A 5$ 1.5" LCD screen for all your projects !
53 posts   Page 2 of 3   1, 2, 3
by blc » Wed Sep 07, 2011 1:49 pm
Quote from amiga65 on August 17, 2011, 00:54
Found this while looking for a screen to hack Myself. This looks to be doable.
http://www.bit-tech.net/moddin.....sone_lcd/1
That link is very very out of date. If I remember correctly you needed some very specific display timings to make it work correctly, and there were many reports of this method being incompatible with all but a few (long out of date) ATI graphics cards. Even if it was a compatible graphics card, you needed to configure specific timings in software.
In any case, this method is overkill for the RasPi. Any old LCD that accepts a composite input will work, and you'll find far more of those than you will find small LCDs that you can mod to work with VGA/DVI.
Hope I don't sound like I'm out to rain on your parade. I'm long-term bit-tech reader/user and re-using LCDs (especially laptop LCDs) as a secondary/alternative display has become a bit of a bit-tech forum meme ;).
by obarthelemy » Wed Sep 07, 2011 1:52 pm
I'm not really following this topic, sorry if I'm rehashing old news. You guys aware of that ?
http://www.ebay.com/itm/Compat.....0802804706
by blc » Wed Sep 07, 2011 1:56 pm
Quote from Arbelzapf on September 7, 2011, 01:26
Could these be opened up and built into one case together with the R-Pi?
http://mp4nation.net/catalog/3.....p-571.html
http://mp4nation.net/catalog/7.....p-570.html
If yes (and speaking as a total noob on stuff like this): how dificult would it be to have both the R-Pi and the display use the same power supply? I'd love to experiment a bit with these boards and I figured those screens could be a usable and cheap option for a small display. It's only composite but on the other hand, it saves the HDMI port for video-out (assuming that works)
I am pretty sure that the 3.5" LCD I bought from fleaBay is exactly the same model as the first link there... It has two composite inputs (which will work with r-pi) and a 2.5mm power socket. The seller I bought it from did advise that it would work with a 9v supply, but I haven't managed to get it working on anything less than 12v. Either way, 9v/12v is well within the specifications for the r-pi (which, I believe, is 6v-20v) so all you'd have to worry about is suppling enough current to power both devices.
by Arbelzapf » Thu Sep 08, 2011 10:35 pm
amiga65 & blc, thank you for your helpful input :)
Looks like I found a good match then; I'll definetely order one of those screens. I like how they apparently can still be used as an external monitor for other sources using the second input.
by NoshBar » Wed Sep 14, 2011 1:58 pm
I previously got Doom and Midnight Commander running through one of these screens on a BifferBoard (http://noshbar.xtreemhost.com/.....index.html and http://noshbar.xtreemhost.com/.....index.html), but I couldn't find somewhere local to the UK that sold the non plug-and-plug versions anymore.
If anyone has a tip on where to get them, I'd appreciate it.
Also, this might be of interest to someone: when I get my Pi board, I intend on putting it inside a PSP case (got a mauled one off eBay), and finishing off my C port of http://jjs.at/software/pspdisp.html so I can use the PSP as a screen/power source.
Failing that, Tesco is selling some second hand Samsung photoframes that are DisplayLink compatible...
by Gabriel » Wed Sep 14, 2011 3:24 pm
Quote from NoshBar on September 14, 2011, 14:58
Wow nice ! Especially midnight comander !
I suppose that you didn't have my problem after compiling for Bifferboard ?
(On my key chain the program lcd4linux can't display characters)
I will add your link to the 1st post.
Thanks for sharing :)
My home-made case : http://goo.gl/nprcI ; My presentation http://goo.gl/5hSar et en français : http://goo.gl/28Vif ; Please think to the FAQ and to the Wiki
by Lakes » Wed Sep 14, 2011 3:48 pm
Do you have a link for the Tesco Photo Frames?, I did a Google search but came up with the usb ones.
by cougarten » Sat Sep 17, 2011 5:23 pm
Quote from magnitux on August 22, 2011, 16:58
this lcd 2.4 screen is compatible with lcd4linux on debian(seagate dockstart)
http://www.pearl.de/a-HPM1184-5618.shtml
good german tutorial on this (also how to buy): http://geekparadise.de/2011/04.....-dockstar/
I hope I'll get 5fps screencasting und a proper console done. At least the console and 0.2fps should be possible with lcd4linux. 0.2fps is enough for some monitoring stuff at least.
by meltwater » Mon Nov 21, 2011 3:05 pm
Hi guys,
Any news on getting these devices, I'm in the uk and so far not had any luck sourcing one of these devices, without crazy p+p.
Edit: I think I've found a suitable one ($8.50 - it'll take a few weeks to get here but will report details if it works).
What other things can act as display link clients? Could I put some software on my laptop or tablet and then use it's display for the R-Pi over usb?
_________________________________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
Released at the start of each month.
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
by Jasont41 » Tue Nov 22, 2011 12:07 am
http://www.amazon.com/Axion-AX.....38;sr=1-10 This would work without a doubt...
by Pirx-Danford » Wed Nov 23, 2011 1:14 pm
Hey sweet thanks for the links.
The pearl screen was available at 2.90 € right now, got me one - exactly what I was looking for!
This will do until vr goggles become better (hopefully next year already).
by meltwater » Wed Nov 23, 2011 3:14 pm
Unfortunately the shipping made the perl too expensive for me (outside of Germany).
I'm hoping the one I got will work (or it'll become kids present).
Will also have a try with a using an Alpha-numeric display too (have some 16x2 modules to try), should be possible via GPIO.
Also if you have an iPad, displaylink apparently works with that too. Might even be able to use a psp (I've used one as a extended display from a windows laptop).
by tech guru » Wed Nov 23, 2011 3:41 pm
does any one think that 1 of these screens could work
http://www.laptopscreen.com/
it could make a nice table type device if say a 10 inch eee pc screen was compatible
(post edited to fix link)
by meltwater » Thu Nov 24, 2011 10:46 am
There are several threads about interfacing directly with LCD screens (have a browse), in particular with the LVDS interface etc, suggest you check them out. It seems like there are a number of standards so it'll take a while to work out which will work with the least additional electronics etc and which screens will be the best value etc.
by modernist364 » Wed Nov 30, 2011 2:26 pm
could you uses a touch screen with the Raspberry Pi? Like a iPhone screen?
by meltwater » Mon May 14, 2012 3:34 pm
I'm gonna drag this topic back up, since I now have a RPi and I have one of the 1.5" screens. It would be neat to be able to use them together (I tried through a VM previously, but I didn't have much luck with changing the FW over on the screen).
Anyone got it working on the RPi yet?
by reggie » Tue May 22, 2012 2:32 am
I think you'd be better off looking for a 3.5" or bigger screen on ebay that uses spi and has a controller on it. It's great hacking the little photoframes but the screen size is a bit pitiful at 1.5" :) There are already linux drivers out there for plenty of little screens, ilitek, himax etc.
by meltwater » Thu May 24, 2012 2:20 pm
reggie wrote:I think you'd be better off looking for a 3.5" or bigger screen on ebay that uses spi and has a controller on it. It's great hacking the little photoframes but the screen size is a bit pitiful at 1.5" :) There are already linux drivers out there for plenty of little screens, ilitek, himax etc.
1.5" 128x128 is plenty for the "right" application, the cost is low and the power usage is minimal.
But I agree, if there is no easy way to use it then there are easier solutions out there with more to offer.
by hamjudo » Thu May 24, 2012 5:34 pm
It is a USB device, so I can hang more than one of these off of a Pi. It also doesn't force me to unplug any other displays. I wouldn't use it as a replacement for an HDMI monitor, but it would be handy to display why my robot is refusing to move (E-stop, low battery, communication problem, sensor failure, etc...), or what mode its in and battery voltage.
This is all theoretical today, but my Pi has shipped, and the shipping company's tracking page says it should arrive tomorrow.
by Phil Spiegel » Fri Jun 01, 2012 9:29 am
Quite - agreeing with hamjudo; the idea of using a Pi to control a whole series of miniature screens - the smallest I can get - around a model railway layout is what I'm aiming for - as well as some slightly larger screens. USB fed screens is the ideal way. I primarily want to load JPEGs / GIFs or similar images to them - whatever images they support - to convey 'advertising' or updating images of timetables ... on the medium sized screens (1.5-2.4"), equivalent to 'Main Station' Large Departure boards, the fine lines of text are legible, whilst on <1" its impressionistic or a poster. [This running in conjunction with the Pi presenting the timetable and tracking the trains via RFid tag readers]
by hamjudo » Mon Jun 04, 2012 4:41 pm
Sony made a clunky wrist mounted bluetooth display for use with Android Phones. They weren't ideal for their intended use, because they are a huge thing to wear on your wrist. So one of the one sale a day ebay vendors is unloading them at $19.99 each. The pre-purchase questions that come to mind are:
Can it work while hooked to the charger? (Yes, some portable devices can't charge and work at the same time. It means they can't be repurposed for model train layouts and robot displays.)
Is the bluetooth protocol documented, so we can write a Raspberry Pi driver for it?
The product is the "Sony Ericsson LiveView Remote Bluetooth Display Watch". I searched ebay with that string, and the other vendors had it for twice the price. By that measure, the $20 price is reasonable. Note that the vendor is in Brooklyn, NY, USA. I don't know if the thing is available outside the US at a similar price.
Has anyone any experience with these things? Anyone got one of them to talk to a non-Android Linux system?
I'm not planning on buying any, unless someone posts that they actually work with Linux, and would work when continuously hooked to a power source. The concept of a wireless 128x128 pixel is intriguing.
by cougarten » Tue Jun 12, 2012 12:05 am
join this thread: viewtopic.php?f=64&t=6688
by captainwebb » Wed Jun 13, 2012 10:58 am
Morgan (www.morgancomputers.co.uk) are selling an "Elonex 7" Weather Station and Digital Photo Frame WS710" for UKL30. The photo frame is 800x600 pixels and has a USB2 connection.
I assume RPi can supply images to the screen via USB, but could that setup function as a Linux terminal? I'm currently using HDMI to drive an (enormous) lcd monitor from my RPi, but would like something smaller.
I'm very new to Linux, so I'm hoping to pick someone else's brain. Thanks.
by meltwater » Wed Jun 13, 2012 11:29 am
captainwebb wrote:Morgan (http://www.morgancomputers.co.uk) are selling an "Elonex 7" Weather Station and Digital Photo Frame WS710" for UKL30. The photo frame is 800x600 pixels and has a USB2 connection.
It would totally depend on what the internal chipset is as to what your options are. The 1.5" screens are mentioned here since they can (apparently) be hacked to provide direct interfacing to the screen.
If the screen above isn't able to do that, you'll need to find some other way around it (which probably won't be too effective).
There are some screens which support connecting as a USB monitor directly out the box, although price is an issue then.
by guidol » Mon Jul 23, 2012 2:34 pm
cougarten wrote:Quote from magnitux on August 22, 2011, 16:58
Today I took this tutorial above and did go through it with a Raspberry Pi under Raspbian Wheezy.
After installing some replacement-packages, I could compile lcd4linux with dpf support on the Raspberry.
I patched the Display firmware with the windows-tool from http://www.vdr-portal.de/board18-vdr-ha ... ost1032264
The display-Firmware-Package (Portrait and Landscape) is at http://dl.dropbox.com/u/64770380/Pearl% ... rmware.zip
Perhaps, the actual lcd4linux-version via 'apt-get install lcd4linux' is already supporting the DPF-Display?
But the Homepage of LCD4Linux states about that:
http://ssl.bulix.org/projects/lcd4linux/wiki/DPF
Requirements
To build this driver you need libdpf. But it isn't online at this moment.
Here is a blog about what I did in german:
http://lehwalder.wordpress.com/2012/07/ ... an-wheezy/
And here are 2 pictures for you from the display and my Raspberry :)
The command-lines I did use:
apt-get install libtool automake1.10 autoconf zlib1g-dev libssl-dev python-dev libc6 libusb-dev libibus-1.0-dev subversion libgd2-noxpm-dev libgd2-noxpm –fix-missing
(apt-get install sdcc-libraries)
apt-get install cc1111
wget http://tech.section5.ch/files/dpfhack-0.1alpha.tgz
tar -xvzf dpfhack-0.1alpha.tgz
cd dpf/src
make
cd ..
wget http://tech.section5.ch/files/dpf-lcd4linux.tgz
tar -xvzf dpf-lcd4linux.tgz
cd dpf
vi build-dpf-lcd4linux.sh
./build-dpf-lcd4linux.sh ../src/dpflib/
cd lcd4linux
make install
