Rename this forum ?
May I suggest Instead of having a forum for gertboard, Piface, Pi-Wire etc, perhaps re-name the 'Gertboard' forum 'GPIO Boards' then discussions about all the GPIO boards can be discussed here. If it gets really busy in here then sub-forums could be made for the popular boards.
I think as the Gertboard is "semi-official" (
) it'll probably be more popular than the other addon boards, so IMHO it makes sense to leave a separate forum for Gertboard and discuss the other GPIO boards in "Addons" ?
As you say the Gertboard is likely to be more popular than most, but separating it out it is spreading things to thin as most of the discussion relating to the Gertboard will be general GPIO topics that will apply to all the boards. Seems to make sense to me to keep them all together.
We are going to run like this for a while, and if necessary we will combine/separate at a later date.
- Moderator
Come to think of it having
"Gertboard", Interfacing (DSI, CSI, I2C, etc.), and 'Add-Ons' seems quite confusing and somewhat duplicates the same things.
For example I have a question that is " If there a permanent pull-up resistor on Expansion Header GPIO 0, would it be best to use pull-up rather than pull-down designs for GPIO ?'. I'm not sure where I would post this as I am thinking of using a Gertboard, on the other hand you could say my question is Interfacing related or an Add On question.
Seems most logical to me to have just a general 'Interfacing (DSI, CSI, I2C, GPIO etc.)' forum.
well, IMHO there is no confusion, if the question is about an actual gertboard it goes here, if its about other boards using I2C, SPI, UART or GPIO (or DSI, CSI, PWM, I2S) it goes in the other forum.
Well have to see how many actual gertboard questions well see here.
