Hi, I just ordered the RPi with a clear case for Singapore and it'll take about 12 weeks for despatch!
Complete beginner. Love the concept of RPi.
Anyhow I am curious about the RCA and 3.5mm out. The HDMI seems straight forward for HDMI or DVI-D to a HDTV or a DVI-D capable monitor respectively (DVI-D won't carry audio yes?) but what about the RCA Video out? If I wanted to use it on an older TV which only takes RCA Video and Audio (L&R) . Could I use a S-Video Male (with a S-Video Female to a RCA Video Male and plug it to the RPi's RCA Video Out) to RCA Video and a 3.5mm to RCA Audio(L&R) on the old Television?
I'm not sure if using adapters would be that simple. Will the above setup be possible in theory?
RCA Video, 3.5mm. Cables and adapters
It should be that simple.
I haven't tried with S-Video but it should still work as long.
Visit my blog for ffmpeg Webcam streaming, Raspbian Server Edition, RaspAP Hotspot guides and more !
Home of PiParted - A custom GParted LiveCD to make installing OSes onto the SD Card easier !!
