions used.
I'll try to get that tidied up and published.
But really, OpenMax IL is hard to use. You'd be well advised to look very closely at the XBMC code.
https://github.com/peterderivaz/pyopenmax is another place to look. (Video playback from python).
Moderator
by henle » Sun May 06, 2012 5:25 pm
Does that mean it is just a matter of reading/extracting the comments in e.g. OMX_Broadcom.h, or is there more?
Thank you for the github link.
by dom » Sun May 06, 2012 5:38 pm
No, the documentation comes from the GPU side comments.
(and perhaps documentation is overstating it...)
Moderator
by henle » Mon May 07, 2012 1:29 pm
Well, if you are able to put that up, it would be highly appreciated!
by dom » Fri May 11, 2012 5:53 pm
Documentation on ilcomponents is pushed to github:
https://github.com/raspberrypi/firmware/tree/master/documentation/ilcomponents
start with index.html
Moderator
by mjtessmer » Fri May 11, 2012 8:47 pm
When I click on the "index.html" file I get
the source text of the above file.  How do
I display the regular html output?
by Paul Webster » Fri May 11, 2012 10:33 pm
Save them all to a new folder on your machine then open the index file in your browser.
by mjtessmer » Sat May 12, 2012 1:06 am
I did save them to a new folder and opened the index
file; but it did not display properly.  I had to open each
individual file on the web, then copy the text contents to
a text editor, then re-save to a ".html" file.  I did notice that
the new files were 1/10 the size of the files I previously
downloaded.  The only files I was not able to transfer over
were the three ".gif" files; appears to work without them.
