Multiple displays on the Pi
by cajundust » Tue Nov 06, 2012 8:19 pm
I am looking for suggestions or pointers to connect multiple displays on the raspberry pi, running the arm linux, and displaying 2 independent screens (not mirror).
Preferable, one of the 2 screens is a touchscreen.
What I want to to is provide a sort of 2-display system, where an operator has the touch enabled screen,and the other person is just observing the second screen output.
I hope the community can help me get started...
by Burngate » Wed Nov 07, 2012 10:20 am
The Pi on its own can only drive one screen - be it HDMI or composite.
There are USB screens, which may interface with the Pi.
A maybe better alternative would be two Pis networked together.
If you don't supply a mouse and keyboard for the second Pi, then that one can only be watched!
by mahjongg » Wed Nov 07, 2012 10:35 am
The raspberry PI foundation is working on an interface that would make it possible to add an LCD panel, and this panel will indeed be useable as a seconds screen, independent of the HDMI screen. The interface connector is located above the SD-Card slot, a second similar connector is for a planned camera module.
Moderator
by cajundust » Wed Nov 07, 2012 12:13 pm
Thanks for the replies.
So, the analog video and HDMI cannot be used simultaneously as 2 separate screens.
I believe there is already a connector on the type B board, to connect a LCD. But I cannot find any good starters about how and which hardware to connect. Is it also exclusive ? E.g. when connected, the hdmi or analog will not work anymore ?
Where can I follow the status ?
The other solution, to connect 2 pi's via network, is the last resort solution...
by mahjongg » Fri Nov 09, 2012 4:13 pm
No!
the DSI output will function as a second screen, and will be fully independent of the main screen.
At least AFAIK.
It will be announced on the News page (front screen), it will be ready when its ready, my best guess will be early 2013, but you won't hear when its ready until it is ready.
That is one possibility, the other is to use the same screen twice. Connect the composite video output of the PI to two TV's, and mask a different part of each TV's screen. For example on one screen the top half, and on the other the bottom half.
Moderator
by toxibunny » Fri Nov 09, 2012 6:24 pm
You could use a USB video card, or a graphical LCD module attached to the GPIO. Performance will probably be pretty poor though...
note: I may or may not know what I'm talking about...
by zardoz66 » Thu Jan 03, 2013 2:24 am
Mmm, I have a USB display link adaptor. I might half to try this...
Zardoz
Raspberry Pi B v2.0 | Sony 16GB SDHC Class 10 | Cyberpower CPH420P 4 port USB HUB | Netis WF-2111 150Mbps Wireless-N USB | Sabrent CRW-EXT 6-Slot Card Reader | MS USB Notebook Optical Mouse | Mini USB Keyboard | Adafruit Pibow case (blue)
by zardoz66 » Thu Jan 03, 2013 3:12 am
tried my usb displaylink adaptor, no go out of the box. reading on it reviled some driver stuff might have to be done to get it working... I will poke at it and see what I can get done...
Zardoz
by gordon@drogon.net » Thu Jan 03, 2013 4:24 pm
Are you looking for a framefuffer type of display, or just a general purpose programmable LCD panel? If it's the latter, then this may help: https://projects.drogon.net/4d-systems- ... pberry-pi/
-gordon
by zardoz66 » Thu Jan 03, 2013 4:38 pm
Hello Gordon,
Think he is looking to do somting like a multi-display with the RasPi. There is a technoligy called displaylink that alows you to have a USB video card of sort. (this is a pice of hardware) from what I have found so far this might work, but drivers will need to be setup for it, and it's seems to be a bit of work that I have not started yet. hope to have some time this week to mess with it, I am using an EVGA UV-16 to test with.
Zardoz
by zardoz66 » Fri Jan 04, 2013 4:14 am
ok, I found a link that shows how to get a display link device working. it will require a compile of the the raspbian kernel some drivers and configure a /etc/X11/xorg.conf file. anyways looks like it can be done. here is the link to what I found.
http://karuppuswamy.com/wordpress/2012/ ... -raspbian/
I dont have the resource to compile something like this at the moment.
Zardoz
