These are pin compatible with SD cards, and are just half the length
They just slot right into an unmodified Pi and sit more or less flush with the edge:
KenT wrote:I happened to be looking at a SD card in a bright light and it looked like the memory chip only came half way up the card so it may be possible to hacksaw an ordinary card in half.
Caveat Emptor!
Montala wrote:This looks like an excellent solution.
Has anyone else tried it, and if so, are there any downsides to the idea?
Montala wrote:KenT wrote:I happened to be looking at a SD card in a bright light and it looked like the memory chip only came half way up the card so it may be possible to hacksaw an ordinary card in half.
Caveat Emptor!
Now that you mention it, I am sure I once read an article confirming that was indeed possible... perhaps only with certain brands though... I can't recall the exact details.
Nice thought anyway!
mikerr wrote:I wonder if that's the limit of MMC, or modern ones are faster ?
Dilligaf wrote:Someone needs to manufacture and sell a "MicroSD Pidaper", basically a half height micro sd adapter, then a micro sd would sit flush.
azerty wrote:Dilligaf wrote:Someone needs to manufacture and sell a "MicroSD Pidaper", basically a half height micro sd adapter, then a micro sd would sit flush.
Something like this, maybe?
Montala wrote:That does indeed look VERY interesting!
Is it a proprietary device, or a purpose made 'one off'... or just a clever bit of 'Photoshopping'?![]()
Please tell us more!
clickykbd wrote:I thought I read that micro adapters were problematic in general... i assume this one is not! Tell us more. Stop being a tease.
Dilligaf wrote:Cool, that would work. Ideally the micro sd slot would be rotated 90 deg counter clockwise from the pic in order to make removal easier. Maybe raised enough that the socket overhangs the end of the sd socket and remains flush with the side of the board.
bircoe wrote:How bout these?
Little bit expensive as they're for the Apple brigade but they certainly look the goods!
http://www.kickstarter.com/projects/1342319572/the-nifty-minidrive
bircoe wrote:The Pro ones have round corners on the end piece where the air ones are right angles...
I see no reason why it wouldn't work in the Pi, on the electrical front it should work in any device that accepts an SD card... however there would be obvious physical issues with using these in other devices that stick to the SD standard.
wolfgangmob wrote:Another option is a combo adapter for micro SD to SD/USB then just cut off the USB side of the adapter.
