I have a buzzer attached to GPIO 8 (pin 24) and everytime I reboot my Pi it goes off like mad until I set it to false manually?
Is this just the nature of that pi and its secondary function? Should I swap the buzzer to one of the primary GPIO's or can I make it stop.
GPIO 8 Starts True?
kghunt wrote:I have a buzzer attached to GPIO 8 (pin 24) and everytime I reboot my Pi it goes off like mad until I set it to false manually?
Is this recent kernel? If-so, then I think it's the SPI driver - it seems to set a couple of pins to be active outputs and sets them high.
So what I did was to make sure those modules were not loaded at boot-time - if this is the issue, then create /etc/modprobe.d/gpio-blacklist.conf and put in it:
- Code: Select all
blacklist spi_bcm2708
blacklist i2c_bcm2708
blacklist w1-gpio
and reboot.
To see if it is the cause, try typing lsmod and looking for those modules.
-Gordon
awesome thanks got rid of that annoying buzzing sound every time I reboot
kghunt wrote:awesome thanks got rid of that annoying buzzing sound every time I reboot.
Great!
You can always use the modprobe command to re-load those modules later if you have a project that uses SPI or I2C.
-Gordon
