The modification is very simple, you don't even have to care about the purpose of the pins, just line up each contact on the holder to the matching contact on the adapter and solder them together using a wire. Remember to short out the "card detect" pins.
I am using 30 gauge Kynar coated wire, plenty of flux, flux core solder, desoldering braid (in case you screw up).
The wire lengths are short enough to not cause problems. The adapter is still very thin and do not add to the overall thickness of the R-Pi at all. Full sized SD cards will still work after this modification.
